Question about Sharp AL-1655CS Copier
Sharp AL-1655CS ERROR MESSAGE
Display is frozen says "system error (H4-00) refer to manual" but there is nothing in the manual with regard to this system error code.
  • 2 more comments
  • RandyD Mar 20, 2008
    There is no Auto or 10's key on tne AL-1655CS
  • Anonymous Jul 24, 2008
    We are having the same problem after power outage yesterday. I pressed #, * C * but the error message is still frozen in place.
  • Anonymous Jan 07, 2009
    I have the same code error H4-00, tried all the solutions. The problem still.
  • Anonymous Mar 31, 2009
    I tried the best solution and it did not work. the other 2 solutions dont seem to fit my model/year. thanks
The [H4-00] system error popped up when the power went out of the house. I called Sharp Tech Support (1-630-378-3590) and was talking to their Tech Support in less than a minute.
The FIX? Just press the following keystrokes:
# * C * (That's pound, star, C, star) This will clear the display error, now press…14, then press the green button twice. This should let your printer start to warm up and you have fixed your problem.
Posted on May 07, 2008
  • Chilimama Jan 07, 2011
    This apprentice is a total genius!!! Thank you so much for taking your time to help us out.
    President:
  • 2,072 Answers
This should take care of that.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Posted on Mar 17, 2008
  • 1 more comment
  • Rick Kasper Mar 21, 2008
    That is the solution.
    Why not ask before harming my rating?
    That is not fair or correct at all.
    I would explane it more but not with that unfair rating.
    NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
    1. Locate the [C] (Clear) button on the Control Panel, at the far right.
    2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
    3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
    4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
    5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
    6. Press the [Start] button. The machine should be ready to use.
    7. Make a copy, to check that the machine is working properly
    This will clear it. Learn how to be realistic in the future. You will NOT get good service insulting honest reps.
# * C # worked for me.....I called tech support, got a rep on the line inside 5 minutes, and he walked me through the code.
Posted on May 04, 2010
E1-00
Posted on Aug 25, 2009
My boss has a Sharp AL-1655CS Copy Machine and it makes this awful, screatching noise when I try to copy anything. Now the System Error Code L1-00 shows up. Not sure what to do.
Your problem on scanner unite.May be your copier is now lock position.
Solve:Unlock position.Left side under copy Board.Then solve your problem.Or study your copier user manual.
Jan 12, 2010 | Sharp AL-1655CS Copier
Sharp AL-1655CS ''Replace the drum cartridge'' error message
Have you replaced with a new drum cartridge? If so, does it still display error message? You have to simulate 24 sub 7 to reset drum .
Nov 04, 2009 | Sharp Office Equipment & Supplies
My Sharp Al-1655CS Display is frozen say: system error (H4-00)
Thank you!
Sabharish
Jun 19, 2009 | Sharp AL-1655CS Copier
System error L1-00 Sharp AL 1655cs
hi maryanne,delete all the sharp AL 1655cs programme and reinstall the printer software (INSTALL PRINTER) if need more help please log on to sharp copier web site for the manual instruction..before that make sure your printer is compatible for your PC.
Dec 08, 2008 | Sharp AL-1655CS Copier
MESSAGE: SYSTEM ERROR (H4-00) REFER TU USER GUIDE
We had this problem when the power was fluctuating in our building. I called Sharp and they told me to clear this condition with the following code: #*C* and when the screen shows 00-00 enter 14 and press the green copy buton. This worked on the AL-1655CS. On the AL-1631 we had to do a similar thing: C<auto>C<auto> 14 <copy>
Jun 06, 2008 | Sharp AL-1655CS Laser Printer
Cant get rid of blinking error message, nothing works
H4-00 is a fuser related service code. you need to get into the simulation programs and run sim 14 to reset the code. Make sure there is no paper jammed in the fuser. (The hot part on the right side inside the door)
Dec 02, 2007 | Sharp AL-1655CS Copier
Sharp AL-1655CS Copier Logo
1,970 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
