Question about Mitsubishi VS-50501 50" Rear Projection Television
Mitsubishi 5051 I have a Mitsubishi 5051 big screen i was in "menu"i went to "Advanced Features"then i went to "Use Home theater' pushed enter and the screen said "this TV is Set up for use with a home theater receiver" and the screen turned blue and i have no picture or sound please help
  • 868 Answers
I can help you here follw my pictures and be sure you have a reciever hooked up so the TV can identify it.In some cases like in picture #2 you have to tell the TV that its on by entering it in your self ,(notice the pic.2 Ive selected NO on right side ) you have to use the Volume /Enter keys to make the change,and you probably already learned that you have to highlite each move your at that your changing.Mitsubishi 5051 - d116022.jpg9f9fa1f.jpg
Posted on May 26, 2008
NO VIDEO OR AUDIO ON ANY INPUT, BUT HAS MENU DISPLAY
If you try to change the chanel on the remote and you don't get snow, then your set is in home theater mode and stuck on EXT-1 input.
You will have to get into the menu under advanced settings and turn off Home Theater.
Hope this helps.
Thanks for using FixYa
Mar 02, 2011 | Mitsubishi VS-50609 50" Rear Projection...
Tip
Mitsubishi parental lock removal/v-lock redo
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
on May 16, 2010 | Audio Players & Recorders
My mitsubishi tv ws48613 has no audio or vidio. menu screen only and will not except channel memory
It sounds to me like your set is stuck in home theater mode.
You will need to pull up the menu and select advanced in the next menu, then navigate to home theater and turn it off.
The home theater mode fixes your Television to input one or Aux 1.
If you need any further help please reply to this post.
I hope that this helps you with this issue.
Thanks for using Fixya.
asnowman
Mar 22, 2010 | Mitsubishi WS-48613 48" Rear Projection...
I have sound but no video. Onscreen menu okay Any idea what can be causing problem.
It sound to me like your set is stuck in home theater mode.
Thanks for usning Fixya.
asnowman
Oct 19, 2009 | Mitsubishi WS-65411 65" Rear Projection...
Can't get it back to tv input - tv connected to 2 direct tv satellites. changed input to dvd mode and now tv mode won't come back up. went to menu to change input and still cannot get tv to come up
You set may be set to Home Theater mode.
I think it is in the advanced menu.
Set home theater to off. This will fix the input on the television to input one, no matter what you do.
I hope that this helps you.
asnowman
Oct 01, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Power light is on, menu info shows on screen, but no picture. Satellite does not show picture and DVD player does not show picture. Both are hooked through Bose home theater which seems to be working.
You should be able to use the device button on the remote control. If this does not work, try going into the menu and disable the home theater mode. The home theater mode locks the TV to input 1. I believe that it is in the advanced menu from the main menu.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Aug 16, 2009 | Mitsubishi WS-65511 65" Rear Projection...
I had to unplug my cable/tv last night and when I turned it on this morning I could not get the menu to display the cable accept on the menu screen. I went in to turn off the home theater and the cable...
Push the menu button and enter 1370 and push enter and the tv picture will appear on the screen. If it does not push the input button until the picture appears.
Jul 28, 2009 | Televison & Video
Mitsubishi CS-26201. Can't get clear image on screen
Hopefully you still have the remote.
On Remote, hold the Q.V. button down and press the number 9. That will bypass the lock
Then press the menu button on the remote - go to Advanced features, select Parental Lock - it should sho as on, hold the Q.V. button doown and press the 9 button again, and you will turn the lock off
Dec 31, 2008 | Mitsubishi CS-26201 TV
Input problem
your tv is set to "Home Theater mode" . Use "menu" key on your remote, go to "advanced feature", then go to "use home theater" then hit "cancel" to return to standard mode. If this does not work try unplugging the tv for 4 hours to return to factory default settings
Nov 07, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Televison & Video Logo
121 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
