Question about Dishwashers
Water doesn't drain ot
Water doesn't drain out - the details of the dishwasher as follows:
FDB510LC53
Serial Number # TH65125751
Energy Star Rating
    Genius:
  • 3,587 Answers
Check the filters in side..and also the down pipe for blockages first.
Posted on Mar 17, 2008
  • Patrick Michaels
    Patrick Michaels Mar 17, 2008
    this could be a weakening pump as well, but checking for clear drainage is recommended.
Motor keeps running. Water heats fine. Help
One of the reasons for motor not draining during normal cycle is the check valve is stuck. It is meant to return to normal during drain cycle but close during wash. I think the cancel is resetting it and letting water out.
See this discussion.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/26-129-977852-/Bosch-Dishwasher-won-t-drain-SHE43RF2UC64
Apr 02, 2014 | Bosch 24-in Built-In Dishwasher Color:...
Clear water left n bottom of dishwasher
Check drain and pump. If the water goes to a garbage disposal then remove the hose at the disposal and see if it is clogged.
Good luck,
Marty
Mar 23, 2013 | Whirlpool Whirpool Energy Star Dishwasher...
Doesn't drain
Drain line could be clogged with food particles
Pump could be bad
Sep 10, 2012 | Frigidaire Dishwashers
Not draining
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Aug 20, 2010 | Frigidaire 24 in. GLD2350RC Energy...
Water will not drain during the rinse cycle
A lot of those front load type washers have problems resulting from overuse of detergent. You should remove the panel and clean ot the sludge and lint inside. Service Manualb8c024f.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 07, 2010 | GE Energy Star WCVH6260F Front Load Washer
Water does not drain
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 10, 2009 | Frigidaire 24 in. PLD2560LCC Energy...
My Kenmore Dishwasher will not drain.
Some of the energy star models have a p poor motor with plastic pumps parts. The pump reverses direction to pump out the drain water but get in a bind and the motor shuts down. These units should be recalled.
May 10, 2009 | Dishwashers
Machine doesnt drain properly
The following checks might help you out->
Check the sink drain and drain hose for restrictions
Unjam the motor
Unjam the pump
Check the drain valve
Check the drive belt
Please do post comments if the solution is not clear.Also to provide internal diagrams, so that the parts can be identified easily, please provide me with the model number. Please do rate my solution if accepted.Thank you for contacting Fixya.Good luck with the machine.
Sunny
Apr 08, 2009 | Dishwashers
Dishwasher comes on, fills with water, water heats, no movement of the arms so no water spraying out, then the water drains, it goes through the dry cycle and no clean dishes.
What is the manufacturer and model number of your dishwasher?
Depending on the model and design, the sprayer motor/pump has probably failed and the drain motor/pump is still working.
Recommend you pull the sprayer arm and filter. Look for debris that could be jamming the pump - watch out for broken glass when looking.
Make sure the impeller can spin and is not damaged.
If that does not fix the problem, replace the wash motor / pump or replace the entire dishwasher with an Energy Star qualified name brand model.
Good Luck!
Apr 01, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
130 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
