Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Wf640 test wf640 has test showing will not reset to use
  • 2 more comments
  • Anonymous Mar 25, 2009
    my machine indicates test and won't let me do a cycle
    my machine keeps doing a test cycle
  • Anonymous Apr 25, 2009
    the machine will not reset from the test mode
  • tonkev1993 May 01, 2009
    Machine stuck in TEST mode. How do I fix?
This has happend to me today! this is the fix
  1. Press and hold the Start/Cancel button until message clears
  2. Now press both Start/Cancel and On/Off buttons together until you get a dOFF message
  3. now your machine should work OK
Posted on Jun 25, 2009
  • leemyson Sep 25, 2011
    Thankyou very much for the answer it was driving me nuts.
  • dan farley Jan 20, 2013
    how do you know when it is in test cycle
Cancel program on hotpoint aquarius wdl540
Posted on Nov 22, 2009
2 Suggested Answers
  • 25 Answers
SOURCE: test light
Press and hold "on/off" and "start" buttons together for five seconds.
Posted on Jun 03, 2009
Hotpoint aquarius washing machine displaying tESt +won't do anything
Someone has accidentally pressed some buttons and locked you into test mode.
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Your machine should now work.
Oct 21, 2012 | Hotpoint Washing Machines
Is there any filtter to clean in hotpoint wf640
Remove the lower rear panel of washer, locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside the hose.
Reassemble and test for leaks.
Have some cloths ready to wipe up water from hose.
Jan 10, 2011 | Hotpoint Aquarius WD640 Front Load...
I have washing machine Aquarius wf640 + it keeps showing f-02
F02 indicates that the motor tacho has broken or become detached, this is to be found on the end of the motor shaft.
Pleawse rate my solution.
Thanks.
Aug 07, 2009 | Hotpoint Ultima WF860 Front Load Washer
Test light
Apr 25, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wf640 washer says 'test' on digital display. what does this mean?
hold down start button untill unit comes out of test. Then hold start and on/off button untill it gives you test end message.
Jun 29, 2008 | Hotpoint Washing Machines
Hotpoint WF640
the f-01 error code on your hotpoint all in 1 washer/dryer is a short circuit code for the motor. the only way to clear the code is to have a service tech come and inspect the reason for the error.
May 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WF640
check your water supply to the machine is of adequate pressure . this is the sign when the machine is not getting enough water
Dec 16, 2007 | Hotpoint Aquarius WD640 Front Load...
Error message
Hotpoint’s are designed to go into test mode when the start button and the on/off button are pressed at the same time. If you are stuck in Test mode, simply hold the start button down until it comes out of test mode, then hold both the start buttons and the on/off button down until you see ‘D:end’ (or similar message)."
Nov 03, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
1,515 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
