Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Hoover Steamvac Ultra
It is not sucking the water back out of carpet. I checked the brushes, the lid on recovery tank, everything seems to be intact. Now what? I have wet carpets.
  • Veronica553 Aug 24, 2008
    I have checked the brushes and the upolstery tool. They are all hooked up according to the directions. I have used these tools for years and have not had this problem. Water comes out but the machine doesn't take it back in'
    New Friend:
  • 136 Answers
Make sure all parts are snapped in again i did the same thing.......
Posted on Mar 17, 2008
Steamvac will not **** up water
Check the lid on the lower tank. The front of the lid lips over the tank to lock it on and snaps in the back. You probably haven't locked the front edge down
Apr 29, 2010 | Hoover F5810 SteamVac Upright Vacuum
Hoover SteamVac LS F5899-910
Did you try to clean first the unit..
Jun 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Its not sucking up the water off the carpet , no suction , it's spraying , the scrubbing brushes are spinning , I can feel air blowing out of the side, I don't know if i usually feel that are not
Hello. Take out your recovery tank, remove the lid, and re-attach lid rolling it from the front to the back, there are two tabs on the tank that the lid has to be aligned with, you will hear it "click" when it is tight. I think this might be the trick! Let me Know if I helped. Thank you. Rene (The Vacuum Doctor) Don't forget to have your unit serviced once a year by a qualified tech!
Nov 06, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I poured the water out and when i went to put lid back on its not sucking up the water and lid keeps moving around
The lid on the lower tank needs to have a tight seal, otherwise you will lose suction to the floor. make sure all latches are secure.
Oct 27, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Steam vac won't **** water
check to see if the recovery tank lid is on correctly. if this is not on, the machine will not **** up the dirty water from the carpet. all you will get is suction that is chopy when it comes up instead of more like a flow.
Jul 31, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Steamvac won't **** the water into the recovery tank.
This usually means one of a few things:
1. The lower tank is full
2. You did not dispense water (sloution tank empty), when applying solution to the floor.
Jan 19, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam cleaner F5912-900 not sucking up water
Check to make sure that the lid locked down all of the way around. If yours has a foam filter on the inside of the recovery tank lid, make sure it has at least a 1/4 in. gap from the top. There is a filter, from the bottom, has a red casing, remove it and clean it. Also make sure that the removeable duct in front of the recovery tank is in place.
Solution tank does not dispense--recovery tank still sucks up dirty water from tile floor on screen porch. I applied cleaner manually with a scrub brush and sucked it up with the hoover steam vac deluxe.
Check to see if the when you squeeze the trigger, the rod is hitting the reservior asm(tank sits on). If not then there is a problem inside the handle and the rod. If it is hitting, then the reservior asm. is bad. Also make sure fluid is coming out of the tank when you push the vavle in at the bottom of the tank.
May 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Steam vac will not pick up dirty water
My Hoover Steamvac problem isn't with the bruches--it's with the suction. Dirty soapy water stays in the carpet instead of being returned to one of the holding tanks.
Oct 21, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
430 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
