Question about Toshiba Satellite A45-S150 Notebook
MEMORY WHERE IS THE MEMORY LOCATED?
  • 1 more comment
  • shroomnjaime Oct 07, 2008
    Ok the RAM is located under the keyboard. How do I get to to it without ripping the whole machine apart?
  • junk4chuck Dec 10, 2008
    As stated, ram is located under keyboard. How do you gain access. Want to upgrade to more ram.
  • Anonymous Feb 13, 2009
    I want to upgrade the ram.
    Sergeant:
    Champion:
  • 256 Answers
Remove keyboard its down below the keyboard.
Posted on Mar 17, 2008
Need to program new phone numbers
The manual is available here: www.uniden.com/pdf/CEZ260om.pdf. If you search google for "uniden cez260 corded phone manual" it is the first result.
You can find the instructions in the fourth column of text under "Storing a Name and Number in Memory"
Here is the text from that section, but I can't promise the copied text is accurate. Check the pdf at that address if anything doesn't work.
1. Press STORE. LOCATION? shows in the display.
2. Press the desired memory location (0 to 9 or quick call buttons A, B, or C.) NOTE: Press LEFT or RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C to select a location.
3. Press STORE again to con? rm the memory location. NOTE: Use Delete to erase existing memories or to correct errors.
4. Use the number keys to enter the telephone number (up to 32 digits) and then press STORE to save. (The unit will not dial a phone number in this mode.) The cursor automatically moves to the text line for name entry.
5. Use the number keys to enter the name of the person associated with the telephone number you just entered. More than one letter is stored in each of the number keys. Press the keys multiple times to scroll through the letters for that key. For example, to enter "B," press "2" twice. Press LEFT two times to create a space. NOTE: The ? ashing cursor automatically moves to the next position or you may press LEFT or RIGHT to move the cursor to the next position.
6. Press STORE to save the name.
7. To enter another name and number in a di erent memory location, return to step 1 and repeat this process.
Storing a Pause in Memory
The REDIAL/PAUSE button has dual functionality and becomes a pause button when pressed in sequence after the STORE button. It is valid only when storing a number into memory locations. Use the REDIAL/PAUSE button to insert a pause when a delay is needed in an automatic dialing sequence (for example, when you must dial a 9 to get an outside line or when you enter codes to access your long distance company).
NOTE: A pause is 3 seconds in length and you can store more than one if a longer pause is needed. Changing a Stored Number Repeat the storage sequence under Storing A Name and Number in Memory, and press DELETE to delete the old number before entering the new number.
Erasing a Stored Name & Number
1. Press STORE.
2. Press the memory location (0 to 9 or quick call buttons A, B, or C) to be erased.
3. Press DELETE.
Copying Caller ID Memories to User Memory
1. Press LEFT or RIGHT to view the caller number and name you want to copy.
2. PressSTORE.
3. Press the memory location (0 to 9 or quick call buttons A, B, or C). The number ? ashes if there is a number already stored in that memory location.
4. Press STORE to enter Edit mode, and then pressSTORE again to edit the name. NOTE: Select a di erent memory location by using LEFT and RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C.
5. Press STORE to con? rm and save. Wait three seconds to exit.
NOTE: If the name you want to enter is longer than 12 characters, only the ? rst 12 characters will be copied into memory.
Storing a Redial Number to Memory
1. Press STORE.
2. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If a number is already stored in the memory location, it will appear on the display. Use LEFT and RIGHT to select a di erent location.
3. PressSTORE again to con? rm.
4. Press REDIAL/PAUSE, and then press STORE again.
5. Enter the name, if necessary, and then press STORE to con? rm.
Copying a Redial Number to Memory
1. Press REDIAL/PAUSE while on-hook. Redial number will display along with PICKUP PHONE.
2. Press STORE.
3. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If there is a number already stored in the memory location, it will appear on the display. Use the RIGHT or LEFT buttons to select a di erent location.
4. Press STORE twice.
5. Enter name, if necessary, and then press STORE again to con? rm and save.
Dialing Numbers Stored in Memory
1. Press DIAL.
2. Press a memory location button or use LEFT or RIGHT to scroll through stored memory locations to ? nd the desired number. The number in that memory location displays.
3. Press SPEAKER or pick up the handset to dial the displayed number.
OR
1. Lift the handset or press SPEAKER.
3. Press DIAL again to dial the stored number.
Jun 11, 2015 | Uniden CEZ260 Corded Phone
How to turn memory off on casio fx300es
There is no memory that YOU can turn ON or OFF. All you can do is store numbers in some memory locations (A,B,C,D,X,Y) and M. By pressing ALPHA 9 (CLR) you reset the calculator, thus clearing the contents of the memory locations. Another way to clear a memory location is to store 0 in it. 0 ->ALPHA A, stores 0 in A.
Sep 05, 2011 | Casio fx-300ES Calculator
Putting numbers in the memory and editing
To store numbers in memory do the following
(Make sure the phone is in standby and not in TALK mode)
2.) Press the memory button on the handset or base.
3.) Press the desired memory location button (0 through 9 number keys) or
use the CID-VOL (- or + ) buttons on the handset or CID/rev or CID/skip)
buttons on the base to scroll to desired memory location. If the memory
location is occupied, the stored name and number displays. If the
memory location is unoccupied, EMPTY shows in the display.
4.) Press the memory button again. The display shows ENTER NAME.
5.) Use the base or cordless handset touch-tone pad to enter a name (up to
15 characters).
6.) Press the memory button again to save your selection. The display
shows ENTER TEL NUMBR.
7. Enter the area code followed by the
telephone number (up to 24 digits, including pauses) and press the
memory button again to save your selection. The unit beeps to confirm.
8. To enter another name and number in a different memory location,
return to step 1 and repeat the process.
Manual available HERE
Jun 17, 2011 | Uniden Cordless Phone
How do you program #'s in to the phone
There are 20 memory locations to store numbers in, they are numbered 01 - 20. Press and hold the memory button until Memory Store shows in the display. Dial the 2 digit memory location or use the arrow keys to choose the memory location. Press the select/channel button which will show Store Name in the display if the memory location is empty or will show edit and delete options if the memory location has an entry in it. If the memory location is empty, use the number keys to enter a name for the memory location. Press the select/channel button which will show Store Number in the display. Enter the phone number using the dial pad. Press the select/channel button to save the entry. Press the memory button to end.
Here is a link to download the manual in pdf format.
http://www.uniden.com/pdf/TRU348om_VA.pdf
Jan 23, 2011 | Uniden TRU348 Cordless Phone
Hi, are there MC, MR, M-, M+ functions in Texas Instruments BA II Plus calculator?
The calculator has 10 memories (0 to 9)
To store a number (13) in memory 6 type 13 [STO] 6
To erase the content of memory 6 (M6) store 0 in int: 0 [STO] 6
To recall the content of memory location M7 press [RCL]7
To operate on the content of memory location M5 the syntax is [STO] [Op] 5, where [Op] is the operation symbol [+], [-],[x], [/] [y^x]
Ex: to raise the content of memory location 4 to the power of the displayed value, you press [STO][Y^x] 4
To clear all 10 memory locations
press [2nd][MEM][2nd][CLR WORK]
In short, although you do not have the keys you are accustomed to, you have a lot more. And please do not blame me if you feel disappointed.
Apr 18, 2010 | Texas Instruments BA-II Plus Calculator
Memory upgrade.. toshiba portege 3500
hi..the one of memory located at the lower or under the one slot memory installed..thanks...^_^
May 13, 2009 | Toshiba Portege 3500 Tablet PC
Where are the 2 sockets for RAM memory located? One is at the back of the laptop in the center, where is the SECOND ONE? They are not in the same location. Please, I need the exact location.
The 2 memory slots are in the same location. The memory modules essentiall lie on top of each other. If you open the back cover you will see 2 slots in which you insert the memory modules. They're referred to as slot Aand slot B.
Mar 08, 2009 | Toshiba Satellite M45-S169 Notebook
Store & Recall Buttons
STO 1 puts the displayed value into memory location 1.
RCL 1 brings the stored value back.
Same for memory locations 2 and 3.
If there's something in memory, M1, M2 M3 will show in the display, clear the memory by storing the value zero.
Note that anything stored into memory location 1, 2 or 3 over writes what was there. Memory values are retained through power off/on.
To add the displayed number to a memory location (instead of replacing the value stored), use 2nd, STO, n
To exchange displayed and stored values, use 2nd, EXC, n
n is 1, 2 or 3
Get the instruction booklet from TI's website (pdf download) if you don't have one
Sep 26, 2008 | Texas Instruments TI-30XA Calculator
Programming a number for memory
Memory
Store up to ten 20-digit numbers in memory for quick dialing.
Storing a Number in Memory
1. Make sure the phone is OFF (not in TALK mode).
2. Press the MEMORY button.
3. Press a number (0-9) to store the dialed number in that memory location.
4. Press the MEMORY button again.
5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm.
6. To enter another number in a different memory location, return to step 1 and repeat the process.
Nov 03, 2007 | Uniden Cordless Phone
Toshiba Satellite A45-S150 Notebook Logo
89 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
