Question about Zebra Printer 140-751-00000
Zebra Printing issue
Zebra printer is printing a blank ticket then the printed ticket then another blank ticket. How do I get the printer from not printing the blank tickets?
  • 1 more comment
  • dpflynn2006 Mar 17, 2008
    I had to recalibrate the printer and then it seemed to work. Thanks for trying.
  • Anonymous Apr 08, 2008
    Only print the bottom halve of ticket.
  • neilna_77 May 11, 2010
    how do i recalibrate the zebra 170 ix printer?
    President:
  • 4,402 Answers
Turn off eof or blank page after eof
Posted on Mar 17, 2008
Hi all~ my zebra printer print blank non-stop everytime power on printer. we need send jobs first just can power on printer to stop printing blank non-stop.
When you power that printer on it will automatically calibrate which can kick out up to 6 feet(2 meters) of blank labels. After that is done if you have an issue it should display an error.
Sep 29, 2015 | Zebra 203DPI Printer
Zebra TLP 2824 Plus does not print barbell labels
You need to run win7 in XP mode. I am not sure the Zebra software will run in 64bit.
Feb 27, 2017 | Zebra Office Equipment & Supplies
TLP 2742 is printing blank labels
Skipping labels is normally a calibration issue or label template size. Solution: TLP 2742 is printing blank labels
Apr 02, 2012 | Zebra Eltron TLP 2742 Thermal Label...
Will print on sticker labels, but not on thick price ticket paper
If you are not using ribbon, the tickets are probably not Direct thermal. Try using a Ribbon and see if it works
Mar 02, 2010 | Zebra 105SL Thermal Label Printer
Zebra M4 is printing blank labels
Did you switch your ribbon as well?
Jul 06, 2009 | Zebra Z4M Printer
Zebra 2746e will skip leaving a blank label while printing.
You need to calibrate. Hold down the feed key while powering the printer on, then let go. The printer will calibrate, print a config label, then fo into dump mode. Press the fee key again to go out of dump. Of your issue persists, there could be a problem with yoru media, or with the commands that you are sending to the printer.
May 28, 2009 | Zebra 2746e Thermal Printer
I can't print to my printer zm400
When you install the driver, do you get a test print from the driver setup? If the data light blinks, this is at least a sign that something is coming and the printer is aware of it. If you feel knowledgeable of the printer to do a Media Sensor setup through the menu, you can reset the printer to Factory Default settings. Getting any print from the machine is a plus. Are you using the Zebra drivers? If yes, you can try printing from Notepad.
Apr 26, 2009 | Zebra Printer 140-751-00000
Printing blank labels between and after printing tags
your printer needs to be calibrated and set label lenth in the driver in both printer preference and printer defaults
Jan 16, 2008 | Zebra Eltron TLP 2742 Thermal Label...
Advances ticket too far after printing.
your label length is set incorrectly, there are 2 things it could be
1) your software is telling the printer the label length is longer then the current labels, even if the label size is out my a single millimeter the printer will give you this issue of feed an extra label. you need to change this in your software. you can set a label size smaller then the current label size and it will work correctly
2) you software is not setting a label length and so the printer is going off its internal setting, to recalibrate hold feed and power up the printer letting go after the light starts flashing
it is important to note that label roll will change slightly over time so even though you are ordering the same labels as a year ago the manufacturer will have slight changes from batch to batch
Nov 05, 2007 | Zebra Eltron TLP 2742 Thermal Label...
Zebra Printer 140-751-00000 Logo
379 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
