Tip & How-To about Washing Machines
If your washing machine won't drain and, the pump appears to be stuck:
Go to an autoparts store and, buy a radiator locking hose pinch off plier. Then: unplug the washer (remove all power) bail out all the water with a cup or, bowl; remove the washer cabinet or, tilt back the washer against a wall so that you can access the pump from underneath the front; pinch off the tub to pump hose; lock the plier, place a towel under the pump; remove all screws on the pump cover; remove the blockage from the pump and, reattach the pump cover. remove the pliers and, test the washer. (if you can acces the pump from the front (like a front load washer) you do not need to bail out the water as, the pliers will hold the water in the tub, so that only a small amount of water will come out when you open the pump.)
