Question about Alpine CDA-7863 CD Player
No sound coming from deck
The deck produces no sound via tuner or cd I am trying to install in a 1997 Ford Explorer
  • 1 more comment
  • bubbaj1 Mar 17, 2008
    I am connecting thru the built in amp and yes everything else seems to work just fine.TY
  • renekaizer Aug 09, 2008
    i have called the store that i bought the deck from about the no sound problem but they werent much help. i need to know where to find the built in amp and what to do after that
  • Tygh Duval
    Tygh Duval May 11, 2010
    Are you connecting via the built-in amp or do you have an external amp?
    Does the deck seem to operate fine, other than no sound?
    Problem Solver:
  • 7 Answers
Check the remote wire(the blue with white) is it giving 12 volts to the factory amp? some ford have amps that needs to turn on when the radio turns on.
Posted on May 28, 2008
  • 3 Answers
You have to bypass the factory amp. I had the same problem. They burn up really fast when changing the head unit! take it out
Posted on May 21, 2009
I'm having the same issues. No sound from the unit. Display sits at 87.7 and doesnt indicate any reception from the display. Buttons dont function. Knob changes the volume, buttons beep and light up indication when pressed, and display tilts up and down.
When I had initially wired it up, it worked flawlessly. I have metered at all joining points with total continuity everywhere. Tuner worked and CD worked.
I have tried switching between the AiNet switch underneath with no change as well.
What gives, internal problems?
Posted on Apr 21, 2008
    Sergeant:
  • 300 Answers
I can't seem to find the manual online, so I'm flying blind. It's possible the wiring harness/connector that connects the deck to the (factory?) speaker wiring may be disconnected. That's the only thing I can think of that would affect all of the channels at the same time. Otherwise, there's always the possibility of the deck having internal issues.
Posted on Mar 18, 2008
How can I use a hand held stereo microphone to record via a Denon F101 tape deck
You really need to include all brand and model number info for this question.
Feb 03, 2015 | Denon Audio Players & Recorders
Hi, I'm digitising my old cassettes. I have a
Just connect the line outputs from the tape deck to the line input of the computer using a dual RCA to mini stereo adapter if necessary. Your processing software will correct any deficiencies and produce satisfactory results. Be sure to copy the original tape information before dumping the old tape; otherwise you will have a "mystery" CD
Sep 08, 2013 | Audio Players & Recorders
Where is the amp located for 1997 ford explorer. I am trying to install an aftermarket radio. I have the harness that I need, but where is the amp and the antenna lead tuner box located in the vehicle?
right side above the rear wheel well -you have to remove the panel which has fasteners everywhere and a few screws under the carpet-might have to get a special antenna adapter too- ford premium stereos are weird like that-good luck
Nov 24, 2009 | JBL GTO755.6 Car Audio Amplifier
Installing an aftermarket stereo in 1996 explorer...sound issues.
You may have a factory amplifier in the rear of the explorer in the right cargo panel. You need to supply power to it by connecting the amp power on (Blue/White I think) in the dash to a power source (such as red on your stereo harness) so it comes on with the key. If you do have the amplifier, that's why you have no sound.
Oct 02, 2009 | 1996 Ford Explorer
1997 Ford Explorer Radio will turn on but no sound When i first turn it on it says {Phone} then switches to tuner
its either in a bluetooth phone mode, or the deck is bad.
if its bad, remove the deck and throw into nearest trash can.
Mar 12, 2009 | Car Audio & Video
No Sound from CD but I do get sound from tuner
you have the blue, power antenna, wire hooked...
(blue/white is remote for amp)
Feb 20, 2009 | Alpine CDA-7863 CD Player
1997 Ford Explorer, whining sound when put in reverse
HAVE YOU TAKEN YOUR FORD BACK TO THE PEOPLE WHO REBUILD YOUR TRANS. FOR A 300 MILE TEST DRIVE? I HAD THE SAME PROBLEM AND COME TO FINDOUT THE TRANNY WAS LOOSE ON THE END AND THEY WERE ABLE TO FIX IT AGAIN.
Jan 23, 2009 | 1997 Ford Explorer AWD
Where can I get a speaker wiring chart for 97 Ford Explorer
Perhaps there was another system installed at another time and someone cut the wires within the system to make that particular stereo system work. Inspect the wires all the way from the decks wiring harness to the speakers, they could be cut and you might be able to splice the wires and reconnect them or you may have to run seperate speaker wire for each speaker to resolve this issue.
Can't get B Speakers to work
Use the remote and switch it to be in the sub mode (top right corner of remote) It is here (in the sub mode) that you can change volume and inputs.
May 29, 2007 | Onkyo TX-DS555 Receiver
Help!!
if you have a amplifier to it you might want to check your remote wire there is two of them they are blue check and see if its connected to the one that says amp not antena remote.i think that that is you problem
Nov 22, 2006 | Kenwood KDC-MP628 CD Player
Alpine CDA-7863 CD Player Logo
488 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
