2005 Chevrolet Tahoe Logo
Anonymous Posted on Apr 08, 2010
My cd player/radio lights, info screen lights, heater/ac light and cigarette lighter stopped working, but the cd player/radio still works on my 2005 Chevy Tahoe....how can i fix this?
  • Anonymous Apr 08, 2010
    I don't have the service book that has the fuse layouts....thanks though, you gave me a good direction to start researching in!
  • Anonymous Apr 09, 2010
    Makes plenty sense!!!
Anonymous
Level 2:
New Friend:
  • Expert 155 Answers
  • Posted on Apr 08, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
155
Questions
0
Helped
36752
Points
294
Sounds like it's a fuse issue even tho the radio works,, my vehicle has a radio fuse and a assessory fuse the controls the lighter and lights on the radio
    use a test light and check every fuse with the ignition on
1helpful
2000 Mitsubishi Mirage. The tail lights, dash lights, license plate light, lighter not working.
Fuse 4 does the cigarette light and the side mirrors. Do the mirrors work?
4 15A Cigarette lighter and control system for side mirrors
Fuse 6 does tail lights
6 15A Stop lights
Fuse 14 does the Dash Lights
14 10A Interior lighting and luggage. compartments, clock, radio or radio tape recorder, instrument cluster, central door lock control unit, engine control unit, automatic transmission control unit
If all those fuses are okay, you need a good auto-electrician.
https://fuseandrelay.com/mitsubishi/mirage.html
1helpful
My radio won’t turn on. My door ajar light WONT illuminate. Neither will the map lights, heater. Please help
The problem is that even if you replace fuse #2 and fuse #8 in the engine compartment, possibly restoring map lights, air conditioning, heater and radio, it is very likely some component is busted and drawing too much power through the fuses. It is possible that the bearings in the heater need oiling finally drying out after 10 years That fuse #2 handles multiple power on functions and if it is blown, you have to round up the usual suspects, i. e. test further to see just which component has truly failed..
My radio/tape deck/CD player all of a sudden do not work, and only those items.
I would see the Audi dealer service department on this, I think the radio has failed.
My cigarette lighter won't work and the radio does not light up. I think it's a fuse but not sure where to find the fuse box.
It is quite true that your problem is likely a burnt out fuse. It is common for the radio and the cigarette lighter to be on the same circuit. The fuse box for this will probably be behind the drivers side kick panel underneath the steering wheel. It might require some contortion for your to get in there, but it will be there. There should be a fuse diagram on the back of the fuse box cover. This will help you identify fuses.
My Ford Ka radio/ 6000 CD RDS EON doesn't work.
It can be the problem with cd player mechanism,on many cases just removing the cd player system out of dash and servicing the unit helps to take care of such problems.
For more help on car radio problems, I suggest you to go through these troubleshooting links, these will help you: -----
Click the link below: ---
Cigarette lighter, Remote central locking, and Radio stopped working http://whoisbyme.blogspot.in/2012/07/cigarette-lighter-remote-central.html
VW passat radio off safe mode? VW radio CODE? http://schematicsdiagram.blogspot.in/2012/03/vw-passat-radio-off-safe-mode-vw-radio.html
How to wire new Radio on 1990 Toyota Celica?
http://schematicsdiagram.blogspot.com/2011/12/how-to-wire-new-radio-on-1990-toyota.html
Radio Stereo Wiring Diagram for 1991 Chevy 1500?
http://schematicsdiagram.blogspot.com/2011/12/radio-stereo-wiring-diagram-for-1991.html
How to remove radio on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-radio-on-acura-car-models.html
Where is Radio Fuse located on 2007 Dodge charger?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
How to reset Radio code after car battery is died?
http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
Can car radio code block Passkey anti theft system ?
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
After Market Stereo wiring for 1999 Chevrolet Silverado 1500?
http://schematicsdiagram.blogspot.com/2011/12/after-market-stereo-wiring-for-1999.html
Chevy car radio doesn't allow to switch to the XM Band to get the radio ID?
http://schematicsdiagram.blogspot.com/2012/01/chevy-car-radio-doesnt-allow-to-switch.html
No power to radio on 2005 Toyota Scion Xb?
http://repairhelpcenter.blogspot.com/2012/01/no-power-to-radio-on-2005-toyota-scion.html
Lexus rx330 Radio has power but no sound?
http://repairhelpcenter.blogspot.com/2012/01/lexus-rx330-radio-has-power-but-no.html
Radio goes ON and OFF while driving?
http://technoanswers.blogspot.com/2012/01/radio-goes-on-and-off-while-driving.html
Lincoln Town Car Radio stereo wiring?
http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html
Radio wiring diagram for 1997 Lincoln Town Car?
http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
How to remove cd player from dash on 2003 Lincoln Aviator
http://technoanswers.blogspot.in/2012/01/how-to-remove-cd-player-from-dash-on.html
These details will help you thanks.
NO POWER TO CIGARETTE LIGHTERS (BOTH) IN TOYOTA MATRIX 2003
good day, you may have a fuse problem, try to check your fusebox and see if you have a busted or fried fuse, if u do then have it replaced. hope this helps, have a nice day
Cigarette lighter(more info)
how about checking the fuse and wiring to lighter
1helpful
3answers
My dash lights are not working the gauges fuse is
good be dimmer switch, but only if all dash lights are out,like radio heater control, cig light,if those still work then i would say its bulbs.
Radio and cigarette lighter
Check behind the dash for loose wiring connections. Check for bulkhead connectors that could have possibly come partially apart. Check for any under dash grounds that are ready to break or have become frayed.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
