Question about Brother MFC-5840CN All-In-One InkJet Printer
Print Unable 50 Brother MFC5460 CN
Hi
My Brother Multi-Function Printer MFC 5460 CN showed an error message Print Unable 50 after the paper jammed and I removed the jammed paper out, but it still kept showing "print unable 50". There was once that it showed "print unable 30" What is wrong?
I am trying to see if there is still a paper stuck inside, but there is none. I am trying to follow what the user's guide said which is included
-Open scanner cover & remove objects
-Disconnect the machine and reconnect it again
But it still keep showing this message. I called Brother and they told me if my printer is no longer under warranty and the service center said they charge labor fee $90 and part $45!!! I don't know what to do now and my husband is going to kill me :( Help me please!
I need a detailed advice about how to fix the problem on our own.
  • catsup Apr 04, 2008
    Brother printer error message "unable to print" and to refer to the users guide.
    I can't figure out on line what the actual solution is.
  • Anonymous Apr 14, 2008
    My Brother MFC 5840CN's LCD is showing 'Unable to print - See troubleshooting and maintenance chapter in User's Guide.'
    I have checked for foreign objects and have no faxes in memory. I have disconnected and reconnected to power source. Nothing happens. I have visited Brother Solutions online and get no help understanding what 'mechanical problem' the MFC has.
    Can anyone be of assistance? Thanks
  • 832 Answers
So dont let me be a withness of murderer:
There is no paper sicking within the machine! The jam had lifted the encoder strip out of the ph. After you have fixed it simppy stick some very thin scotch tape onto the ph cover to avoid further liftings (that will happen quite often...)
same issue: (change the viwing size of your browser to enlage the pics)
http://www.fixya.com/support/t211210-brother_mfc845cw
Posted on Mar 17, 2008
Print unable 51 code on brother MFC-5460 CN
paper jam or some sensor error, try to clean the sensor, locate the sensor under the pump, where the printer head park the dis assemble and get the sensor, then clean with water or alcojol..
Jul 21, 2014 | Brother MFC-5460CN InkJet Printer
Our mfc5460 brother printer is giving the error message "print unable 30" and "print unable 50" alternately. WE had a paper jam, removed everything we could see from top and back, and are now stuck. We...
  • Remove the input paper tray and take off the output tray. Remove all loose paper from the input tray.
  • Step 2Pull out the paper support flap and unfold it to its greatest length.
  • Step 3Flip through the stack of paper before inserting it back into the input tray. Place the paper in the tray and adjust the paper guides so they press against the margins of the paper.
  • Step 4Ensure that the stack of paper is below the maximum paper line on the inside of the input tray. Unplug the power cord from the back of the printer.
  • Aug 09, 2010 | Brother MFC-5460CN All-In-One InkJet...
    Multi-Function Center MFC-240C All-In-One InkJet Printer: i get the message "print unable 36" displayed on m...
    Error code 36 is generally because of a paper jam that was not cleared. Remove the rear jam cover (the plastic cover in the back center of the machine)and the paper tray and check for any pieces of paper. Sometimes just a scrap will remain, but it's enough to cause the machine to not work.
    Once you've replaced the covers, if the jam code does not reset, turn the machine off and then back on.
    May 16, 2010 | Brother Multi-Function Center MFC-240C...
    My printer is showing an error
    our printer brother mfc 5460 is not printing.....even though there's an ink....how can we fix that? pls help....
    Dec 27, 2009 | Brother MFC-5460CN All-In-One InkJet...
    Unable to print 30 or 50
    the encoder strip is probably out of its socket. its a long mylar strip that goes from one side to the other, and goes underneath the printhead.
    Jun 25, 2009 | Brother Multi-Function Center MFC-665CW...
    Message unable to print 50
    Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
    Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
    I have a brother mfc 665cw printer, had a printer jam, cleared the jam and now recieve unable to print 50 error, unable to copy or print. Have found some information about the encoder strip but I have no...
    Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
    Worth a try, as I have fixed a number of printers this way, saving costly repairs.
    Hope this helps. Bud
    Jan 05, 2009 | Brother Multi-Function Center MFC-665CW...
    Error messages
    I can't help directly but if you go here to the (Australian) support site
    http://www.brother.com.au/customersupport/customersupport.asp
    you may find your answer.
    Note You may need to contact them direct to get your answer.
    Good luck.
    May 11, 2008 | Brother Multi-Function Center MFC-240C...
    Error messages
    same issue:
    http://www.fixya.com/support/t294185-brother_mfc_240c_change_unable_50
    Dec 29, 2007 | Brother MFC-845CW multi-function...
    Brother MFC-5840CN All-In-One InkJet Printer Logo
    775 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Victorman
    Victorman
