Sony Playstation 3 (PS3) Console Logo
Posted on Apr 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hooked up BluRay with HDMI cable and I can hear sound but no picture.
Anonymous
Level 2:
New Friend:
  • Expert 76 Answers
  • Posted on Apr 08, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
76
Questions
0
Helped
11851
Points
146
Problem with the cable! try using the same cable HDMI cable for another system i.e dvd player, something that has an HDMI in-port
I have a sanyo DP50740plasma tv a few years old. Last night I got wi fi and hooked up a Samsung blue ray player and the sound quit working. the picture is clear on dish (on HDMI 3) and the blue ray p
What happens when you take the bluray hdmi out? or turn the bluray power off from wall? can you connect audio from bluray with a separate cable? often one device overrides the other. there may be a way of daisy chaining the devices
What are the best settings for the DMP-BDT330 Panasonic Bluray Player
Hello Myles, we recommend you connect the player with a HDMI cable and then set the player's output to 1080p.
Phillips 50pfp5332d/37
take it back and exchange it...then you'll know for sure if they are incompatible or TV is on the fritz or a bad sound system
1helpful
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
I am using a logitech harmony one remote. i have a yamaha rx-v463 hooked up to a phillips hdtv, i am running hdmi from revr to tv. i have cable box hooked upi hdmi to recvr and bluray player hooked up to...
The remote has nothing to do with this.
Get into the manual. Page 14 says Component Video In will go to Component Video Out, not HDMI. No analog-digital video conversion is implied.
The receiver is hooked through my Blue Ray Disc Player via HDMI cables. When watching a movie the sound is way to overbearing on the effects end making it almost impossible to hear any speaking voices. ...
I'm not sure if this will help you but if you can hook your Bluray player directly to TV(HDMI) then out from TV to reciever via HDMI or digital optical, it very well may solve your problem.
No picture
It sounds like the Bluray player may be outputting the signal at a higher resolution than the TV supports. If the Bluray player has a scart or composite connection, connect with those first, and adjust its settings to output a lower resolution. Then reconnect the HDMI. Hope this works for you.
2helpful
I just bought a onkyo hts5200 and I can't seem to get the sound to work with my ps3. Is their any secrets I need to know? I have hooked it up according to their diagram for HDMI AV component hookup. I...
If you are using the hdmi hookup, then you will also need to use either a composite or coaxial cable for the sound. Yes I know this "sounds" crazy, but I had the same problem for both the cable and bluray set ups with this receiver. I thought the hdmi would work for both the picture and sound but for some reason the hdmi only works for the picture with this receiver. I bought mine from Crutchfield and without their tech service I would never have guessed this was the problem. (I never would have purchased this receiver if I knew this was the design problem/issue.) Good quality composite cables for the sound works just fine.
HDMI and or Receiver problem
While Bluray pluged into the TV change the resolution from AUTO to 720P then plug Bluray back to the receiver and see if it solve your problem.
2helpful
Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
