Question about AOpen : CDRW 52x32x52 Beige Color Retail (MULAOOD14AS) Burner
How do i install a second writable disk drive???
I am trying to install a second disc drive so i can copy cd's, however i am a little confused as to what to do and what i need. I purchased the drive but not sure what to do. can you please help me.
dede
    Master:
  • 518 Answers
Hard drives, CD drives and DVD Drives of this type are usually "IDE" type which requires a flat ribbon cable (IDE CABLE) and a power supply cable.
There's usually 2 "IDE ports" on a mother board. Each port supports 2 drives (HD, CD, or DVD)... a Master and a Slave drive.
In your case, it's best to install the new drive on the other IDE port if possible. The reason is because you stated that you want to record from one to the other.
You need to locate the 2 ports.... at least -1- is being used for your current HD nd CD drive. If the other is unused you simply need to plug a new IDE ribbon cable into it. Note that the ribbon cable has a red strip on one side that should face pin #1 on the mother board plug, but they're usually "keyed" so you can not plug them in wrong. Set the jumper on the back of the new drive to Master, plug in the IDE ribbon cable, and the 4 pin power supply cable. Mount the drive into the PC in an open slot. Then boot the PC, it should find the new drive.
Hope that helps...
Geno
Posted on Mar 17, 2008
    Genius:
  • 3,587 Answers
Aloha...this can be done, IF your computer has the expansion capacity. what kind of computer are you using?
My CD/DVD burner isn't burning at the proper speed. I burned a disc that should have been 66:53, but it came out 66:38 (making the music a little bit fast). I did a burner test, with Exact Audio Copy and...
The speed is determined by the speed of the burner for the type of writable media (disk) you are using and the speed the writable media supports. (For example: I have CD-R disks from years ago that don't write as fast as the CD-R disks I purchased recently.)
The lowest of these two speeds is the max write speed.
Unfortunately, there is a ridiculously large number of disk writing standards which affect write speeds. Check this out: http://en.wikipedia.org/wiki/CD_recorder
If this helps please vote for my solution.
May 22, 2010 | Roxio Easy CD & DVD Creator 6...
Record errors
If your dvd player only supports dvd+r discs then that is the only way it will record. It will only record once onto the dvd-rw and, since it doesn't support the re-writables, it won't be able to use this function. This is the most likely reason for the first error. The second problem is a little confusing. Is it when you are trying to record on dvd-rs or dvd-rws that it says it can't record? I hope this post was helpful (for the first error, anyway). Good luck! I hope everything works out! Sincerely, Der Strom
Apr 06, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Trying to do a backup it says there is not enough disk space available when there is plenty
Probably need more info, such as what utility you're using and where you're trying to back up to. If you?re trying to back up to a CD, make sure it is a fully functional CD-R/W or other writable drive. In most cases folks will try to copy directly onto a CD that is not formatted or to a disc that has been finalized (made readable on other computers), with little or no data on it. Once finalized the "available" disc space is inaccessibly. If you think this is the case, format a new CD-R or CD-R/W disc and try your backup again. If you are trying to back up several directories, such as /My_Documents, you may indeed have too much data for a CD to handle; particularly if you have subdirectories you forgot you had. Try backing up smaller chunks of data to see if that helps. If it does, you can back up several times, or gradually increase the data amount to maximize the disc space usage.
Nov 25, 2009 | Microsoft Windows Live OneCare 2.0...
Hitachi 0A59577 320 gb disk drives reporting high pending and reallocated sectors causes system to crash.Vibration 10-200mz
The electronics inside the disk-drive is encountering "bad" spots on the surface of the disk-drive, and is attempting to allocate some of the "spare" parts of the disk-drive as substitutes for the "bad" parts.
But, it is running-out of "spare" areas to deploy.
What this means is that YOUR DISK-DRIVE IS ABOUT TO FAIL.
Buy an external disk-drive, or buy a bunch of CD-writable or DVD-writable disks, and make a BACKUP copy of your files (E-mail, music),
while you still can access your current disk-drive.
Then, buy a new "internal" hard-drive, and reinstall Windows (you *DO* have the "System Restore" disks, correct?) onto the new disk-drive, and restore your files from your backup.
If your current disk-drive is still under manufacturer's warranty, then exercise the warranty, to get a free replacement. But, make sure that you have copied all your data from the disk-drive *BEFORE* you send it to the manufacturer, because they will take *NO* responsibility for trying to "recover" any of your files.
Nov 09, 2009 | Hitachi Computers & Internet
Why cant I write onto my blank DVD disk I have windows XP and DVD R in my DELL writable drive.Im trying to copy about 1 gig of JPEGS onto the disk. The disc is MAXELL 4.75 GB DVD R. Im using windows XP....
It doesn't matter what name or brand the disc is. All it matters that it is a writable disc. If you had aldready written previous files on that DVD disc and then it was compiled, it wont write again. When the computer requests to compile a disc, say no, otherwise you wont be able to write more data on the same disc. The same goes if you have selected a CD to burn. There are 3 ways to do so. Try copy and paste, drag and drop the file to the DVD icon or CD icon, or right click on the file to be burned and select 'Send to...' choose the DVD drive, (D:), see what happens.
Sep 18, 2009 | Dell Computers & Internet
I am coming up with error 10-fc12-0570 on the toshiba satellite a215-s7422 i used the both recovery disk and this was the error code
The error message is telling you that the recovery utility was not able to read the data from the disc correctly, or wasn't able to write it to the hard drive. The problem could be with the disc, the CD/DVD drive or the hard drive.
but usually error 10-FC12-0570 is pertaining to a bad HDD or memory
First, try copying the second disc using another system. If you can't copy it, order replacements from Toshiba Customer Assistance: 1-800-457-7777. If you can copy it, try using the copy to do the restore.
You can try using a third party disk checker to verify the problem is or is not with the hard drive. But since the system is under warranty, you're going to have to arrange to have it repaired anyhow, so it may not be worth the effort to verify whether it's the hard drive or CD/DVD drive. It's probably not the CD/DVD drive since you got all the way through the first disc. Contact a Premier (not regular) ASP for service from here: http://pcrepair.toshiba.com
The best way would be to load the Win Vista discs n format the pc...and reinstall...iam telling this because u have a tried the recovery disk as well....
I know most users will not have the Vista CD with you but the Vista Recovery Boot Cd is available free by Microsoft just google...
Download it burn the Image .iso and run that disc. Since that disc will not restore the OS all it does it lets u run diagnostics on ur HDD and allows u to install the OS. Once disk check is completed and repaired, proceed with the Recovery disks that you have.
thank you
have a nice day
Jul 08, 2009 | Toshiba Satellite A215-S7422 Notebook
HP Pavillion a712n Desktop PC-CD writable drive space all used up; and it wont recognize blank CD
have not fixed it. Can you fix the title ? I sokld the pontiac. This is about an HP PC. thanks
May 28, 2009 | 1989 Pontiac Grand Prix
When i try to copy dvd it keeps telling me to insert blank disc even though one is in there i can burn cds but not dvd it tells me to put in writeable disk and ive put in dvdr-w and dvd-r and still it...
Go to the device manager to insure your optical drive is in fact a DVD/RW. You should also be able to tell by looking at the front of the drive and see what it says. If it says CD Writable or DVD Rom, you cannot do it. Kind of sounds like you have a CD/RW-DVD Rom combination drive, which does not allow the burning of DVD's.
Let me know, OK.
Mar 15, 2009 | Dell Inspiron 1501 Notebook
Download a powerpoint 2007 presentation onto a lightscribe dvd+r
There are special DVD discs you need to buy. They have an embedded ink on the lable side. I don't hink the CD format is available yet.
Jan 06, 2009 | HP 5188-7537 DVD Writable CD-RW...
Philips CDD4851 CD R/RW in my HP Pavillion XT963
if the device is being recognised, As D:- Or E:- et,c.
right click on the device, and select options from there.
such as open/explore et,c.
If the disk has been written to in any way shape or form, even the smallest file. then the disk being read will be classed as empty.
try a different CD Disk, And try re-installing your CD writing software.
Hope this helps mike @ Compurepair.
Feb 22, 2008 | Computers & Internet
Open Questions:
Which 5 Things missing your website? 1. Social Media Links Social media has become the foremost popular and best type of communication. With the recent announcement from Facebook that over two Billion individuals log in daily to use their website, it might be ludicrous to not faucet into this medium to achieve out to a wider audience vector-free-social-media-icons By using a simple to use social integration tool, websites will easily add this feature to share a message with their social circle quickly. 2. Clear decision to Action Buttons As shortly as you get a visitor to your website, it needs to be captivated to perform a relevant action. It may be a Call us Now button or a Sign-Up form for a free service trial, asking the user to act instantly. Netflix It should make sure that these buttons have the proper aesthetic attractiveness and appear at the correct time while not annoying the end-user. 3. Responsive web design The use of smartphone and tablets has quickly increased since 2012. Marketers corporations'and corporations'and firms} are currently paying shut attention to the present platform wherever fifty-eight of companies have a core mobile promoting team. responsive In such circumstances, a responsive web design is crucial to developing if businesses want to achieve profitable customers. A mobile-friendly website will permit you to compete together with your competitors and provides your business the boost to remain ahead. 4. Email marketing check-in Email marketing campaign could seem like an obsolete technique to stay up-to-date with your customers, however, of course, it can produce wonders for your business if used properly. email signup Placing an email subscription type will permit you to interrupt through the middle of promoting your services to an audience with revenue generating results. 5. Testimonials Word of mouth advertising is that the most credible means that of promoting your business. a region on your website containing remarks and comments of clients'the purchasers'the shoppers} you've got antecedently served will instantly gain the customer trust. test The client testimonials may be a way of gaining your website visitor trust by exhibiting a decent log of your past performance. confirm to focus on these reviews on your website somewhere close to your services section to realize effective results.
Feb 19, 2018 | Facebook Computers & Internet
See all AOpen : CDRW 52x32x52 Beige Color Retail Questions
AOpen : CDRW 52x32x52 Beige Color Retail (MULAOOD14AS) Burner Logo
52 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
