Have an RCA floor model tv that has a crack in the protective screen. Where can I order a replacement screen?
  • bishop43 Apr 17, 2008
    I have a philips 55pp9401 with a cracked screen, and broken mirror. Where can I find the scree and mirror? How hard is it to put it in yourself? I work on cars, would you say it is a difficult as replacing an engine?
  • 8,617 Answers
What is the model number of your set as well as the dimensions of your screen top to bottom and side to side. Screens are hard to find, but I have a source for used ones.
Posted on Mar 17, 2008
6ya staff
SOURCE:
Need to order a replacement 46" LCD Screen
Sorry,not repairable,because the LCD screen panels are limited produce by the Tvs Corporations.No where u will able to buy a LCD Screen panel for the replament,but except by the tvs corporations themselves.Because it limited production of the LCD screen panels,they will sell it to u the same as a new tv.Might even cost more after the labors of by replacing the LCD screen panel.
May 23, 2010 | RCA L37WD12 37 in. LCD HDTV
The tv was working and made a hiss and pop and quit, I replaced the flyback and now it just ticks
When you replace a flyback on an RCA Model, Always replace the Horizontal Output tranistor with it. These models are notorious for for bad solder connections in and around the HV area. Also check around the High Voltage Area for bad HV Scaning Capacitors. These are usually square shaped , for cracking,arching,and swelling. Replace if found to be defective. One more thing check the neck of the picture tubes for cracks or arching inside a tube when trying to turn the set on. Sometimes a bad scanning cap will go defective and drive the high voltage so high it cracks the Green CRT.
Nov 15, 2009 | RCA P52960 52" Rear Projection Television
Need screen protecter
Here's a link to order the original Hitachi protective screen for this model (57F59A) from a major parts distributor:
Hitachi 57F59A Replacement Part Protective Screen / Ultra Shield
Mar 03, 2009 | Hitachi 57F510 57" Rear Projection...
I have a Magnovox HD TV Progressive Scan (Floor Model) TV
You can find a replacement Philips/Magnavox fresnel screen, in stock, for this model (51MP392H/17) at this following link from a major parts distributor:
Philips / Magnavox 51MP392H Replacement Part Fresnel Screen
And here's a link for the Lenticular (middle) Screen, if needed:
Philips / Magnavox 51MP392H Replacement Part Lenticular Screen
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
Small scratches on tv screen, can I fix it?
The only way to completely get rid of the scratches is to replace the screen. If you want to get a new replacement protective screen for this model, here is a link from a major parts distributor:
RCA P61927 Replacement Part Protective Screen / Super Shield
Jan 15, 2009 | RCA P61927 61" Rear Projection Television
Screen broken or cracked
you will need to call rca and order one from them
here is a customer service number you can call for more details on how to get the screen
877-794-7977
Dec 10, 2008 | RCA HD52W59 HDTV Projection Television
Rca projection tv
MCM electronics 800-543-4330 $197.77 p/n 240793
Jan 25, 2008 | RCA P52937 52" Rear Projection Television
My tv
if your tv has black borderaround screen protector it has to be replaced with original part..if not it can be replaced with plexi-glass, avail at local home improvment stores john
May 24, 2007 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
