Question about Sony PlayStation Portable (PSP) Console
Ip adress High every time I go to try and use my psp internet the I.P address times out .? '' First time user to psp maybe I did some thing wrong ''
  • OldManPuff Mar 19, 2008
    What all do I need to hook my psp up to my
    home .p.c .?
  • Anonymous Dec 21, 2008
    Everytime I try to connect to the Internet, my I.P address times out. We believe we may have security or password problem. I don't know. Any help? Please help. If you have any information please answer this.
My ver 3.90 cant play games
Posted on Mar 19, 2008
  • 52 Answers
1. make sure ssid is correct
2. make sure ip is valid
3. configure proxy ( if you have one)
4. reset router and cross fingers
Posted on Mar 17, 2008
What is the network settings adresses for internet on psp version 3002
By default the ip address is assigned by the router unless you made a static ip configuration.
Jun 13, 2011 | Sony PlayStation Portable (PSP) Console
When i try to connect to the internet on my psp it says my
Hi! At This Time : I use WPA PSK encryption simply because it is the only one i can work out how to set up and the PSP will not support this which is why i disable encryption while using it! But : i had that error. wut I did was (u can do this from in the game or in network settings) delete the one that should be working. did it all over again and this time I scanned for a connection. when I found my connection, I used it. and i redid the connection and it worked when I tried it again. Fix-sha0w
Jul 14, 2010 | Sony PlayStation Portable (PSP) Console
Can you tell me what an ip addresse is im trying to connect to xbox live and it keeps asking for ip addresse
Every device connected to the public internet is assigned a unique number known as an internet protocol (IP) address. IP addresses consist of four numbers separated by periods(also called a 'dotted-quad') and look something like 127.0.0.1
since these numbers are usually assigned to internet service providers with region based blocks, an IP address can often be used to identify the region or country from which a computer is connecting to the internet. an IP adress can sometimes be used to show the users general location because the numbers may be tedious to deal with, an IP adress may also be assigned to a host name, which is sometimes easier to remember hostnames may be looked up to find IP adresses,and vice-versa. at one time ISPs issued one IP adress to each user. These are called static IP addresses. beacuse there is a limited number of IP adresses and with increased usage of the internet ISPs now issue IP adresses in a dynamic fashion out of a pool of IP addresses (using DHCP). these are referred to as dynamic IP addresses. This also limits the ability of the user to host websites mail servers, ftp servers, etc. in addition to users connecting to the internet with virtual hosting,a single machine can act like multiple machines (with multiple domain names and IP addresses).
Jan 30, 2010 | Microsoft Xbox 360 Elite Console
Well I'm trying to use internet on my psp. security thing is wpa-psk(tkip). after i do all the settings & test my connection. it always says; connection error has occured. the attemptto obtain the ip...
hello have you try pairing the psp first at the side of the router there should be a pair button once this is done the re enter the wep key
all the best
shaun
Aug 01, 2009 | Sony PSP-3000 Silver Console
Ip adress keeps timing out
bro you will need to change your wep code even if you know the correct one i think it is becuse it allows other devices or somthing to conecte through to change your wep code do the following
1 open internet broser
2 type in the bar (http://192.168.0.1) tuyp tthis in for D-link routers. for Netgear routers type(http://192.168.1.1) as for Belkin routers type (http://192.168.2.1) if you have a diffrent router you are going to have to shearch it on google.
3 ok now when you put in the routers address in the address bar and press enter this parssword/user name thing will pop up you will net to enter (admin) this is the defalt for most routers if you have a difrent router look in the instruction manal or somthing. if you have changed it and you can nto remeber it ring your brodband support.
4 ok now your in your routers seetings change your wep code then reenter the same thing on your psp.
ok some times this will not work and the (ip address thing has timed out) thing will be starting to really **** you off ok this is what you do.
5 go to the start botton in the bottem right coner and click on this then you will need to click on run let it pop up and in the bar type (cmd) this will bring the comarnd promt up if you have vista just go all programs then to asseories then the comarnd promt.
6 once you have ented in (cmd) click on enter and the command promt will pop up in there just type (ipconfig/all) then it will come up with a bunch of informatin on your router.
7 go on your psp and go to ip settings click on manal and enter in the settings that the command promt are telling you.
note: make sure you dont use yuor proxy setings this secrew up thes all way of doing it.
then you are all done and this should work!!!!!!!
Jul 02, 2009 | Sony PlayStation Portable (PSP) Console
Need directions for router
Perform a factory reset of the router. Locate the reset button on the back of the unit. Hold it in with a paper clip for 15-30 seconds then release. Reboot the router and it will be back to factory default. Log into the device, and check the firmware. Look online to make sure that you have the current version, and update it if you do not.
Jun 23, 2009 | Computers & Internet
What is ip address
to fix go on ip chiken.com it will give you your ip
Jan 10, 2009 | Sony PlayStation Portable (PSP) Console
IP adress dosent work.
You need to match the security settings on the Wifi router. I do not know what security is set up on your Wifi, so I cannot accurately solve this problem. I have my router set to WEP with a passcode. On the PSP, I tell the network setup that the wifi is WEP and put in a passcode to match the Wifi routers security. If you have the passcode wrong, the IP address part will fail. Just find out the security type and passcode, then set up the PSP's network connection to match.
Dec 30, 2008 | Sony PlayStation Portable (PSP) Console
Psp internet doesn't work.
Try power cycling (turning everything off for about a minute) and connecting again.
Jul 29, 2008 | Sony PlayStation Portable (PSP) Console
Driver help...Anyone?????
For Router drivers is not required ,U can configure though the command prompt
I can tell some configuration try it,
the default ip adress of the router will the 192.168.1.1 OR 192.168.0.1
In your Lan card configure,
1. obtain Ip adress automitically
go to command prompt----type ---ipconfig---check the ip address which ip is getting---
go to internet explorer ----type the ip address in adress bar-----------login page will get---
login as, user name admin
password admin------configure your internetip adress & DNS ip address,save & check.............
Mar 21, 2008 | Actiontec GT704WG Wireless Router...
Sony PlayStation Portable (PSP) Console Logo
73 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
