Question about Hitachi Travelstar 5K100 HTS541060G9SA00 60GB 5400rpm 150MBps Serial ATA Serial ATA/150 I... (0A26923FT) Hard Drive
500 GB External Hard Drive Hitachi
Bleebs when i plug in and does not start up.
  • Palmbeach
    Palmbeach May 11, 2010
    Have you successfully used the external drive before?
    What are you using it with?
    Problem Solver:
  • 15 Answers
Operating System? Computer specs?
I'm afraid we need some info before we can help.
Posted on Mar 17, 2008
6ya staff
SOURCE:
Ring 01440 268162 as easier for me to understand just got second hand scooter from private seller all electrics work and looks nearly new prob is I drive it for bout 15mins then it bleebs 3 times every...
It sounds like the coil is overheating, check for spark when this happens. When the engine first shuts off pull coil wire and insert a Phillips head screwdriver in wire then hold it 1/2 inch from a cylinder head bolt. There should be a blue spark, if it is yellow or not sparking then the coil is faulty.
May 29, 2014 | Cars & Trucks
Doesn't start has spark @ plug fuel @
try starting meaning pull the rope 6 times and then check the spark plug if its wet clean it or try a new plug, if its dry your not getting fuel in the cylinder which means carb problems. if you have a seringe or something to put some gas into the spark plug hole then install spark plug and try it. if it runs for a couple of seconds then you need to focus on the carb. only put a small amount of fuel in the plug hole if you try it otherwise youll be pulling on the rope for awhile before it will start. hope this helps.
Jul 06, 2011 | Echo CS400 18" Chain Saw
2004 landcrusier 100 series. glow plug light stays on all the time, although the glow plugs are not being supplied power. starts and runs ok.
THIS COMES ALL FROM "WAIT TO START" DO YOU WAIT TO START? IF NOT,THEN THE GLOW PLUGS ARE BUR'NT OUT,WHICH YOU WILL NOT NEED UNTIL FALL. OR MAYBE YOU'VE GOT IT HOOKED ON EITHER,STARTING FLUID,IN WHICH CASE,I SUGGEST YOU REPLACE THOSE GLOW PLUGS NOW.OR ELSE YOU'RE MOVING ON TO EVEN WORSE ISSUES.LET ME ASK YOU THIS,WHY ARE'NT THE GLOW PLUGS BEING DENIED POWER? AFTER ALL THEY START THE ENGINE? AFTER YOU INSERT THE KEY INTO THE SWITCH,WAIT TO START,LIGHTS UP.IF YOU'VE NOT WAITED UNTIL THAT WAIT TO START LIGHT GOES OFF,,,YOU'VE BURNT THE GLOW PLUGS UP.THE ONLY THING TO DO IS REPLACE THEM ALL.IF YOU'VE BEEN USING STARTING FLUID OR EITHER TO START YOUR ENGINE FOR A LONG PERIOD OF TIME,FORGET REPLACING THE GLOW PLUGS,BECAUSE YOUR ENGINE IS ADDICTED TO THE BOTTLE(EITHER) YOU MAY BE ONE OF THE LUCKY ONES,REPLACING THE GLOW PLUGS MAY RESOLVE YOUR ISSUES.BUT,WAIT TO START,,AIN'T NO JOKE. BEST OF LUCK TO YOU & YOURS!
Apr 08, 2011 | 2004 Toyota Land Cruiser
When i press the button the green light comes on then the light turns orange then bleebs and flashes red. whats happening can u help
Hi, its not good news im afraid the reason it shuts down and gives you a ref light is due to damage being done to the circuit board inside the ps3.
it could be that it has over heated which is often the case this could be down to dust build up or if the heat sink paste on the gpu and cpu chip has gone brittle or if you have been using the ps3 on carpet or in top of anything else that gives off heat such as dvd or sky box, these cause it to over heat really quick.
right now you have a couple of options if you have any warranty left take it back and get a refund if your warranty has run out then you could try getting it repaired but their is no guarantee the repair will work or how long it will work after the reapir.
as you have got the red light this does mean the console has over heated and their is a fault with the board so its not going to work again the way it is.
now i repair these for 25 quid plus parts so you need to look around if you want it repaired and see what the best price you can get.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
z9
Oct 01, 2010 | Sony Playstation 3 (PS3) Console
Car wont stART.TURNSOVER BUT WONT start
Pull a spark plug after trying to start it, and sniff the plug. If it smells like gas, you are getting fuel. Then check for spark. First leave the gas to dry off the plug. Then with heavy gloves on, or holding the metal body of the plug to the engine block with it plugged into the plug wire, have someone crank it while you look for a bright bluish spark between the electrodes on the plug. If nothing, your problem is ignition rather than fuel. Good luck. Again, make sure the gas has dried from the plug before you try this, and make sure to hold the plug and wire with something insulated. It will give you a serious shock if you don't!
Nov 14, 2009 | 1990 Honda CRX
Won't start
I have the same model chainsaw, and sometimes it's very difficult to start. If you pull the plug and it's wet, with the plug still out pull the starter rope about ten times to clear out the excess gas. Dry the plug and put it back in and try to start it with the choke off. If it fires up, be ready to put the choke on if it starts. I forgot to mention that before starting you should pull in the trigger, push down the button on top of the handle, and hold it down while releasing the trigger. This sets the trigger so that it is on slightly. If it doesn't start, pull in the trigger and give it a few pulls that way. If it doesn't start, pull the plug again and see if it is wet. If it's dry, put the choke on and try to start it. If it still doesn't start, pull the plug, pour a few drops of gas in through the plug hole, replace the plug and try to start it with the choke on. If it still won't start, get a Stihl chainsaw.
Jul 15, 2009 | Garden
Laptop will not boot and screen is blank
3 beeps means the RAM or memmory problem, check it by yourself or consult to a technician.
Dec 17, 2008 | Computers & Internet
Matsui dishwasher mf160
I used the solution I found for a slightly different fault, ( this was the same fault but without the bleebs)
switch off mains and turn off water. Then disconnect water pipe and lay machine on it's back. Switch on electrics, and allow water to run out. Switch off electrics and stand machine up .Reconnect everything and hey presto I can hear two good things, the machine gently humming, and my wife telling me what a genius I am !!
Aug 05, 2008 | Electronics - Others
Bosch wff 2000 washing machine - won't spin/drain
How did you solve this problem. I have the same problem. Kiran
Mar 09, 2008 | Washing Machines
Open Questions:
Computers & Internet Logo
181 people viewed this question
Top Hitachi Computers & Internet Experts
Ekse
Alun Cox
Marvin
Marvin
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
