Question about Kodak EasyShare C743 Digital Camera
Will not operate
Camera does not light up when I turn it on. Full charged batteries are installed. Previously, I was using time setting Now does'nt come on.
Tnx., Larry
Be absolutely certain the batteries are installed correctly. The Kodak C743 battery compartment is poorly marked so that if you don't look at the underside of the flip-out door and see the positive and negative imprints (very faint) you may be installing the batteries upside down. This happened to me as I hadn't used my camera in a long time and replaced the batteries for the first time. Finally, I tried the batteries 'upside down' and it turned on right away.
Posted on Apr 07, 2008
Battery charging shows quick green light
Ill try to help you, I think the slow flashing green lite is when you first plug it in the longer its on it will flash quickly when almost finished mine blinks untill full then stays on try to wear your battery all the way down then try to charge again good luck
Mar 24, 2014 | Nikon COOLPIX L19 Digital Camera
Tip
How to maintain camera battery and lengtens camera battery life ?
Camera batteries tips for use and promote battery life:
Camera batteries could cause failure of turning on a Camera easily. Try to turn battery off and turn on Camera through the outside electrical source when Camera can't turn on and all the indicator light if off.
Why Camera battery can't charge to 100%?
Generally speaking,batteries for Camera usually can't charge to 100% due to the display problem but not the battery fault. After adjust the electricity display 1-2 times,it will show correctly.
Whether Camera Samsung BP70A battery life will be cut down when Samsung BP70A battery hasn't run out and is charged?
Samsung BP70A Battery life is generally computed by the times of full charge.Lithium battery usual have 300-400 times and once is defined charge it up to 80%-90%. So don't be worried.
What is the best temperature for battery storage?
Because very hot or cold conditions could affect a battery's performance and such as canon lp-e8 battery life,you'd better store the canon lp-e8 battery in a place with recommended storage temperature of 15°C (59°F).
Camera Batteries Note Of Don't:
Battery can be only used on the designated equipment.
1.Do not heat the battery or dropped into the fire.
2.Do not put it near fire or into the car at temperature over 60'.Do not discharge under these circumstance.
3.Do not put the battery into the water, do not make them wet.
4.Do not put the battery with necklaces, hairpins, coins, or screws and other metal items together in pocket or bag, they should not be stored together with the battery with the above-mentioned items.
5.Do not reverse the positive and negative when load the battery.
6.Do not use sharp objects to pierce the battery.
7.Do not break down the battery.
8.Do not weld the battery directly.
9.Do not use battery with serious wounds or deformation.
Before use your new battery, please read the operating instructions. Improper operation may lead to battery heat increasing, fire, explosion, destruction or attenuation of battery capacity.
on Jun 01, 2010 | Cameras
Troubles Turning Camera On
What kind of camera is this? I suggest calling the company such who will take time on the phone and work with you to fix the issue. Didn't have the same problem but have a Nikon and they assisted me over the phone almost an hour working with me to solve the issue.
Mar 25, 2017 | Cameras
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Cameras
I have a olympus 7010 digital camera. everytime i try to turn the camera on, a orange light flashes and turns off. i've tried charging the battery numerous times.
The Olympus Stylus 7010 has a rechargeable lithium ion battery that will eventually wear out-- your battery could be at the point where it does not hold a charge any longer.
Have you previously noticed a degradation in battery life? If so, you can try replacing the battery or connecting the camera to a constant power source (like an AC adapter) to troubleshoot.
Mar 04, 2011 | Olympus Stylus 7010 Digital Camera
Camera has failed to operate giving a "change batteries" message
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Nov 29, 2009 | Canon PowerShot S3 IS Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Sony DSC-S70, battery not charging to a full charge
That battery is not good.if the battery have warranty please give back and get new one. after that the problem continues, The charging control ic of the camera may be damaged
Sep 21, 2009 | Sony Cyber-Shot DSC-S70 Digital Camera
Kodak EasyShare C743 Digital Camera Logo
62 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
