Hi
Thanks for using FixYa. Check the water temperature by using a thermometer inside
the dishwasher to measure the water temp. It should be as close to 125 degree F
to 140 degree F as possible.
This
would have happened as the dishwasher was overloaded with more than prescribed
number of dishes. Check the spray arm and pump cover for splits or leaks. As
the dishwasher is not draining properly, this issue
is related to kinked hoses, knocked out disposer unit (if connected with the
dishwasher drain hose) & clogged drain pump & filter.
Also note that
dishwashers do not drain completely after a finished cycle and this is normal.
Dishwashers are designed to leave some water in the unit to ensure that the
heating element doesn’t overheat. If you suddenly begin to experience a large
amount of water being retained in your dishwasher, you have a problem. Some of
the most common reasons include that the drain hose isn’t working properly, the
drain pump isn’t working correctly, or possibly there is a plumbing problem in
your home’s drain lines. If you have checked the air gap and the drain hose and
can’t locate the problem, then it is an issue with the drain pump of the
dishwasher.
Please do accept the solution if the issue is
resolved or else revert for further assistance.
Thanks
Rylee
As I said First of all please check the Water temperature by using a
thermometer inside the dishwasher to measure the water temp. It should be as
close to 125 degree F to 140 degree F as possible. Now try using the
temperature boost feature if your dishwasher is equipped with this cycle
feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store
your soap in a dry environment and it is not stale and clumping together.
Possibly try a different detergent like a liquid or gel. Also, make sure the
dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with
water up to and around the heating element. If water is more below the heating
element, you may have low water pressure or a problem with the fill valve. Try
& listen if it sounds like it is spraying the water around with enough
pressure.
For low water pressure, try to clean the screen
at the entrance of the fill valve, sometimes the fill valve can fail and not
allow the proper water into the dishwasher and may need to be
replaced. And, check the spray arm and pump cover for splits or leaks. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nope the solution remains the same.
The problem with the dishes not being properly clean is happening on light loads as well as full loads, there are bits of food left on some things.
At the end of the end of the cycle the dishwasher is empty of water but the dishes are not dry.
As we said in the first email our dishwasher is a G575 model not a G656SC does this make a difference
