Motorola Mobility MOTOROKR Z6 Cell Phone Logo
Posted on Feb 01, 2018
No service keeps coming up after network search on motorola z6
My motorola z6 was working fine until i removed the sim card, i put a sim back and and after searching for network, the keeps saying no service, it does not matter what sim i used...it just keeps saying no service, and its a unlocked phone.. can anyone help me plz, i need the phone for business
2helpful
2answers
Sim Network Unlock Pin for Motorola Moto G6 XT1925? Where do i find that
You can find Sim Network Unlock Pin for Motorola Moto G6 XT1925 from any unlock codes provider or from your sim card provider. It is the default code; restriction for a single network from the provider which occurs when you insert different sim card. It can be remove permanently. Some unlockers are also providing some type of cable unlocking solution for Motorola XT1925 Sim Network Unlock Pin & it works as well. Do some research on this or go to the below website https://24x7unlockcodes.com/product/motorola-network-unlock-code-through-cable-unlocking
24x7UnlockCode Network Unlock Code IMEI Unlock Code Unlock Code
Phone will not accept sim card
There are two possibilities to get this type of issue.
1.There may be a problem in your Sim card so try another one.
2.Your mobile is locked to particular network provider.
If your problem persists after trying another sim card means definitely your phone is locked by some network.So try to unlock your phone.For unlocking you can approach your service provider or else try to buy an unlocking service from any one of the online unlocking service provider like TheUnlockArena.com Here you can unlock your phone at low cost.
Forgot my unlock code on my Motorola rokr z6
When you receive your email with your unique Motorola unlocking codes, you may see there's actually more than one code as some models require more than one code to unlock them fully. However, for simplicity, we do aim to send you a single unlock code.
Example:
359810001112345 F33RHE1234 12345678 85901234 5F8D1234
The unlocking code is 3rd part in this example: 12345678.
(We may also return your IMEI number, simply ignore this, it will always be the first)
Motorola Models
1. Switch On your phone with a SIM Card not from the original network. (IE Not the network it's locked to)
2. The phone should now show the message 'Enter Special Code' or 'Enter subsidy code'
3. You can now enter the Unlocking Code provided to unlock the phone.
WARNING : If One of these messages is displayed:
- 'Contact Service Provider'
- 'Tamper Alert'
- 'Wait before enter special Code'
- 'Contact Service'
It's because too many incorrect codes have been entered. To reset this, you will need to leave the phone on displaying this error message, until it changes to 'Enter Code Special' or 'Enter subsidy code'. This can take up to 72 hours.
Note: If your phone is on a 'Three' network, you will need to enter * * 0 5 7 * to open another window to enter your code.
1helpful
Network signal
Does the SIM card being used belong to the carrier you're on? If not, then in order to use that SIM card in that phone, the phone would have to be unlocked first.
I bought a Motorola ATRIX 4G a few days ago and it has been working fine until today. It died and after I charged it and turned it on I got a message that said "Sim not provisioned MM #2". I...
Try changing the sim card. The sim card might be faulty since the new 4G phones use the micro sim cards or the newer versions of the sim cards. Try a new sim card and that should work.
Aug 26, 2011 • Cell Phones
My phone says it has no service and no network... motorola v9
Hello
The problem you are experiencing might be due to a lot of reasons.
1. Try to remove your sim card and test it on another phone and see if it works properly,if it works fine then the phone and the simcard might not be compartible.
2. You could also move around or maybe go out to another environment and check if it sees service.
3.You could also put of your phone, remove your simcard and clean it with a clean cloth gently and fix it back.
4. After all these measures and you cant still get network then you would have to contact your service provider because the problem might also be from them.
BEST OF LUCL
Hi my phone has had no service for the past 5 days when it searches for a network it says that "no network operator found" but it can't be the sim card because it works fine in my old nokia 6300 Does...
Try upgrading the Symbian System with Nokia PC Suite. Try multiple sim cards.
If it still doenst work...
-The Sim Card might be damaged or incompatible with the phone.
-The Sim Card reader in the phone could be defective.
-The Phones Signal part could be defective too.
1helpful
MOTOROLA NO SERVICE
alot of guys that sell "unlocked " phones sell a regular network-specific phone but they'll include a universal unlock wafer-thin sim that fits in your phone between your sim card and the phone contacts. Look in the box ..if you still got it look for a plastic sd card sized container and see if there's one with you phone... if not you can get one on ebay for about ten bucks..
let me know what happens... KEN
Sim card
Hi.. I got moto V 3 from usa ( tmobile ) ..
Now I am in jordan & its dosnt work here .. need a cod for GSM network...
How could I do it ...?
Thanks
MOTOROLA A1200...NEW...SAYS "EMERGENCY ONLY"
1- select your network manual in your handset
2-try another sim card ,so that your either there is problem in your sim card
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
