Question about IBM E74 17" CRT Monitor
ATTENTION OUT OF RANGE 74.7 kHz v:59.8 KHz - IBM E74 17" CRT Monitor
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 103 Answers
This means either your Refresh Rate or the resolution has been set (usually in the display settings of the operating system) beyond the monitors display capability. On a windows OS, go to START == CONTROL PANEL == DISPLAY == SETTINGS (for XP) or R click on the desktop and select SCREEN RESOLUTION for Windows 7 & VIsta. Use the slider to reduce the screen resolution to one that both looks good and fits within your monitors capability.
Hope This Helps FixYa! Please leave us some feedback if you found this information helpful.
Posted on Apr 08, 2010
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: I CHANGED MY MONITOR SETTINGS
You need to change your PC video resolution back to the native resolution of the monitor, please read here:
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Sep 23, 2010
Optical Audio Output Formats for PS3
look in your receivers manual or download it using a google search
Dec 23, 2013 | Kenwood VR-606 Receiver
Icom IC-7200 transmit problem on 1600.000 kHz to 1999.999 kHz
If the radio is made to be sold only in the US then the phase lock loop is disabled when your are trying to transmit out of the US band edges. Try looking up a MARS circuit mod for this model and it amounts to only clipping one end of a diode to enable the transmitter on all frequencies.
Nov 12, 2017 | Icom Radio Communications
Out of range 64.0 kHz / 60 Hz
Unfortunately if you cannot get the resolution down, you cannot use it.
Jun 18, 2017 | LG Flatron L1515S 15" LCD Monitor
I get error message: Out of Range, on my 17 inch LCD KDS monitor
get the monitor that you used previously, and on the Windows desktop, go to display properties, in settings> advanced, under the monitor tab, change the refresh rate to 60, which is common on these flat panels.
Jan 05, 2010 | KDS Computers & Internet
Magnum 257 6 digit display
To tune frequencies in either 10 kHz or 100 kHz increments,
press the STEP button until the desired digit is
flashing. Rotate the FREQUENCY control in either direction.
The entire frequency range of the Magnum 257
can be stepped through in 10 or 100 kHz increments.
To tune in 1 kHz increments, press the STEP button
until the 1 kHz digit flashes on and off. Rotate the FREQUENCY
control. NOTE: When stepping in 1 kHz increments,
you are limited to tuning within a 10 kHz
frequency range.
Dec 22, 2008 | Magnum 257 CB Radio
Signal out of range?
Using your CRT, open the properties of the video adapter. Look for the refresh rate and set it to 60Hz. This should fix your problem.
Hope this helps, and please rate my advice, good OR bad.
Thanks, and good luck!
Feb 02, 2008 | Balance CM2017 17" Monitor
Mp3 disk no audio when playing
First, make sure the CD is an AUDIO CD, and not a DATA CD
If you have recorded a Picture CD or MP3 CD
yourself, ensure that your disc contains at least 10
pictures or 5 MP3 tracks.
MP3(ISO 9660) 96, 112, 128, 256
kbps & variable
bit rate fs, 32, 44.1,
48 kHz
– MP3 discs, picture (JPEG) files
on CD-R(W).
– JPEG/ISO 9660 format
– Maximum 9 characters display.
– Supported sampling frequencies :
32 kHz, 44.1 kHz, 48 kHz (MPEG-1)
16 kHz, 22.05 kHz, 24 kHz (MPEG-2)
– Supported Bit-rates : 32~256 kbps
(MPEG-1), 8~160 kbps (MPEG-2)
variable bitrates
Oct 02, 2007 | Philips DVD 622 DVD Player
Range Warning
first, 68.5 khz -85hz means horizontal raster frequency of source signal is at 68.5 kilohertz and repeats vertically at 85 hertz. (hertz means "cycles per second). the sony monitor cannot "read" the signal being sent from the pc. change the screen resolution to a lower number like 75 or 70 hertz vertical.
Jun 05, 2007 | Sony SDM-HS95 19" TFT screen silver LCD...
IBM E74 17" CRT Monitor Logo
336 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
