Honda 8 HP Engine Logo
Anonymous Posted on Apr 08, 2010
Engine wont stay running unless i put my hand over carb then it stay runnin cleaned carb gas is flowing fine engine is on a morta mixer
  • Anonymous Apr 08, 2010
    yes there is a choke i have to keep my hand over carb so it gets very little air then it stays runnin
  • Anonymous May 11, 2010
    Is there no choke?
Kelly
Level 3:
  • Master 3,740 Answers
  • Posted on Apr 10, 2010
Kelly
Master
Level 3:
Answers
3740
Questions
Helped
2163389
Points
12091
Hi and welcome to FixYa. I am Kelly.
When you said you cleaned the carb did your remove the float bowl?
Here is what you need to do:
1. Fuel selector off
2. Remove float bowl mounting screws and nut
3. Remove the BRASS Jet / Orifice in the very bottom of the venturi tube inside the pickup tube. (Flat blade screwdriver) Hold the Orifice up to the light. You should see a pinhole. If it not clear clean the orifice but do not force anything through the hole.
4. Underneath the Orifice there is yet another BRASS tube that you need to remove. (Flat blade screwdriver) Make sure all of the holes in the tube are clear. The tube will be over 2 inches long. Clean it and reinstall it.
5. Reinstall the Orifice.
6. Using a catch fuel container turn on the fuel selector. Fuel should flow at a good rate. GENTLY lift the float assy level and make sure fuel flow shuts off. When you drop the float again fuel should flow.
If you do not have fuel flow at this point the needle and seat will need to be inspected. Fuel selector OFF.
(The following procedure is to be done only if there is no fuel flow with fuel selector on.)
a. Remove the silver float pivot pin retaining screw
b. Drop the Float down (The needle will come off with the float. NOTE the position)
c. Inspect the tapered rubber of the needle If should be pointed. If it is not pointed then the rubber tip is stuck inside the seat.
d. Clean the seat hole ONLY if obstructed. (Easily damaged)
e. FUEL Selector on then off fuel should rapidly flow through the needle seat.
f. Renistall Float and needle making sure to get the pivot / hinge pin installed correctly and reinstall the silver retaining screw.
g. Fuel selector ON. Raise and lower float checking for free movement and fuel flow.
7. If there sitll is not fuel flow at this point remove the fuel hose from the carb and check fuel flow. If no flow check that gas tank exit hole, fuel filter (if installed) and the selector valve assy for obstructions. Reassemble connections.
FUEL FLOW IS GOOD
8. BEFORE you install the float bowl inspect the bow nut. There are 2 holes in the side of the nut where it screws in to the bottom of the carb that must be clear.
9. Install Float bowl mounting screws and nut. Check for leaks.
10. Test engine.
That should do it. (Honda carb cleaning 101)
Thanks for using FixYa.
Kelly
Yamaha golf cart 1996 ulima g14ap engine jn3 200191 start but wont stay running put a new fuel pump on still wont stay running y
Have you cleaned the carb? Many times if they sit up with this ethenal gas it eats the seats an causes a gell to form in the carb bowl. I would check an clean carb first with new gas.
Jun 01, 2017 • Golf
2answers
2003 volvo s40
worn fuel pump / low fuel pressure / engine management fault ?
My honda gx160 5.5 hp will only stay running if i slowly pour gas into the carb. Carb was rebuilt motor running fine last week. Put away and now wont stay running.
here is your problem,first shut off the fuel valve right underneath there is a small settlement cup that can be removed with a 10 mm wrench,once removed reopen the valve just to see if gas is flowing if not your strainer in fuel tank is clogged and can be cleaned.if you do then shut fuel valve off and remove the fuel bowl using the same wrench inside the stem there are two parts the jet and the tube,both need to be cleaned use a small screwdriver to remove the jet the tube may be stuck so maybe a small wood screw can help you remove it
I have a suzuki samurai that my grandfather gave me and he wants to keep it in the family. its a 85 and the it wont stay runnin. to keep it runnin u have to pumpin the gas or put gas in the carb. any...
all engines.
good compression
good spark , strong to all 4 cylinder, and timed by the fsm need a free fsm see links.
last is fueling if above is good ,now a carb can begin to work right.
if not flooding, (is it) then its starving.
ill pretend starving.....
1: fuel pressure at spec.
2: float level at spec.
there are 50 more carb checks but Ill stop here.
now the link to a real fsm. for free.
http://www.acksfaq.com/fsm.htm
I got a1985 ford f250 with a 460 it will run for 30 secs and die I change everything to do with the ignition system and fuel system and still wont stay runnin
put so sea foam in carb let it sit over night start next morning should run fine it cleans out the carb get sea form at auto store runs about 10.99 a bottle just fill carb let sit
3helpful
2answers
2002 Honda SHADOW SABRE It wont stay running unless it's
More information is needed - aftermarket pipes? any carb work been done to it? is fuel fresh? air filter condition? how are the plugs burning? oily black, white/tan?
My pit bike wont stay runnin
sounds like your carb could be blocked with dirt if it wont start unless you put juice down plug i would take the carb off and give it a good clean and also make sure the jets ok just clean them with carb cleaner and a paper clip
My 2008 kfx450r wont stay running. when i finally get it started i can pin the throttle wide open for a few seconds but it dies like its not getting fuel please help any info i will take
ALWAYS have a fire extinguisher on hand when working on carburetors.
Open the petcock, (gas valve), and drain 1/2 cup of gas from the tank. Did the fuel flow freely? Is there any water or trash in the cup?
Drain the carburetor. There should be a screw on the lower right side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Check the float height. The fuel level in the bowl may be low. Bend the tang (in the center of the float) downward to raise the fuel level. EASY, a little bend goes along way.
Put the carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine.
Top Honda Garden Experts
Sean Wright
Sean Wright
john h
Jesse Walters
Jesse Walters
Are you a Honda Garden Expert? Answer questions, earn points and help others
