Question about Refrigerators
Fridge not cooling enough
The fridge seems to have difficulty staying as cold the past few days. It still makes ice but the ice is melting and driping through the outside ice dispencer. I can hear the compressor or at least the fan running. When I open the door I can tell its not as cold as it was a week ago. Any ideas how to trouble shoot?
Thanks Rob
    Sergeant:
  • 120 Answers
Check compressor if it is working fine then check temperature thermostat. If they both are good then either your fridge has ran out of gas or the doors are not closing properly.
Posted on Nov 09, 2017
SOURCE:
catriver
  • 878 Answers
SOURCE: Fridge/freezer
Denis, frosting back to the compressor is usually a sign of refrigerant overcharge. The fact that you noticed one of the other lines opened could indicate a wrong charge. You will need a cfc certified tech to check this thing out. This way he can check for a proper charge, restriction or a weak pumper...Catriver..post back.
Posted on Sep 04, 2006
fridgetech
  • 473 Answers
SOURCE: refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Posted on Nov 16, 2007
22yooper
  • 828 Answers
SOURCE: Fridge not cooling compressor works intermitently
If the compressor starts and runs for a few seconds it could be the relay. Or it could be the compressor itself has failed. When a compressor starts and runs for a short period it is possible that the relay contacts are arced together which would have both the start and run winding in the motor engaged at the same time for more than 3 seconds. This would result in the compressor tripping out on the thermal overload. It depends on what type of relay your compressor has. If it is a thermal relay, unplugging the refrigerator for about 15 minutes would allow the relay to cool off and reset.
Posted on May 10, 2008
  • 489 Answers
SOURCE: Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Posted on Sep 30, 2008
  • 399 Answers
SOURCE: the freezer has ice build up on vents
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
also click the links below for more help
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Posted on Dec 06, 2008
Fridge portion doesn't get cold
The defrost circuit is not working, there are usually 3 things that normally go bad, defrost timer, defrost heater, and thermal switch. Would have serviceman check it out as cooling fins on coils will cut you like a razor.
Jul 24, 2017 | Whirlpool Centralpark 25.6 Cu. Ft....
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Aug 12, 2012 | Frigidaire FRS3R5EMB Side by Side...
Driping water into food cooling section.
The drain that carries the water from the freezer to the evap tray is plugged and filling the space between fridge and freezer up with water and then soon it won't be cold in the fridge anymore as it will block the flow of air from the fridge to the freezer. Locate the drain in back of the fridge or inside compartment under freezer and unplug. Should actually unplug fridge overnight to let ice melt in between levels.
Jul 19, 2011 | GE Refrigerators
Fridge and freezer doesnt seem cold enough. Things are cool but not cold. Ice cream is not as hard as usual (soft but not melted). Ice maker not making ice. Adjusting thermostat doesn't seem to make a...
Please check the timer the thermostat and the heater for the auto defrosting to work. Switch off the fridge and after all the frost has gone off switch on to see if the sooling returns . If so you can be sure that the timerr does not work and so reduces cooling on frosting. If there is still no cooling then you will need to check onthe compressor and the gas pressure. Get help to confirm and take an estimate before attempting, get an warranty assurance for work. Hope you try out and see first.Good day
Aug 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My fridge is working but not cold enough. Freezer
DEFROSE YOUR FRIDGE IN ONE DAY OR TWO DAYS UNTIL THE ICES ARE MELTED AND CLEAN
Feb 15, 2010 | Samsung RF265AA Bottom Freezer French Door...
Candy Fridge - The freezer part is not cold enough, fridge ok!
A couple of things to check-
- Is the condensor cooling fan running? This will be located to push air through the external cooling coils, wherever they are located.
- Does the auto-defrost timer work? It may have failed and stayed in a position that has left the heating elements (for defrosting) turned on.
- Does it seem to be running way too long and not turning off as it once did? This could indicate either a loss of coolant (would need recharge and leak detection) or the compressor is reaching its end of life. If the latter is the problem, expect a cost of $200-$400 US.
Apr 07, 2009 | Whirlpool Gold Series GI15NDXT 15"...
I have a Samsung RM255LASH Side by Side Refrigerator. The ice maker is not making ice correctly. The ice that comes out is half water, like its already melting. Later the same day I noticed water on...
move the fridge out to see if there is water underneath it sounds like a leak in a line some where you might want to have a service tech check it out.
Dec 07, 2008 | Samsung RM255LASH Side by Side...
Fridge is not cold enough, freezer is working fine, but has frost
Just had the same problem with my side-by-side.
In my case, the solution was to empty the freezer side, to access a back panel INSIDE the freezer covering the fan and cooling coils. Two screws held the back panel cover on, and when I removed the panel cover I found the cooling coils to be totally iced up, preventing the flow of cold air into the fridge side. I left the freezer open for a few hours until all the ice was melted, before replacing the inside panel. (I used a blow dryer to help speed up the ice melting).
Everything's working fine now for me - good luck with yours!
MW
Nov 17, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
