Question about Sony Mavica MVC-FD100 Digital Camera
SHOWING A YELLOW LIGHT BUT NOT CHARGING
MY MAVICA IS NOT CHARGING AND NOT WORKING EVEN WHEN I PLUG IT WITH THE ADAPTER. I DON'T KNOW IF THE BATTERY IS BAD OR IF IS BECAUSE I OVER CHARGED IT. IT SHOWS A YELLOW LIGHT ONCE IS PLUNGED.
  • present0077 Jul 07, 2008
    i charge it for hours on end the yellow light is on showin its charging but when I go to turn it on it won't come on the light flashes green and goes out immediately. I tried to charge it thats all and start it wit the cord in to no avail
The circuit board has had it, its the L shaped flat board under the main ali floppy body and has 4 connection leads to it(2 at the top and 2 at the bottom)
its possible to swap from another broken camera ??
Sony will probably charge over £100 !!
Posted on Oct 13, 2008
Sony FD mavica will not run on charged battery, will run plugged in to charger
You either have:
1) a false positive on your battery, meaning that they aren't really charged even though they say they are (especially common the older a battery gets), or
2) the battery connection is faulty/dirty, while the AC adapter is fine. If the AC adapter uses the battery port, then the battery is your problem.
Nov 09, 2012 | Cameras
Sir i have problem in hp charger or battery i don't know but when i charge my laptop at that time yellow light beside laptop which shows charging but after some time it is just simply plugged in a
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Oct 25, 2012 | HP Computers & Internet
Orange battery light comes on and the computer says low battery. Computer does not work even when plugged in to wall outlet. I don't think it is the adapter because blue ring on plug in to the com
Diagonizing and analysing this problem, it's obvious that the orange light means battery low.
Have u ever tried charging the laptop with another charger/adapter?
If no try it because some adapters/chargers don't work with some laptops. Also be careful to use the recommended adapter, some can spoil the laptop's panel.
Jul 23, 2012 | Dell Studio 15 Laptop
Sony Mavica MVC-CD400 will not operate under battery power.
Try cleaning the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol.
Aug 31, 2009 | Sony Mavica MVC-CD400 Digital Camera
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
For laptop: Toshiba Satellite A105: My battery won't charge/computer won't turn on when plugged in. No lights show when plugged in. Don't know if it's a problem with the chord or the computer. Don't want...
Start by trying another power outlet.
The power adapter should have its own light. If it doesn't light up then the adaper is bad. Kensington.com sells very inexpensive universal power adapters. You might also find a good deal on eBay.
If the adapter lights up then it may be your battery. Notebook batteries are only good for 2-3 years. If you let them sit for a long time without a charge they may only last 1-2 years.
Vote for this solution if it helps.
Aug 18, 2009 | Toshiba Satellite A105 Notebook
My sony mavica mvc-fd81 turns on for only seconds,and turns off.
Have you tried another battery?
Even the lithium ions will eventually not hold a re-charge.
If the unit stays on with external power, there is a good possibility that a new battery will solve the issue
Jan 02, 2009 | Sony Mavica MVC-FD85 Digital Camera
The battery light is amber when the adapter is plugged in.
Sorry to be the bearer of bad news here but the amber or yellow light means 1 of 2 things. The battery is bad or the battery charging circuit on the motherboard is bad. Normally it is the battery and replacement would need to be purchased.
Dec 20, 2008 | Dell Latitude D600 Notebook
Mavica fd 83 with batterytroubles
Hi,please ask Fixya for the site of WELCOMEJEE,I have similer problems with my 83,mine shows full charge at times ,and low battery and shuts down at other times.
He says that it could be a Battery Fault,even if it shows Full Charge as batteries can be Faulty,please ask Fixya about WELCOMEJEE,regards,Walt.(rtd.)
Sep 13, 2005 | Sony Mavica MVC-FD83 Digital Camera
Sony Mavica MVC-FD100 Digital Camera Logo
124 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
