Question about Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens
Canon E0S 400D locks up
My new Canon EOS 400D doesn't complete the picture cycle when the shutter release is pressed. When I switch it on everything looks fine. The display on the LCD is fine and reports whatever program I have it on. However as soon as I take a picture the camera lock up - at this point the LCD goes black and I cant even power the camera off. The only way to reset it is to take the battery out and put it back in again. On replacing the battery in the camera the proccess completes and the camera is returned to its normal mode only to lock up again if the shutter release is pressed. I have tried with and without the CF card and on every program.
Any help appreciated.
  • sameg Mar 17, 2008
    Yes, bought from Canon Outlet on ebay - still under warranty. They will refund the money. Question is do I buy another 400D or look at something else.
    President:
  • 4,402 Answers
Is it still in warranty? send it back to cannon, there is a problem with this model doing that.
Posted on Mar 17, 2008
Why do i have to click the button twice to take a picture, with my canon 1000d
Possibly shutter failure, possibly bad release switch, possibly bad motor board
Mar 18, 2013 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS 400D Flash Problem
yes..that's a twitchy button all right..can you inspect it to see if there's any accumulated dirt/grease can cause it to actually 'stick'
Mar 29, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
How to release a stuck sutter on canon 400d
Wow, four days ago.
I would think that the camera has dropped the shutter by now.
There is a mode in the camera that holds the mirror up out of the way for sensor cleaning but this is defaulted as soon as the power is shut off and then turned back on again.
Or the camera was set in manual mode "Bulb" and is waiting for the next command from the photographer to "drop" the shutter "takes a second press of the shutter button.
The lens may be loose (unlocked) and giving a bad command to the camera.
The Canon 40D has a shutter capable of 60,000 actuation so if you are close to this I'd say the shutter has been shot out of it.
Also sometimes the shutter release button sticks and gives the feeling or appearance of a stuck shutter.
Shutter switch also known as a release button have been an issue sometimes where dirt and oil from a person hands get down into the button.
To release shut the camera off, take the battery out, remove and reinstall the lens, shift the taking mode to "P" program or full automatic green box.
Apr 29, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
I'm having problems with the settings on my Canon EOS 400D. When I take pictures in AV mode I can get quality pictures but in TV or M modes the pictures always come out so dark even when taking them...
You need to understand the relationship and teractivity of aperture, shutter speed and iso. In Av mod, you choose the aperture and the camera makes thw shutter speed agjustment, In Tv mode, you set the shutter speed and the camera makes the aperture adjustment, In manual, you have to set both shutter speed and aperture manually. If the ISO mode is set to AUTO, the camera chooses the sensors sensitivity to light automatically. Change to specific ISO
(200-400 for daylight and 799-1600 for night). Take a picture in AV mode and note what shutter speed the camera chose. Then switch to TC mode choose the same shutter speed and see if camera chose the same aperture(f-stop) you chose in first shot. Change to Manual and choose same f-stop and shutter speed the camera chose for you in the other modes. Compare all three photos. They should be almost if not exactly the same exposure wise.
In Tv mode choose a dlowers shutter speed, In Manual choose a combo of slower shuuter and wider f-stop(smaller number). Read your manual.
Jan 02, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
How do I use my time-lapse function, Does my camera have one?
There is no tme lapse function on the 400d however a search on ebay can come up with some 3rd party electronic shutter releases which have time lapse function fitted.Most are from Hong Kong but dont be put off I have bought lots of theses 3rd party accessories (battery grips, off camera flash cords,remote shutter releases etc) and all work faultlessly. Here is one of many.I do not own this one personally but I have several items by the "Yongnuo" company and they are great.
http://cgi.ebay.co.uk/Timer-Remote-Shutter-For-Canon-EOS-350D-300D-400D-450D_W0QQitemZ280404021729QQcmdZViewItemQQptZUK_Photography_DigitalCamAccess_RL?hash=item414961d1e1&_trksid=p3286.c0.m14
Oct 07, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Take picture 3/4 of frame is black
Take the lens off the camera and look through the lens. Is there anything obstructing the light?
Now have a look inside the camera body. Same thing, anything there that looks like it shouldn't be? If look up into the cavity you should be able to see the focussing scren clearly - any obstructions there?
Finally, with the lens off, switch on the camera and go through the menu until you find the sensor cleaning option. Select this. The internal shutter will open and allow you to see the CCD sensor. Have a look and make sure it is also free from obstruction.
You will need to switch the camera off to release the shutter.
Put everything back together and check the pictures again.
If still no joy, then it sounds like the CCD sensor is faulty and the camera needs a repair from an authorised Canon repair centre.
Jan 14, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
My new 400D with kit lens produces dark pictures. I tried everyth
take it back and get it replaced sound like your shutter Assembly went out.
Jan 06, 2009 | Canon Digital Rebel / EOS-300D Digital...
Canon EOS Rebel problem
This is usually caused by a defective shutter release switch - it'll have to go into a repair shop - independent shops will charge about $110 USD - Canon charges about $180
Nov 26, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Error code 99 canon E0S 450D
Try this:
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Jun 14, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens Logo
229 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
