I have just purchased a Prolectrix Digital Photo Frame (with Bluetooth). I am using a usb memory stick and can get the photos to show but the machine seems unable to run continuously. It gets to the end of the files and stops. Can it be set-up to run continuously. many thanks David
    Problem Solver:
  • 10 Answers
Sure....i think u can find the option in the digital photo frame.....it may like repeat or the symbol...just check it out and have fun
Posted on Mar 17, 2008
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
P350 lexmark saying that a memory card is not present yet it is.also blue tooth on phone cannot connect to printa allthough it is all turned on.
Make sure you are inserting a compatible memory card for your model. Below is the list of compatible digital media memory cards for the Lexmark P350 printer:
  • CompactFlash I & II
  • Sony Memory Stick, Memory Stick PRO
  • Secure Digital (SD) Card
  • MultiMediaCard (MMC)
  • xD Card
  • Sony Memory Stick Duo (with adapter)
  • Mini Secure Digital (Mini SD) Card (with adapter)
  • Sony Memory Stick PRO Duo (with adapter)
  • SanDisk TransFlash Memory Module (with adapter)
  • RS-MMC (with adapter)
Guidelines to print via bluetooth:
  • You can print photos from a Bluetooth-enabled device such as a camera phone using a USB Bluetooth adapter.
  • Make sure that the Bluetooth Enable and Discovery Mode selections on your printer are set to On.
  • Insert a USB Bluetooth adapter into the PictBridge port on the front of the printer.
printmastert_72.jpg Note: Bluetooth adapter sold separately.
  • Once the printer detects the Bluetooth adapter, the following message appears on the printer display for five seconds: Bluetooth Dongle Connected.
  • To print photos from your Bluetooth-enabled device, see the documentation that came with the product.
Aug 15, 2011 | Lexmark P350 InkJet Photo Printer
My external is hooked up to the frame through the usb, but itwill only let me choose internal memory or slideshow folders, it wont let me choose usb when i try to select media sources. how do i get it to...
The external hard drive is diferent from a regular USB stick, so this is probably the case. You could check the manual of the photo frame and the manual of the externa drive, probably you will find some settings that reffer to this.
You could also check that the external drive is plugged in to AC, and turned on, many drives require alternative power source when conected to low power readers like your photo frame.
Apr 07, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
How to scan photos from a scanner on to a memory stick I want to transfer old photos on to a memory stick to use with my digital photo frame
First, make sure the scanner is connected to your PC via USB cable.
Hopefully the scanner software is already installed on your PC, your scanning should automatically show up on your PC screen.
From there, save to Memory Stick and you should be able to view it on your digital photo frame.
What scanner model and brand do you have by the way?
Jan 30, 2010 | Canon MX300 Office All-In-One Printer
Memory stick format
Hello Sir
#1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
# 2 Open up 'My Computer'. You should see it under the list of available drives.
# 3 Check its contents first to make sure that you have the right drive.
# 4 In 'My Computer', right-click on the drive and choose 'Format'.
# 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
# 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Dec 25, 2009 | Coby Electronics DP-812 Digital Photo...
How to send photos from laptop to digital photo frame
The photo frame will either have a card slot or a USB connection on it. If it has a card slot you will need to connect the card to your compuer first (through a card reader) and download the pictures onto it. Then put the card into the photo frame.
If it has a USB connection, you can use a usb flash drive - first plugged into your computer to download the pictures then plugged into the photo frame.
It is also possible that the photo frame has internal memory - in which case you would connect the frame to your computer directly using a USB cable. It would them show as a "Removable Disk" and you can download directly to it.
Nov 04, 2009 | Office Equipment & Supplies
I cant transfer pictures from my PC to a Digital Frame
either transfer to a usb pen or a standard digital card and then insert in photo frame good luck
Dec 20, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
Hi, i can only copy some jpeg images to my 8FF3FP digital photo frame and not others, any ideas why???
it only will show jpeg images no other formats show.
Technical information sheet of 8FF3FPB/00 - 8" (20 cm) Digital Photo Frame - Black + 1GB SD Card With the Philips 8FF3FPB/00 digital photo frame, you can show off all of your favourite digital photos in style!
Its 8" 4:3 screen has a resolution of 800 x 600 pixels, so with the 8FF3FPB/00, you don't need to resize your photos. Plus, the 8FF3FPB/00 uses ImagEn technology to ensure your photos always look their best on this clear, bright display.
The Philips digital photo frame is also an ecological choice, because its SmartPower function allows you to save a considerable amount of energy.
General Device Type Digital photo frame Key Features Digital photo viewer, memory card reader Width 24.5 cm Depth 12.1 cm Height 16.7 cm Weight 494 g PC Interfaces USB Features Auto power off, clock, USB host function, alarm, auto power on Localisation Belgium, Saudi Arabia, United Arab Emirates, Bulgaria, Czech Republic, Indonesia, Israel, Lithuania, South Africa, Vietnam, Ukraine, Egypt, Hong Kong, Iran, Pakistan, Romania, Thailand, Malaysia, Singapore, Luxembourg, Hungary, India, Bolivia, Uruguay, Honduras, Guatemala, Panama, Algeria, Morocco, Bangladesh, Philippines, Croatia, Kazakhstan, Slovakia, Slovenia, Korea, Latvia, Austria, Denmark, Finland, France, Germany, Italy, Netherlands, Norway, Poland, Portugal, Russia, Spain, Sweden, Switzerland, Greece, Turkey Display Display Type LCD 8" - colour Display Form Factor Built-in Image Aspect Ratio 4:3 Image Contrast Ratio 300:1 Image Brightness 250 cd/m2 Display Format 800 x 600 Status Information Card, firmware version, memory Display Features Brightness Memory / Storage Flash Memory Cards Supported CompactFlash Card type I, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, Memory Stick PRO Duo, SDHC Memory Card Digital Photo Frame Operating Modes Landscape, portrait Features Variable slide show speeds Still images Supported Still images Formats JPEG
Nov 30, 2008 | Computers & Internet
Trutech digital photo frame
Most digital photo frames do not have internal memory and require external media to be plugged in permanently. Only the expensive ones have there own memory and usually not a lot.
Get an SD card and move your photos to it, that way you won't need to have the USB drive sticking out of the frame. That's if the frame has an SD slot.
Jan 14, 2008 | Electronics - Others
7" Trutech digital photo frame
I don't have the booklet for this darn thing and I just got it for mothers day.... I have a sandisk in it and I can see the pics just fine, but it doesn't save them??? I can only view when I have something in it??? That's crazy?? Isn't it?? Help
Dec 29, 2007 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
