Its a cooling problem, i would go out and get a 10 dollar fan that they build for them, un plug everything from everything, wait a couple minutes then attache the fan and put the cords back in. it should work, if it doesnt, you can call the xbox help line, i know its a drag, but if u tell them ur problem and they cant fix it, theyll send you a box to put it in and try to fix it, if they cant theyll send u a new one, thats what happened to me
Your Xbox 360 is stuffed. The 3 Red Lights mean that it has overheated (by the way it's a design flaw it happened to me with my 360). If it is still under warranty, take it back to the place you bought it and they will send it back to Microsoft. If it is not throw it out because it cannot be fixed
Hey man, i dont own a 360, but i know that red rings are know as the red rings of death on a 360
SOURCE: xbox 360 and wii console problems
As far as the XBOX console let collinhaugen know on the lights but to answer you on the Wii no you cannot attach a web n walk (T-Mobile) to a wii console it will not work
Red Ring of Death: Red Flashing XBOX 360 Lights Explained
Common Xbox 360 Red Ring Errors
The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error,
follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
