Konica 4155 print shift
I have a Konica 4155 that when the copy comes out, the print is shifted from where it should be. The original is located properly. Is it a timing thing, or the lamp, or a tray problem, ....?
  • pseagle Mar 25, 2008
    Nitrotrike....I'll get back to you on your questions.
  • brian c
    brian c May 11, 2010
    Is it shifted from front to rear, or from left to right?
    Is it happening happening only on the glass, or also through the top feeder?
    President:
  • 2,072 Answers
Your paper tray guides may just be out of place. Make sure the guides are against the paper when it is loaded.
The registration may need to be adjusted but that would require a service call to adjust.
Posted on Mar 17, 2008
My machine is showing me p-22 what does it mine
Color regist adjust failure
• The color shift amount is greater than the specified
range during main scan direction registration correction.
range during sub scan direction registration correction.
• On the color shift test pattern, the maximum and minimum
deviations detected in the main and sub scan
directions go over the predetermined value.
Dec 23, 2014 | Konica Minolta Bizhub C451 Copy-print-scan
Why when I select Glossy in the print settings, the print shifts?
Run this paper from the bypass tray located on the right hand side of the machine.
Try setting that paper type on the copier itself.
Load the paper. Go to the manual paper tray select screen. Select tray 1 and then change paper settings.
Glossy paper also tends to slip in these machines when the paper tray rollers are bad.
Oct 29, 2014 | Konica Minolta Office Equipment & Supplies
Twosided copying problem
Try turning original in a different orientation i.e. horizontally vs vertically on top of glass, under lid. Jimmy
Apr 10, 2012 | Canon Office Equipment & Supplies
Konica Minolta Magicolor 2300W firmware needed
firmware is located on secure web site try having a Konica Minolta tech come out and flash the firmware
Apr 15, 2010 | Minolta magicolor 2300W Laser Printer
Text moves down the page when I copy - how can I stop this?
Sounds like it is either resizing the image or not seeing all of the original.
Specify the original size and do not use auto.
Make sure thsat image shift or image centring is not on.
Jun 16, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
You need to enter a service mode. Holding down the "3" and "6" turn on .Enter "92" press copy button then press "P" when the copy quantity indicator flashes a number enter using the number keys a smaller or larger number.turn off then on.
Mar 17, 2008 | Office Equipment & Supplies
Old Polaroid photos
Having photographic quality copy prints made will give you far longer life than the original Polaroid. Polaroid colour dyes will shift colours and eventually fade dramatically. New photographic (and some ink jet) prints will last generations without noticeable fading.
Feb 24, 2008 | Photography
Konica 4155 - J16 Paper Jam
First, check if the paper loaded is matched with the copier settings.
If that doesn't solve the problem, carefully check the paper path sensors.
Feb 07, 2008 | Office Equipment & Supplies
k24674
