Question about Samsung HC-R5245W 52" HDTV
Samsung hc-r5245w no power
When powered up only get red standby light. when you push power button sounds like t.v. is trying to start up but you get no picture and nothing happens red standby light stays on never blinks unless you push channel buttons or volume no picture or sound.
Hello Chac c,
The reason that you are getting a 'red light' is because your lamp is burned out. There is a panel on the back of the TV that gives you access to this lamp. You can remove it and check the part# to be sure then replace it. I did a quick search for you just based on the model# which you provided. You can see it here - http://www.nextag.com/serv/main/buyer/OutPDir.jsp?search=samsung+lamp&gg_site=&gg_aid=1295966762
Hope this helps :)
Posted on Mar 17, 2008
TV won't turn on. Red standby light blinks
Samsung told me this was a common problem and I would have to have it serviced by an authorized repair facility.
My problem ended up being the internal power supply, but they also told me the main boards burn up.
Nov 06, 2013 | Samsung BN94-05038F Main Board for...
SD P50A3 Q red Standby is on....will not power up.
ok sir you have defective power supply at hot side section! and the power oscillstion circuit! your unit need to diagnos to know the exact defective parts!
Oct 21, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Unable to turn tv on.
replace line output transformer.
Jun 30, 2010 | Samsung Televison & Video
My tv come on and turns off stays on 3 min.
How old is your tv and when was the lamp changed last? If its more than two years then you need to change the lamp. Its easy DIY. Buy lamp from reliable source or a known shop. check out rate for lamps on www.fixurtvs.com. thanks if you voted.
Apr 12, 2010 | Samsung HC-R5245W 52" HDTV
My Samsung HC-p4363w have no pic or sound but the power red light is on
Try pushing the "source" button on remote or on the TV. Wait about 5 seconds, if no picture, push again. Do this at least 6 times or until you get a picture. With each push, the TV will look for cable input, dvd input, etc. until it finds your cable signal.
Also make sure your cable/antenna is hooked up and working.
If that doesn't work, hold down the "enter" button for 10 seconds to reset the tv to original factory settings. Then follow the on-screen menu setup instructions.
-please rate me. Thanks and good luck.
Nov 20, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
Samsung HC-R5245W 52" HDTV Logo
240 people viewed this question
Henry  Thomas
Henry Thomas
