New build still need help
I have just built a pc using the p4m900t motherboard,its states it has onboard vga/audio but when i connected my monitor (standard medion-med 2724)nothing happended the monitor stayed in standby mode do i need to buy another graphic card or any other items thanks keith
  • keith_nufc9 Mar 18, 2008
    tryed that still no good wud an extra graphics card be the answer thanks keith
    Sergeant:
    Champion:
  • 256 Answers
Check your ram first see if it is fixed properly and change ram slot.
Posted on Mar 17, 2008
6ya staff
SOURCE:
I have a new asus VS197D then when i turn on it said NO VGA DISPLAY
if there is a graphics card in your pc than you should connect VGA cable to graphics card. may be you connected onboard graphics. just check hope that it will help you
Feb 15, 2014 | ASUS Computers & Internet
Audio not work
Suggest download AND install the audio driver.
Need guidance? Post the Windows operating system you are using.
Also; is it an ECS P4M900T-M2 motherboard?
Post in a Comment.
Regards,
joecoolvette
[Driver: Small piece of software that allows the Operating System to communicate with a device.
Device is the audio chipset.
O/S wasn't stated ]
Mar 02, 2013 | EliteGroup ECS P4M900T-M2 Socket 775...
No display
Tell me if you can see anything on the monitor while the pc is booting/starting.Is your monitor connected correctly ?Is your monitor operating well with other PC?
This motherboard you have has an onboard VGA card. Check if you have a PCIex VGA card connected on the motheroard.
In case you have one then deactivate the onboard one through the bios and connect your monitor to the PCIex one.If you dont have an external PCIex card thenGive me more details if you want me to help you.
Sep 04, 2011 | ASUS P5KPL-AM SE Motherboard
P5KPL-AM mb bios only four line display
Try another monitor, if problem still exists your VGA is damaged, if youre using the onboard vga then connect a PCIex vga card get into bios (suppose the display problem is solved) and disable the onboard VGA option. Keep your pc running like this (using external VGA adaptor).
Aug 03, 2011 | ASUS P5KPL-AM SE Motherboard
My PC can not boot up when insert new VGA card (Asus Geforce 7200 GS), while my friend's can. Does this mainboard need disable onboard VGA before inserting new one ? Or does it need some special treatment...
just make sure you have connected it properly and then connect the monitor wire to pci card ..thats it ..it has to work if it didnt work remove the battery in the motherboard and put it back again after 20 seconds..
Jul 22, 2010 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
No display assus motherboard PSN73-AM ASUS MOTHERBOARD
When the PC starts up, do you get a BIOS display at all? Try fitting a graphics card into the board instead of using the built in port, if that works check the BIOS settings to see if the built in adapter has been disabled,
Mar 26, 2010 | ASUS P5N73-AM Motherboard
Vga card is dead so the nothing showing on the screen
On motherboards with built in video cards when you plug in a new card the on board card is automatically disabled. Just plug the card in and connect your monitor.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
Dec 12, 2009 | Gigabyte GA-8VM800PMD-775 Motherboard
P4vm800 not working how to solve this probelom
Good day sir, hi, lets make sure first that your motherboard is good, so we need to test it, just prepare the folowing items.
  1. A good working power supply, to test: place a jumper wire across the green wire and any black(or sometimes the red with work) wire on the 20/24 pin power connector. Plug it and see if the exhaust fan run.
  2. A good set of Ram, just make sure its good. if not or in doubt buy new one (only one module) if you want. (you can keep the doubtful ones and test it later)
  3. A keyboard.
  4. If your motherboard has no VGA onboard, A good VGA card.
  5. A thumb speaker, or you can use your PC case speaker.
Okay lets assemble, on a table:
  1. Place your motherboard, (make sure no metals underneath) connect the Power Supply 20(or 24) pin to your motherboard and the 4 pin 12v connector. (if your motherboard has one).
  2. Connect the pc thumb speaker or your case speaker.
  3. connect the keyboard.
  4. connect the RAM, make sure it clicks as you install it.
  5. Optional VGA card. Onboard vga will do. Connect a monitor. plug in the monitor.
Okay, plug in your power supply, (exhaust fan is off at the moment) locate the power button pins, short them with a screwdriver. (fan is now on)
Now check your Keyboard. you will see two sets of lights, first set is Num Lock + Scroll Lock + Caps Lock, then a few seconds the second set: Num Lock only. at this point your motherboard is good.
Also check out the PC speaker beeps.
  • 1 beep mean good.
  • 1 long and 3 short beeps VGA is bad. (it may help if the VGA is snug and fit on the slot). If on board VGA, use a new AGP/PCIe card.
  • Continous long beeps. cannot detect memory
  • Continous short beeps, motherboard. (or memory sometimes).
  • No beep, fan is on.at this point do everything again. (do it several times until the board responds)
Hope this helps you. feel free to ask again.
Oct 14, 2009 | Asrock P4VM800 Motherboard
Monitor turn dark frequently
it sounds like your PC trouble, you may try (it is better to make sure the monitor connect other PC ok)
1) check PC ram, change ram sticks position if there are two ram stick, or change a new ram if only one ram inside. not fix go next
2) check VGA cable connection, reseat the cable. still not fix go next
3) if you use AGP VGA card change VGA cable to onboard VGA interface (setup bios VGA to onboard),
is this helpful to you olease feedback thanks.
Feb 11, 2009 | Acer Computers & Internet
Open Questions:
Windows Firewall Number O#1=855=536=5666 Windows Firewall technical support number Windows Firewall is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the Windows Firewall email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. Windows Firewall support number When you are using the Windows Firewall for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the Windows Firewall support number and ask for the help. Once you dial the Windows Firewall customer support number, you come in contact with a team of experts at the Windows Firewall customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the Windows Firewall support phone number will help you with that simply and quickly. This is Windows Firewall's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Windows Firewall agent. Features of Windows Firewall support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the Windows Firewall customer support phone number. Here are some of the features of customer service: The Windows Firewall customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the Windows Firewall customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this Windows Firewall provides you the facility of Windows Firewall support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the Windows Firewall. Here are some of the issues that you are going to face when you are using the application: The user might be having trouble with the connectivity of the internet services. There might be questions regarding the plan the user is using, or how can he or she change it? Might be some channels are missing. The list can go on, but there is no need for the user to worry about. As the user can always get the solution to the problem by contacting the Windows Firewall Customer support number team.
Oct 23, 2019 | HIS Computers & Internet
Windows Firewall Number O#1=855=536=5666 Windows Firewall technical support phone number Windows Firewall is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the Windows Firewall email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. Windows Firewall support number When you are using the Windows Firewall for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the Windows Firewall support number and ask for the help. Once you dial the Windows Firewall customer support number, you come in contact with a team of experts at the Windows Firewall customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the Windows Firewall support phone number will help you with that simply and quickly. This is Windows Firewall's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Windows Firewall agent. Features of Windows Firewall support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the Windows Firewall customer support phone number. Here are some of the features of customer service: The Windows Firewall customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the Windows Firewall customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this Windows Firewall provides you the facility of Windows Firewall support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the Windows Firewall. Here are some of the issues that you are going to face when you are using the application: The user might be having trouble with the connectivity of the internet services. There might be questions regarding the plan the user is using, or how can he or she change it? Might be some channels are missing. The list can go on, but there is no need for the user to worry about. As the user can always get the solution to the problem by contacting the Windows Firewall Customer support number team.
Computers & Internet Logo
35 people viewed this question
Ekse
Marvin
Marvin
