Question about Sony KDSR50XBR1 50" Projection HDTV
Flashing red light
I have this sxrd projection for 6 months.suddenly,while watching a tv show,the picture disapeared but sound remained,a green light continouosly blinked,i pressed on the ON button and suddenly the sound also disappeared and the blinking green light became red which flashed 5 times for every 2sec interval.i switched off the tv,after a while pulled out the plug.after 30minutes tried to turn on the tv but won't start anymore with the standby button flashing red 5 times for every interval
My standby light blinks 5x and the t.v. won't turn on. I have unplugged the t.v. from the socket, but still no luck. Called Sony and all they said was that the blinking could be a few things and that I should call a Sony authorized dealer. The optical block alredy went on this t.v and it's not even 2 years old.
  • Anonymous Apr 03, 2008
    Mine did the same thing. Check your bulb. Mine was visibly broken internally so I ordered a new one. Haven't gotten it yet. I was told it could also be the ballast but if the ballast is bad it shouldn't ruin my new bulb. Hope this helps
  • Anonymous Sep 13, 2008
    I've had the optical block replaced after 5 months; Then tonight the tv just went black. When I tried to turn it on the standby light (green) blinked for about a minute then it changed to red. Unplugged tv and powered on and off a few times without any success. HELP
On the right side of the tv as you are looking at it behind the lamp housing cover there is another cover that has four snaps. It looked like it used to hold a filter. Take this cover off and blow out any dirt with dry air from your electronics store. Plug it back in and turn the set on. If that does not work I have removed the lamp housing cover and blown that out. Turn the set back on. If that did not work then tap mediumly on the back behind the housing. It appears that the main fan has a problem with collecting dirt and the quitting.
Posted on Mar 14, 2009
Light bulb
Posted on Mar 27, 2008
2 Suggested Answers
SOURCE:
SOURCE: flashing red light
I think this sounds like my problem (need to replace the projector lamp). However, when I hit the "on" button, my SXRD 50" blinks green for about a minute then starts blinking red. Can you confirm the bulb solution? I was very pleased with this sight when my fan malfunctioned. I got the fan in a matter of day's from Sony and it fixed that problem.
Posted on Mar 19, 2009
The LCD light (green) flashes for like 6 times and then the pictu
even though the lamp light is not flashing I would think it is the lamp getting weak for some reason the Sony's do that.
Aug 19, 2009 | Televison & Video
Sony 50 inch KDF E50A12U switched itself off!
Does the on/off light flash green and red or just green. Is the light to the left of the on/off light on (this means bulb has definately blown)
Probable problem is that your lamp has blown. This can replaced quite easily, but costs about £100. Search google for xl-2400, there is also a video on youtube showing how to replace bulb.
Aug 11, 2009 | Televison & Video
No picture or sound
Does anything start to work? Any of the three fans start to turn, Lamp ignite, etc., when you press the power button or does nothing happen before the Red LED starts blinking. How many times does the RED LED blink?
Jul 25, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light has recently starting flashing and the picture and sound blank out. it does it for about 30 seconds and then picture comes back on...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light flashes green 96 times than it switches to a RED lamp light that flashes steady. Do you know what it means?
Apr 27, 2008 | Televison & Video
Lost picture
sounds like video card failure mode, 101..you a technically adroit person?
Apr 03, 2008 | Televison & Video
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Flashing red light
Oct 29, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Open Questions:
Sony KDSR50XBR1 50 black screen, no faults! Lamp working, fans OK Sony KDSR50XBR1 50" HDTV: The light engine was working fine before the fan quit starting on it's own. After disassembly, cleaning and lubrication of the fan, I have no errors but the input display or menu options will not post on the screen. The lamp is on but seems to either be projecting a solid black picture, or not be at full brightness and there are no faults. I have a solid greed LED on top, but can get no picture. Sound is fine. What should the lamp voltage be at operating mode? I have tried reseating connectors and pushing on the wires to make sure the connectors seat. This is baffelling because the lamp fired fine for 1 second before the stuck fan issue was corrected and I have no faults now after lubricating the fan. I'm going to check connectors again today as a triple check; as I did remove the power supply. The TV has been reset per instructions in the book. Any advice would be much appreciated but I cannot believe it's the OB as it worked fine before the fan quit and it's about 14 months old. I'm thinking something may not be assembeled correctly, but everthing seems to be pretty idiot proof for re-assembly. Also the menu or input banners will not post. I have 2 new lamps, so it's not that.It seems to be stuck in somne black screen mode. The large fan does start by itself now after cleaning and lubrication, therefore no fault blinks. Please help!!!
Mar 01, 2017 | Sony KDSR50XBR1 50" Projection HDTV
Sony KDSR50XBR1 50" Projection HDTV Logo
507 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
