Question about JVC AV-27230 27" TV
Rca tv hi, picture is gone. humming noise coming from inside....on/off buttons arent working either,before total black out ,picture would codense to very thin and then go back to orginal size,thought it was cable company.. Any suggestions? thanks Don
    Scholar:
  • 54 Answers
Sounds like your high voltage section, or your main power supply is shot. DO NOT OPEN THE BACK OF YOUR TV.
The chassis of the TV ( any metal inside the plastic outer shell ) is Electrically HOT ! The High voltage section has upwards of 30,000 ( thirty thousand ) volts running to the picture tube...so DON'T TOUCH ANYTHING.
THe Humming noise is the TV Drawing a lot of current and trying to work. Don't continue to let it try or it will be an even more expensive fix....pull the plug !!
WHAT YOU SAW:
  • "The picture could condense to very thin and then go back to orginal size"......this means that the vertical high voltage section was collapsing (the high voltage for this part of the picture has failed ) and coming back ( normal picture )........this means that some part in the HV section was on its last legs. Now it has no legs.
Best thing you could do is take it to a shop. I have a 32" JVC of the same era and love it. It has given me no problems at all, and even though the price of a new "Tube" TV is extremely low, the picture quality isnt anywhere near as good as your old JVC. Personally, I would at least get an estimate to repair. Good luck....Rob
Posted on Mar 17, 2008
Tv screen has gone black but still have sound when you shut the tv off and turn it back on the screen comes up but it flashes and goes black again
Hi Bob, The link below is a YouTube video showing how to fix a RCA television(DIFFERENT MODEL) NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
RCA 46LA45RQ tv repair No picture no power troubleshooting
May 01, 2016 | RCA L46WD250 46 in. LCD HDTV
The TV will bring to turn on but then it sounds like it loses power and makes a high pitch noise and powers off, no picture ever comes on the TV, the screen stays black the whole time. The TV is a RCA...
it could one of two things. The power supply is failing which is most common. Or the picture tube is gone. Both would most likely cost you more to fix than the TV is worth. Call around and get a few quotes. Good luck
Jun 02, 2010 | RCA F32650 32" TV
My RCA projection tv makes a loud buzzing, humming noise. Does as soon as turned on even before picture comes on, does not stop till tv is turned off.
buzzing noise is cause by small electrical arc inside the unit or a problem in your audio circuit.if you can open the unit up and check if its an electrical arc.
Jun 21, 2009 | RCA HD52W59 HDTV Projection Television
I'm experencings a buzzing noise coming from the speaker when I turn on the tv....How can I get rid of this noise?
Give this a shot, it should fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone.
Let me know if this works.
Feb 19, 2009 | Proscan 32LB30QD 32 in. LCD TV
Tv taking long time to come and when come on making humming noise
. These are the caps I replaced they where only a little swollen I was worried if they where even the problem but I changed these three and was very happy that my TV is now working like new again the two top ones I replaced with 1000uf 16v the lower one is 1000uf 35v ok well I hope this helps ya
Nov 28, 2008 | Polaroid FLM-323B Television
Trobleshoot RCA F32650 32inch tv
I think that something has gone wrong on the power supply board. If you can check this for yourself otherwise find a competant technician. Hope this helps.
May 11, 2008 | RCA F32650 32" TV
RCA HD50LPW175
Sounds like the color wheel is failing.
Dec 18, 2007 | RCA HD50LPW175 50" HDTV
RCA TV
humming is due to main filter capacitor have gone dry or defective. repace it humming will go. picture cut is due to less voltage going to vertical stage.coming froh eht(hor stage.) as main filter will cause main power supply to be low which will cause low voltage to hor.stage.
Sep 27, 2007 | Televison & Video
Picture went out and all the tv does is make a buzzing sound
The horizontal output transistor drives a transformer that gives you the high voltage to light up the picture tube,either the transistor or the transformer have gone bad,sometimes both have to be replaced and sometimes the transistor fails for no reason by itself.Be safe and call for help if you are not familiar with tv service.
Sep 20, 2006 | RCA F32450 32" TV
JVC AV-27230 27" TV Logo
64 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
