Question about Volfenhag ZX-8300 Car Audio Amplifier
How to mount amp
No visible mounting holes on volfenhag zx-8150 to secure on van floor
  • 3 Answers
Turn your amp over and you'll see 4 holes one in each corner and you should gotten 4 v shapped pieces of metal with 2 holes each and 4 screws.....you normally have to mount them on manually. I hope that helps.
Posted on Jun 17, 2008
SOURCE:
Mounting amp to car
make sure you mount where you can get a good ground and where it can get enough air to keep cool. underneath the car seat is where a lot of installer put the amp, and if you are going power up a lot i would think about mounting a fan to blow air on it to keep it cool. i have fans connected to my laptop power supply transformer to keep the unit cool, here other ideas you will never be told, putting little holes around power supple, fan area, any where there a lot of heat is generated the air flow helps it stay cooler while powering up the amp.
good luck and be safe rod
Mar 01, 2014 | Volfenhag Car Audio & Video
Whats involved in fitting genuine ford rear seats into my connect panel van?
No the mounts in the floor should be there. You can't just drill holes, the sheet metal would tear away in a crash.
May 31, 2012 | Cars & Trucks
Amplifier has a phone jack for remote. Stereo has a blue wire for remote. Do these two need to connect to each other, or can I just run a phone cable from the amp to a remote switch mounted up front. ...
No. That port is for your gain(volume) control switch for the amp(it should have been included with the amp). Connect the stereo's blue remote wire to the amp's remote input that's next to the batt. input and ground input. Here's a link that showed me the pics plus a pic of the switch with the phone jack cable. Copy and paste. Good luck. http://www.sonicelectronix.com/item_2553_Volfenhag-ZX-8300.html
Jul 25, 2011 | Volfenhag ZX-8300 Car Audio Amplifier
Need help setting amp right
volfenhag's are cheap. you get what you pay for. that is the german equiv. to pyramid or kraco.
Jul 10, 2010 | Volfenhag ZX-5007 Car Audio Amplifier
Amp turns on but no green light and no sound
As a pro i have ran into this problem many times,what happens with volfenhag amps the solders on the RCA inputs aren't very good,and what happens is that you get to much current going threw them and they over heat and lose contact,volfenhag will fix it,you have to pay for shipping to them,and include a 12 dollar money order.Volfenhag audio 1-323-588-8571.
Jun 03, 2010 | Volfenhag ZX-8400 Car Audio Amplifier
I have a volfenhag zx-8400 amp. i dont have a manual. whats the proper way of conecting amp? its mounted on my speaker box, which is ported, 12' volfenhag 2500 watts. on the side of amp it had voltage...
The voltage prolly says like 100Mv-2v, it doesn't really matter, just know that that the lower you turn it the harder it bangs. The X-over depends on where your box is tuned, crank the knob down too about 40htz and you'll prolly be good, just don't turn it lower than your box's tuned frequency. And your rca's go to line input. And there shouldn't be a problem with mounting your amp vertically, you prolly just had a bad connection. Hope this helps if you have more questions please ask...
Sep 21, 2009 | Volfenhag ZX-8400 Car Audio Amplifier
Cant find how to mount amp
u need at least 2 lil L shaped brackets.flip ov er the amp and on the corners there should be a couple of holes thats were your lil L shaped brackets go.thats were mine go anyway. the brackets are about 1" .
Mar 17, 2008 | Volfenhag ZX-8300 Car Audio Amplifier
Volfenhag ZX-8300 Car Audio Amplifier Logo
149 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
Professor_V
Professor_V
Steve Sweetleaf
Steve Sweetleaf
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
