HP bt450 Bluetooth Wireless Adapter Logo
Posted on Apr 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to install wireless adapter? - HP bt450 Bluetooth Wireless Adapter
Anonymous
Level 2:
  • Expert 269 Answers
  • Posted on Apr 08, 2010
Anonymous
Expert
Level 2:
Answers
269
Questions
0
Helped
95062
Points
701
Hello faiz
you can download driver for your adapter from here
Click here to Download
actually this device is plug and play hardware but if you still having problem to install this adapter download driver for your adapter then install run the setup.exe file then plug your adapter when prompt
Regards
Manish
Anonymous
Level 2:
New Friend:
  • Expert 115 Answers
Anonymous
Expert
Level 2:
New Friend:
Answers
115
Questions
0
Helped
32936
Points
350
2helpful
I am trying to set up my Avertec N1200 laptop with Windows XP to my Netgear wireless router. The router does not have a USB connection, but I have a Netgear wireless USB adapter. Also, I am getting the msg...
The Netgear Wireless USB adapter should be connected to your Avertec N1200 laptop to act as a wireless antenna. The driver for your Netgear Wireless Adapter should also be installed on your laptop. Once installed, click on the Windows Orb button on the lower left corner of your screen and go to All Programs. Look for the installed program for your Netgear Wireless Adapter to open up the wireless utility of your wireless adapter. That's where you should connect the wireless connection and not on Windows Wireless Manager.
Can i use a Netgear WPN111 USB 2.0 Wireless Adapter with a xbox ?
No definitely not....
If you want your Xbox to be wireless, then you need to buy Xbox wireless adapter...
Bcoz the Xbox wireless adapter comes with a pre-built in drivers....
but other brand wireless adapter donot comes with a built in drivers, you need to install the drivers using a driver cd....But Xbox do not allow driver cd's to be installed on it... so you will not be able to use ordinary wireless adapter instead of Xbox wifi adapter...
How to install an wirless adapter to mi desktop
Install a wireless network adapterIn areas that are served by a wireless network, you can connect to a computer network without using a cable, and surf the Internet or connect with other computers. To connect to a wireless network, your computer needs a wireless network adapter.
Many new computers-especially laptops-come with wireless adapters. Before using your computer, check to see if it already has a wireless network adapter.
If your computer doesn't have a wireless network adapter, you can install one.
Install a wireless USB network adapter. Most people prefer this type of adapter for any type of computer, because it's easy to install.
Install a wireless CardBus or CF network adapter. For portable computers, this type of adapter (also called a PCMCIA or PC Card) is easier to travel with than a USB adapter, because it is often smaller and fits securely in the PC Card slot on the side of the computer.
Install a wireless internal network adapter. If you have a desktop computer, you may prefer an internal adapter so that you can use the USB port to connect another accessory.
The type of adapter you install depends on your computer and your level of expertise.
How to determine if you already have a wireless network adapterMany portable computers manufactured after 2000 have wireless networking built in. However, because the antenna is hidden inside the computer, it's not easy to see.
To see which network adapters are currently installed in your computer
1.
Click Start, and then click Control Panel.
69010-click-control-panel.gif 2.
Click Network and Internet Connections.
69010-click-network-and-internet-connections.gif 3.
Under or pick a Control Panel icon, click Network Connections.
69010-click-network-connections.gif 4.
Microsoft Windows XP displays your network adapters. Wireless network adapters are labeled Wireless Network Connection. If an adapter displays a red X, it is disconnected. If the Network Connections window is blank, your computer doesn't yet have a wired or wireless network adapter.
1helpful
My adapter wireless N WN111v2 is not found
When I insert the adapter WIRELESS N WN111v2 during installation, a message said me : your adapter wirreless is not found !! Help me please
I have a mac os 9.1. I am trying to get my netgear wireless adapter to work with this. how or where would i get software to install it?
well is your computer wireless ready with the wireless adapters installed? if so, what is the hardware installed and who installed it.
1helpful
How to install wireless adaptermn-510
just place the wireless adapter card in your PCI slot which is on the motherboard..then check in the device manager of ur cotrol panel .... then install the drivers ..it will work...
1helpful
I installed a linksys wmp110 wireless adapter into my gateway and it causes the computer to freeze up. i removed the card and the computer works fine. what can i do?
Reinstall Drivers
To re-install the wireless adapter’s drivers, you need to perform two steps:
  1. Uninstalling the Previous Drivers
  2. Reinstalling the Drivers
Step 1:
Click Start, All Programs or Programs, and look for the model number of the Linksys Wireless Adapter.
Step 2:
Look for Wireless Network Monitor and select Uninstall.
Step 3:
Wait for the Install Shield Wizard to complete before re-installing the drivers.
NOTE: Before re-installing the driver, unplug your LinksysWireless Adapter. If you’re using a wireless PCI adapter, shutdown thecomputer then remove the adapter.
The screenshots may vary depending on the model number of your wireless adapter. In this example, we’re using WUSB54GS v1.0
Step 1:
Insert the Linksys Setup CD into your CD-ROM drive.
Step 2:
Click Here to Start
to begin the installation process.
Step 3:
Accept the License Agreement by clicking Next.
Step 4:
Insert the wireless adapter into your computer and click Next.
NOTE: Ifyou’re using a wireless PCI card shutdown your desktop PC and open yourPC’s case. Locate an available PCI slot on the motherboard then poweron your PC.
Step 5:
When Linksys Wireless Network Monitor appears, select the name of your wireless network or SSID and click Connect. If you want to configure the adapter manually, click Manual Setup.
NOTE: To check if the drivers were properly installed, checkif the Linksys Wireless Network Monitor reports the Adapter is Active.For instructions, click here.
NOTE: If you were not able to install the Linksys adapter drivers, you need to update the drivers.
Update the Drivers
To update the wireless adapter’s drivers, you need to perform three steps:
  1. Downloading the Drivers.
  2. Uninstalling the Previous Drivers.
  3. Installing the Updated Drivers.
Step 1:
Before downloading the drivers, make sure your computer has an activeInternet connection. If your computer is plugged directly into therouter and cannot get online, disconnect your router and plug yourcomputer directly into your cable or DSL modem.
Step 2:
Once online, click here to go to the Linksys Downloads page..
Installed a wireless usb adapter to an old computer running windows 98
you re-install your wireless adapter and install the driver of the win 98 only ok the try it.
1helpful
3answers
Netgear 108 Mbps wireless usb 2.0 adapter wg111t
i had the same problem. i tryed downloading the sofware from other computer and install it on the wireless computer. finally i just connected it directly to a lan line and update drivers with windows
Installing pc card: 32 bit cardbus WG511
If your laptop is running on XP, sometimes WINDOWS installs the drivers for the wireless card automatically. If WINDOWS do not install the drivers, you need to load or install the drivers of your wireless adapter. You can use the disc that came with the wireless adapter or downloiad the drivers from the website of your wireless adapter
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
