I am using the above mentioned Number pad and yesterday it refused to work. I shows that Numlock is on, but I cannot get any numbers typed on it. Can you please help. I misplaced my CD I got with it when I bought it.
Regards
Lenata Kemp
email: [email protected]
I bought this number pad and had the same problems.
I found this fix. download this from the labtec site. http://www.labtec.com/pub/techsupport/keyboards/usb_numpad_for_notebooks_1.0v.exe This worked and the number lock off changed from grey, number lock off to, yellow number lock on and back again.
This appears to be a later driver update.
Thanks ian0507 my Labtec numberpad now works if I put numberlock on - on my laptop. I used to have this probelm if I plugged it into a different port on my other laptop. The number lock still shows, but at least the numbers now work.
I'm trying to use this number pad with my laptop and i can not get any numbers to work. I only get the directional functions and the perimeter key functions. What do i need to do?
I installed the software and it worked perfectly for about half a day, then the same problem as described. Strangely, if I plug the device into a non laptop computer it works immediately, without installing the software. I removed the software from the laptop and tried again. Now if I switch the laptop based numlock on then the keyboard works, but the Labtec keyboard num lock key still does not work.
Same problem, keypad arrows work, no numbers working!
I cannot get the numbers on the number pad to work and I cannot change the num lock status on the laptop or using the Labtec
I cant get my numberpad to wright anything . Numlock also fine and just cant and wont work at all.
My Labtec number pad only works when the laptop's NumLock key is pressed - but that then also invoks the embedded number pad in the laptop's own keyboard, which rather defeats the purpose. Anyone know how to get around this?
I am using the above mentioned Number pad and it refused to work. I shows that Numlock is on, but I cannot get any numbers typed on it, although the direction arrows and the symbols work. Can you please help, i am getting very frustrated
When I type on the number pad if i type one number three numbers come up. How can I stop this?
