Question about Cell Phones
Multimedia msg trouble
SAMSUNG SYNC SGH A707, cannot send multimedia msg. removed battery & sims card, turned back on, still cannot send.
  • dkgantt Mar 25, 2008
    i guess i didn't give "all" details. i have been able to send multimedia msgs in the past.
    President:
  • 1,017 Answers
You need to get the Settings for Internet/Wap and MMS from your service provider. These settings are usually sent as a text msg. When you receive the msg. choose save or install on your phone. Or you might find the settings on their website.
MMS doesn't always work between networks.
Posted on Mar 17, 2008
  • Anonymous Mar 25, 2008
    If you could send MMS before then you should be able to now, unless your network service provider has changed the settings.
    Delete all old files, txts, msgs and browsing history, clear the browser cache. The phone needs a certain amount of memory to function.
SOURCE:
Could you please tell me the samsung unlock code and procedure fortaking off the network lock, its a 3g phone and i wish to put a vodafone sim in it
Contact your service provider and get the unlock code for your Samsung SGH-A707 from them or else you can get it from online sites. Try Prounlocking.com ,they provide codes at affordable price.
Unlocking Instructions:
1 - Switch ON your Samsung SGH-A707 with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
NOT ACCEPTED:Use a sim card from a network other than the network your Samsung SGH-A707 is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-A707 that you get either from your service provider or from online sites.
Aug 15, 2012 | Samsung SYNC SGH-A707 Cellular Phone
How do I unfreeze my att samsung eternity without a computer cord
Computer card Unlocking is very Big process,So that You can use the Unlock code....also in computer card Unlocking you need to use Cable,Software,USB port,Boxes etc,so take big time ,it's risk process,cost High also,So that i would suggest the Unlock code the simple method to Unlock Your Samsung SGH-A707 SYNC phone,You need to Unfreeze means specify the Network ,Country it locked now?
You can get the Unfreeze Code at
Simpleunlocking and Unfreeze the Phone from Lock...
Samsung SGH-A707 SYNC Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Samsung SGH-A707 SYNC mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung SGH-A707 SYNC mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Samsung SGH-A707 SYNC with a NOT ACCEPTED SIM Card.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-A707 SYNC is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-A707 SYNC.
Each Samsung SGH-A707 SYNC mobile phone has an unique unlock code. You can buy the unique unlock code for your Samsung SGH-A707 SYNC mobile phone using the form above.
Jul 18, 2011 | Samsung SYNC SGH-A707 Cellular Phone
I want to install java games by SD card and want the SGH-A707 code
If you are talking about the security code,
Remove the sim card and power up the phone. Enter the following.*2767*3855#.I have used this code on a few other samsung handset, but never used on SGH-A707.
Try with this hope this helps you.
Nov 19, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Samsung SGH-A707
You can turn on the option to view numbers from both Phone and SIM. If you really need to transfter numbers from SIM to Phone or vice versa, download PC Studio software from samsung.com, just type in A707 in their search box and click download.
Mar 05, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Unlock a Samsung A707
Insert ANY unaccepted SIM card in the phone and then turn the phone on, follow the steps in 1 to 4 below to enter all the codes. The phone will states "Wrong card" at the end of step 2 and "network lock deactivated" at the end of step 4 if you do everything right so pls take your time to enter the code or follow the instruction correctly at each step. When entering some of the zeros at steps 3 and 4 your phone may display the zero as hyphen or minus (-), dont worry, just count when entering the zero to ensure you enter just the right numbers of zeros. Now let's begin... 1/ Put any unaccepted SIM card in your SAMSUNG SGH Phone, turn the phone on, it will display "WRONG CARD"
2/ At the wrong card screen, type *7465625*638*00000000*00000000#
3/ Now remove the battery with the SIM card, Put the battery back and turn the phone on again without the SIM card, it will display "Insert SIM card" 4/ At the insert SIM card screen/end of step 3 above type #7465625*638*00000000#
At the end of step 4 phone will show "network lock deactivated" 5/ Now Reinsert your unaccepted card or any other unaccepted SIM card in the phone and enjoy your unlocked phone!
Jan 27, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Hello please help
I know my phone does the same thing. The only solution is to take out the battery and then jam that ****** back into its slott. If this fails, remove the battery and the SIM card and blow where they connect. Your Welcome
Oct 29, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Samsung SIM card issues!
you dont have to buy new sim...go to your nearest service senter. hardware failure.... sim sockets or sim ic... thats the problem...
Apr 08, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Sim card transfer
depends on the phone you are using to transfer from. On my sony, for example, i can go to my contact list options and send contacts via bluetooth to another device.
Which phone are you sending from?
Jan 22, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Samsung Sync SGH-A707 Audio Problem
Two things:
Are you in an area where they are upgrading the towers to 3g service? Are you going back and forth from Edge service to 3G service. That could cause the click.
And one more thing you could do is pay 25.00 to get a new sim card. Believe it or not this helps sometimes.
Other than that I do not know of any solution or why it is doing that, it should not do it. If its under warranty have att send you a new one (warranty good for a year from the date you bought it)
CARTEEUSMC
Jan 11, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Samsung sync at&t sgh-a707 cell phone
I had the same problem and fixed it by turning off the phone, removing and re-inserting the battery.
Nov 19, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Cell Phones Logo
242 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
