Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Water will not suck back up
I have a powersteamer and tried to use it the other day, and it does not seem to be working properly. I depress the handle lever and soap comes out, but at the end the the "strip" I am cleaning, a jelly like blog is spit out on the floor. Then, when I try to pull the machine back to suck up the water, nothing gets taken back up in to the return tank. Any suggestions would be appreciated.
The unit pushes out water ok but there is no suction. What am I missing here.
Thanks
Oly
    New Friend:
  • 136 Answers
Try vacuming the water up w/out adding water our anything else to the machine
Posted on Mar 17, 2008
My Pro heat 2x by Bissell does not put out or **** up water Brand is Bissell. Model is 8920 12 amp
Please check the following with liquid in both tanks.
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
If these suggestions do not resolve the issue contact BISSELL Consumer Services at...
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Aug 15, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell powersteamer model 1693 not sucking up water
I have the bissel power steamer / powerbrush # on front at bottom 310-3150 bought in october used it 2 times 3rd time it started acting up as follows
cleaned all parts. the spin dial wont spin. the switches on both steamer and hand wand won't spray. Sometimes works then stops. Water comes out the bottom when sitting. All parts look fine no damages.
Jan 10, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
I have a Bissell Powersteamer & it won't throw out the water.
You can test the trigger to see if that is the problem. Take the two handle bolts out, gently pull back on the tool rack and slide the handle up off the unit. If you look down inside of the unit where the handle was you can see the valve that the handle used to actuate. You can turn on the unit and manually activate the valve with a long screwdriver. If it starts working then you know it was the upper handle.
Does it spray out the tools? If it does then you have a clogged heater. It is located in the lower handle and can be taken apart and cleaned out.
Good Luck
Nov 25, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
could be a few things.. take the lid off the tank and try spray.
did you fill the bladder and not the outer tank.. rubber on bottom of tank still there.. releases fluid it you depress the x shape center..
hot water. prime from hose without a tool on it by holding the hose lower than the tank.. put in on a work bench.. hold spray trigger and turn on machine.... read my other posts as well
Oct 23, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
I THINK THE SMART MIX PISTON IS INSTALLEDS WRONG
it has the rubber seal and the container releases fluid when it depressed.... bipolar lol..
fill it with hot water and prime the machine.. don't use soap just try lear the lines.. always run hot water through your machine to clear the lines before storage.. and to maintain prime
Oct 16, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
BISSELL 1699 :WATER PUMPS THRU HOSE BUT NOT TO FLOOR NOZZLES
Did you blew thru the heater with both hoses off of it? If you did and it was clear, could be the pump, it is just working weakly. Is the top cover flush with the base in the back? If it has broken loose and has risen up, then it won't work. Here is a diagram that may help:
Aug 02, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Either the tank isn't sitting square, or there is a oblong seal that should be on the top of the clear window, it seals the top to the edge of the tank. If missing, it won't suck up water. Also sound like it nees to be cleaned out, run a solution of water and vinegar thru it to clean out the lines.
Mar 02, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell proheat 1698 cleaner not spraying water
MY CARPET CLEANER WAS NOT SPRAYING ANY WATER OR CLEANING SOLUTION. I TOOK THE BACK OFF OF THE HEATER THAT IS IN THE HANDLE. IT WAS CLOGGED WITH CALCIUM DEPOSITS. I CLEANED THE HEATER AND PUT IT BACK TOGETHER AND IT WORKS GREAT. KEN
Feb 25, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
183 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
