Question about Insignia LCDTV26 26 in. Television
Black and white format on 26" insignia hdtv (720p)
When I change the aspect ratio to widescreen, everything looks fine, except on the black and white movies. On the left and right hand side of the screens, the colors dont' seem the same. I'm new to hdtv, maybe this is something normal. Not sure.
  • Anonymous Mar 31, 2014
    subject says it all... i connected a tivo mini set to 720p and the TV displays the image in the center of the screen with borders on not only the top and bottom but on the left and right as well... Pressing zoom doesn't fix the issue (correctly) but widescreen2 is 'kinda close'.
    President:
  • Insignia Master
  • 1,779 Answers
Go to Best Buy and see if they have your same Model on display and change the aspect ratio and see how it is. If it's normal there then to me it sounds like a software up-grade might be in order. It might just have a software glitch.
Posted on Mar 17, 2008
How can I change the screen size on my emerson 55 in tv with my remote contrl
Try:
1. Open the Main Menu (which is by the way the left arrow)
2. Choose settings
3. Press ok
4. Choose Television and press the right arrow 6 times
5. Choose view all and press ok
6. Choose Screen Aspect Ratio and High Definition and press OK
for this step you will need to know what type of display you have:
If you have a...
4:3 standard definition for an ordinary TV
Widescreen standard definition for a widescreen TV (16:9 aspect ratio) that doesn't display HD
720p on high-definition screens for an HDTV with 1280 x 720 resolution
1080i on high-definition screens for an HDTV with 1920 x 1080 resolution
1080p on high-definition screens for an HDTV with 1920 x 1080 resolution and progressive scan (also known as "Full HD")
I can't really help you with this, try looking in the maunal, but you can test it by...
7. Choose continue and press ok
8. On screen instructions will be shown on how to test your resolution
I hope this helps!!
Mar 30, 2017 | Emerson Televison & Video
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
Picture is too large for the screen cutting off heads and cuting off text at bottom
change your aspect ratio, format, 16:9 or 4:3 or widescreen, normal or etc
Feb 17, 2011 | Insignia LCDTV26 26 in. Television
I re-scanned my channels this weekend because I lost HD on 2 of my local channels. Now I have HD back, but I have 2 black lines on each side the picture on all of the HD channels. How do I get rid of the...
A broadcaster will transmit an HD channel in 1 format. This may be 720p or 1080i, both of which are HDTV formats. HDTV formats have an aspect ratio of 16:9. SDTV or standard definition broadcast have an aspect ratio of 4:3. Because not all content is record in an HD format (ex: Judy Judy), the broadcast is faced with 2 options. #1, stretch the 4:3 picture do that it fills the 16:9 canvas. #2, simple place black side bars on each side of the 4:3 image. What you are seeing is the latter of the 2 options. You will notice a change during the evening programming. The bars are only there when the content is not HD. You can use the WIDE feature of your TV to stretch the picture so that it fills the screen, just like broadcaster option #1 above.
Mar 15, 2010 | Vizio VW37L 37 in. LCD HDTV
Aspect Ratio problems with Insignia 26
Keep your Auto Zoom Off set Full screen than only you will get proper picture
Jan 21, 2010 | Insignia 26 in. LCD Flat-Panel HDTV
Insignia 32" NS 32 q09
Since you don't mention how you're receiving the signal, I'm assuming you use a cable box or computer. Adjust the output settings (e.g. 720p, 1080p) on the box and then adjust your TV settings. If it's a computer, you'll need to adjust the video card settings to a compatible aspect ratio (e.g. 1366x768) for the desktop to display properly on the TV. Details can be found in the owner's manual.
Jan 04, 2010 | Insignia 37" LCD Flat-Panel HDTV
On my Insignia LCDTV26 I have almost 3" of black screen on the right and left side of the picture.
This is normal if you're watching a 4:3 (full screen) broadcast or movie on your widescreen (16:9) TV. You can adjust the screen aspect by going into the Settings Main Menu and selecting System, then Aspect Ratio. I hope this helps!
Jul 22, 2009 | Insignia LCDTV26 26 in. Television
Bought a 19inch LCD Insignia TV yesterday at Best Buy. Everthing works fine except the picture won't fill out the whole screen. Can't find anything in the menu to adjust this.
On you remote control or panel buttons press the menu button. Using you on screen menu, use the up and down arrows to find the Settings Function, use right arrow to enter sub-menu. Use the up and down arrows to find the aspect ratio setting. Use the right arrow to enter the sub-menu.From here you can change the picture setting to : Normal wide 1: Wide 2 : Zoom: Cinema. Once you found your preferred viewing picture, set you choice with the enter button. Then use the menu or escape buttons to close the on screen menu. I hope this helps you with your problem.
May 15, 2009 | Insignia LCDTV26 26 in. Television
1- I have a Panasonic TV (PT-53TW54)that has a "digital scan rate of 1080i,540P". I'm not sure if that means it has a digital tuner. Do I need a digital converter for this unit? 2- I'm using a...
1. Do I need any additional equipment to watch HDTV broadcasts on my HDTV-compatible TV?
In order to view over-the-air (OTA) HDTV broadcasts, you need to be within the reception area of a TV station broadcasting HDTV signals. Some TVs may require a set-top HDTV tuner and an external antenna to receive the broadcasts. Your cable or satellite provider may also offer HDTV channels as a part of their service, eliminating the need for a separate tuner. Please contact your local service provider to find out what kind of HDTV services they may offer.
2. What is CableCARD and how does it work?
HDTVs with CableCARD slots can accept a small card from your cable provider that allows you to receive standard definition and high definition digital broadcasts without a bulky set-top cable box. Please call your cable company to find out if they offer this service in your area.
btn_top_gold.gif spacer.gif line_gold.gif spacer.gif spacer.gif3. What is HDMI? Is it compatible with DVI?
HDMI, which stands for "High-Definition Multimedia Interface", is the consumer electronic industry's first connection capable of transmitting uncompressed digital audio/video signals. Components featuring HDMI can transmit both digital audio and video over one convenient cable, replacing the tangled mess that resides behind many home theater components. HDMI also offers improved quality over traditional analog connections thanks to all-digital transmission. Digital sources like DVDs and HDTV programming can now be transferred digitally from source to display without analog conversions that can degrade the original signal.
Unlike the HDMI interface, DVI only handles digital video. Through the use of an adapter, a DVI device can be connected to an HDMI device, but only video content can be transmitted. The audio signal would have to be transmitted through other methods such as analog RCA outputs or an optical digital output.
4. What's the difference between 720p and 1080i HDTV broadcasts? Does my CRT projection HDTV support both?
HDTV signals can be broadcast in either 720p and 1080i. It's up to the broadcaster which signal format to use, and both have their benefits. Our CRT projection HDTVs display 1080i signals in their native format. For 720p broadcasts, you can use the settings on your HDTV set-top tuner, cable box, or satellite tuner to convert a 720p signal into a 1080i signal that your TV can display.
btn_top_gold.gif spacer.gif line_gold.gif spacer.gif spacer.gif5. Why do I still see black bars on my widescreen TV when viewing certain widescreen DVDs and HDTV broadcasts?
Your widescreen TV has an aspect ratio of 16:9 (1.78:1), which is the aspect ratio of HDTV. However, movies are filmed at several different aspect ratios, including 2.35:1. Also referred to as "scope", 2.35:1 is a very panoramic aspect ratio that provides a wide field of view in the theater. Scope is much wider than your widescreen TV, so it still requires the use of letterboxing ("black bars") to fit the entire image on screen. Some TVs and DVD players have a zoom function that allows you to blow up the image so it fills the screen, but the sides of the image must be cropped in order to do so.
6. What will 4:3 broadcasts and DVDs look like on a widescreen TV?
There are multiple settings for adjusting the appearance of 4:3 material on Panasonic widescreen TVs. It can be viewed with black bars on the sides, preserving the way it was originally intended to be viewed. Some viewers find the black bars distracting, so they might prefer one of the stretch modes that lets you fill the entire TV screen with the image. One such mode is the JUST (justify) mode, which stretches only the outer portion of the picture while leaving the center untouched.
Oct 21, 2008 | Panasonic Televison & Video
Insignia LCDTV26 26 in. Television Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
