Window xp file is missing - Computers & Internet
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    Which XP file? What error message do you get?
    Sergeant:
    Champion:
  • 256 Answers
Run in safe mode restore windows.
Posted on Mar 17, 2008
NTLDR is missing is displayed when i turn on the computer
The "NTLDR is missing", error displays very shortly after the computer is first started; after the Power On Self Test (POST) is complete. Windows XP might only initially load when the NTLDR error message appears. Causes of this error message include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Get more help and information for Windows XP hope this helps you.
Mar 01, 2011 | Microsoft Windows XP Professional
My acer notebook says windows could not start because the file is missing or corrupt \windos\system32\config\system. How do I repair it without a drive to download windows xp onto the computer?
Well i got a trick, i get into other xp notebook or pc and get rid of it of copying the missing file from others, to find that missing file into that address, then burning on the CD, while booting, that he have the file.But that is a file that he trail for configuration of the operative system, but is missing.Sometimes is file that is gone lost from someplace or is delete by bad malware.If you have recover, your lucky to have one.
Nov 11, 2010 | Computers & Internet
My computer is missing important system files
> type the path ...
Specify: C:\WINDOWS\ServicePackFiles\i386
as the "path".
Jun 23, 2010 | Computers & Internet
Ntldr is missing press clt alt del to restart
The NTLDR and Ntdetect.com files are important system files that are used by your computer to start the Windows XP operating system. These files can become damaged, corrupted or deleted for a number of reasons and are usually brought to your attention by the "NTLDR is Missing" error message.
Follow these easy steps to restore the damaged/corrupted or missing NTLDR and Ntdetect.com files from the Windows XP CD using the Recovery Console.
Time Required: Restoring the NTLDR and Ntdetect.com files from the Windows XP CD usually takes less than 15 minutes
Here's How:
Boot your system  using a Windows XP CD, press any key when the windows display "press any key to boot from CD"and wait for some time, select "r" option to go to recovery console. it will ask you for administrator password too.
When you reach the command prompt type the following two commands, pressing Enter after each one:
copy d:\i386\ntldr c:\
copy d:\i386\ntdetect.com c:\
In the command listed above, d represents the drive letter assigned to the optical drive that your Windows XP CD is currently in. While this is most often d, your system could assign a different letter. Also, c:\ represents the root folder of the partition that Windows XP is currently installed on. Again, this is most often the case but your system could be different.
If you're prompted to overwrite either of the two files, press Y.
Take out the Windows XP CD, type exit and then press Enter to restart your PC.
Assuming that missing or corrupt versions of the NTLDR and/or Ntdetect.com files were your only issues, Windows XP should now start normally.
That's it.
Jan 22, 2010 | Acer Aspire 5315 Notebook
C:\windows\system32\hauurjab.dll is missing on my
Just google the error msg and you'll find the solution for it. At most times, ppl recommend you to delete this particular registry file that is associated with this dll file. But if I were you, i would better reinstall the operating system. Just google the error and give a try. Best o'luck.
Hope this helps, If so, rate me.. ,thanks - billa
Sep 05, 2009 | Microsoft Windows XP Home Edition
I can't afford a brand new Windows XP boot disk Where
You should be able to download that file from microsoft, or try googleing "ntoskrnl.exe"
I done it for a missing dll file and found many places to download for free.
May 17, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 1700 PC Notebook Problem gives me a screen windows will not strat because file is corrupted or missing file is \windows\system32\config\system
Is this XP?
Do you have the XP cd or the recovery cd's. This needs to be fixed by performing a Windows repair.
missing or corrupt: \windows\system32\config\system"means that the OS,XP, is missing an essential file to run.
Or it could mean that your hard drive is failing. Is the hard drive noisey?
Leave me a comment,here
Oct 12, 2008 | Compaq Presario 1700 Notebook
Corrupt wimdows file
1 corrupt file please fix this problem 4 me.
Aug 26, 2008 | Microsoft Windows XP Professional With...
Windows dont start
It means that some files needed for windows to restart are missing,probably a system file or boot files. Some windows xp users usually re-install and repair their windows xp system using their original windows xp install disk and selecting the "repair" ooption. But another practical solution is to note down the missing file, then,on another PC using the same system,search for that file and copy, though you will have to note the folder location of that missing file from another PC. Boot your PC (the one that doesn't boot) with a system diskand on the command prompt (DOS prompt) copy the missing file from yourcopy disk to the same location where the missing file should be situated.
If the practical suggestion wouldn't work, then you have to re-install your windows on top of the current installation using your windows cd to repair yourwindows sytem, if this still doesn't then you have to install a new windows systemlocated in a different location in your disk, this way you still go to your saved files and backup your files.
Apr 18, 2008 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
171 people viewed this question
David Payne
David Payne
