Question about Dell E173FPb 17" TFT LCD Monitor
Dell Monitor Repair
If this works it would be awesome. Sadly, when I searched and called digikey they need more information about this part. Can you provide more detail about the capacitor?
Thanks!
Blair
bcalski@rcn.com
  • bcalski Jun 14, 2009
    I sent the board to a repair shop I fooun on EBay and the repaired the board at a rsonable price.
    THanks!!
  • 105 Answers
These models are prone to shorting of the inverter drive transistors, 2sc5707. An in-circuit ohm meter test will reveal which are shorted if any. They should be replaced in pairs even if only one is shorted. Bad solder joints on the transformer can cause them to short so look for bad solder.
Monitor Mike
Posted on Oct 02, 2008
    Problem Solver:
  • 6 Answers
Hi there, this is a late reply, sorry, but you just need an electrolytic capacitor. Any voltage above 16V should do, but try to make sure you get the right capacitance...
Good luck.
K.
Posted on Sep 21, 2008
Monitor will not stay on
This is a very common symptom of a failure in the power supply board. These boards have parts called filter capacitors that will begin to have problems after a few years of use. When they start to go out the monitor will have problems powering up or it may have a wavy picture. It is easy to repair the power supply board and get the monitor back up and running. To repair the board you just need to replace the capacitors and it should be as good as new. Here is a link to information on which capacitors need to be replaced. The link shows a Dell 1907FP but they both use the same power supply board so the information will be the same.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_29&products_id=236
I hope this helps,
BuddyMc
Sep 18, 2012 | Dell 1905FP 19 Inch LCD Monitor - SXGA...
Dell Monitor - Model # E173FPT: Power light is on, however monitor screen black. No internal light from the rear panel
You have a failure of the power supply board. The problem is caused by parts called capacitors that have shorted and this causes the backlight circuit to stop working. Here is a link to a page that show how to repair the power supply board and get the monitor back going again.
http://www.ccl-la.com/blog/index.php/category/monitor-repair/dell-monitor-repair/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 21, 2011 | Dell E173FP 17" LCD Monitor
Dell UltraSharp 1504FP Monitor Need driver
If you are looking for Windows 7 driver, Dell does not have it because it is 2002 monitor
Latest driver is 2002:
http://search.dell.com/results.aspx?c=us&l=en&s=gen&cat=sup&k=1504FP&rpp=12&p=1&subcat=dyd&rf=all&nk=f&sort=K&ira=False&~srd=False&ipsys=False&advsrch=False&~ck=anav
What OS are you running?
If you are running XP, you do not need the driver.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 24, 2010 | Dell UltraSharp 1504FP Monitor
Power button not working. Stuck in on position. How do I replace it?
warc619, Maybe the "button" is only thing broken. Maybe the "switch" is broken. Yoyu will need to see if you can view some video clips of monitor disassembly and repair at YOUTUBE first. Then you will need to "teardown" your unit and determine exactly what component(s) have failed and if you can get new exact same size unit from "Digikey" or "Radio Shack" or "Mouser".... WOW! you may even need to learn how to carefully desolder the bad switch and solder in the new one. Good luck with the repair. You didn't tell us what type of monitor you own!! CRT or CCFL back-lit LCD???? 12fixlouie
Jun 27, 2010 | Dell Computers & Internet
Found problem but need to know capasitor
Check this page on our web site at: http://www.ccl-la.com/blog/index.php/category/monitor-repair/dell-monitor-repair/ We have repair guides for all three versions of the Dell E173 monitors. If you need any additional information just let us know.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Apr 27, 2010 | Dell E173FP 17" LCD Monitor
Dell E173FPc monitor worked fine yesterday. Today, the monitor only stays on for a split second and goes blank. The power light stays green. If we shut off the monitor using the power button and wait 10 to...
The power supply in the unit has died. This is a very common problem with this series of monitor after 2-3 years of use. If you can solder then you should be able to do the repair yourself. Check out our step by step repair guide posted on our site at: www.ccl-la.com Our guide gives parts values and location information as well as how to open the unit up. If you don't feel like doing the repair we also offer repair services, see our web site for details.
Buddy
Corporate Computer
www.ccl-la.com
Dec 31, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
My viewsonic va1912wb just flat-out died. Won't turn on, no lights, no response. Is there a likely cause, and is there anything user-repairable?
You have monitor with a very common problem, a dead power supply. After 2-3 years many LCD monitor power supplies will fail just like you have described. The problem is caused by parts called capacitors overheating in the tight space of the monitor case. If you can solder then you should be able to do the repair yourself. We will have a repair guide posted 12/29 after about 5:00 central time that should get you back going again. The repair guide will be on our web site at: www.ccl-la.com If you have any questions please let me know at the address below.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 29, 2009 | ViewSonic VA1912wb Monitor
Dell Monitor Problems
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 17, 2009 | Dell E173FP 17" LCD Monitor
Monitor won't turn on
If there is no power indicator to the monitor, then maybe please verify the inside fuse, maybe got busted. else consult the nearest repair center.
melnavz
Dec 15, 2008 | Computers & Internet
Lines on the Screen, shut down and will not turn back on
Hi, the issue may with the LCD panel. I work in DELL and have been getting lot of issues like this. It's called vertical line defects.. You can connect and external monitor and press Fn and F8 to toggle the display over to the Monitor. If the display is fine, replace the LCD screen. If the system is under wrranty, call Dell tech support and get a replacement or else call 800-288-4410 (out of warranty repair) department to send your laptop for repair. If the display is the same on the monitor, then the video card/Motherboard has to be replaced.
If this information is succesfull, then please rate!!
Sep 17, 2008 | Dell Computers & Internet
Dell E173FPb 17" TFT LCD Monitor Logo
180 people viewed this question
Alun Cox
