Question about Volfenhag ZX-8300 Car Audio Amplifier
Cant find how to mount amp
How to mount amp no visible mount holes
U need at least 2 lil L shaped brackets.flip ov er the amp and on the corners there should be a couple of holes thats were your lil L shaped brackets go.thats were mine go anyway. the brackets are about 1" .
Posted on Mar 21, 2008
I have a 32 inch ATSC/ALT3200N....Need a wall mount for it, and where to get same.
If you know what the Mounting comfiguration is... 200mm x 200mm etc. and the weight of the unit, then you can start your search...google search for the mounting size... i.e. "200mm x 200mm LCD wall Mount bracket"
that will get you started... then you can narrow down the search for the Weight supporting limitations.
your manual saids the hole pattern is:
Vesa standard (300x200mm)
Screw type: 4 x MB5x10
here's my search results:
http://www.google.com/#q=300mm+x+200mm+wall+mount+bracket&hl=en&prmd=ivns&source=univ&tbs=shop:1&tbo=u&sa=X&ei=yjx5Tf2vJZKw0QHL-ZzMAw&sqi=2&ved=0CFMQrQQ&biw=1015&bih=642&bav=on.2,or.&fp=86eb73c4baae05b0
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
Mar 10, 2011 | Televison & Video
How do you install the rear rack ears
I don't know about the Peavey amp but most have rack holes that run parallel with the amp's side panels. On the rear of the rack this requires a mounting kit unique to your rack (provided there are mounting rails present) or some creative strapping to properly stabilize the amp. I've seen tech's anchor the rear mounts to the inside of the rack walls. Wood is easiest (and strongest) to work with but fiberglass mounts with fender washers also creates a pretty strong mount....G.
Dec 06, 2010 | Peavey Pv 2600 Power Amplifier
Interior hood release broke out around mounting bolt. Temporary mounted release but still can not release hood. No opening problems until now. How do I get the open?
If just the mounting broke & not the cable also, take a pair of vicegrips or good pliers on visible portion of steel cable & pull inward. If the cable itself is not broken it will pull out enough to open release.
Jun 16, 2010 | 1998 GMC Sierra
Cant get brake light to go out
make sure the brake light switch is mounted and adjusted properly. they have been known in older cars to actually fall out of their mounting hole which in turn makes the brake lights stay on all the time. if it all looks good then it probably needs to be replaced. most new switches are self adjusting so that helps!
Apr 08, 2010 | 1994 Buick LeSabre
Canon printer pixma mp780 makes repeated clicking noise but will not work. Shows ##356 on LCDisplay
This is the Automatic Sheet Feeder [ASF] Cam Sensor Error
Movement may cause the plastic guide to move away from the chassis which causes the gears not to rotate properly causing a grinding noise and 5 alternating blinks (SFP) or ##356 (MFP) - ASF Cam Sensor Error.
Remedy: Adjust the Screws & Main Case Unit
Step 1: Remove the Left & Right Covers and the Main Case Unit (main cover).
Step 2: Remove the 4 mounting screws from the Chassis.
Step 3: Remove the Main Unit from the Bottom Case.
Step 4: Turn the Main Unit over (upside down) and place on work surface.
Step 5: Inspect the ASF section of the Main Unit for a gap between the white plastic guide and the Chassis. The size of the gap varies. Even if the gap is not visible, complete the steps below.
Step 6: Disconnect the appropriate cables and remove the Logic Board from the Chassis.
Step 7: Loosen but DO NOT remove the 4 mounting screws which can be located behind the logic board on the Chassis.
Step 8: Reseat the white plastic guide so it sits flush against the Chassis. The tip of the white plastic guide should sit slightly inside the mounting screw hole. When seated correctly, the gap will no longer be present.
Step 9: Tighten the 4 mounting screws without causing the plastic guide to shift.
Step 10: Reassemble the printer and retest.
Oct 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I cant figure out how to remove the stereo in my bronco because I cant find any visible attaching hardware. how do i remove the stereo?
most models have 4 holes...one in each corner...if its a factory stereo...a special tool can be bought to remove it or you can find some thing like a coat hanger..cut it into 4 pieces about 4 inches long..insert into all 4 holes and give it a little pry and it should slide out.
Jul 25, 2009 | Car Audio & Video
Headlights have been knocked out of alignment due to falling tree
yes there should be mounts maybe holes that their are torx heads u can adjust but there has to be look or take the 2 bolts out of the top of headlight and adjust for know
Jan 24, 2009 | 1999 Toyota Camry Solara
My Logik L22LID628 tv has an intermitant fault & will sometimes not respond to the remote control, I have tried new batteries, and checked the remote control by tuning an infra red light switch to the...
We have had two of these tvs break within 2 days of purchase, in our case both times it seems to be a backlight failure. Did you wall mount your tv? If so when you take the base off it leaves a hole in the casing leaving circuitry visible. I think it's very easy to damage the ciruitry.
Nov 01, 2008 | Televison & Video
42'' LCD PLTV-4250 MOUNTING
The universal mounts generally have a selection of screws that are to fit different makes and models of tvs.
If you bought the appropriate size mount for the size of your TV, there should be mounting holes that match your TV, and screws that will secure it.
I have not seen any mounts that use more than four.
Apr 07, 2008 | Protron PLTV-4250 42 in. LCD Television
How to mount amp
Turn your amp over and you'll see 4 holes one in each corner and you should gotten 4 v shapped pieces of metal with 2 holes each and 4 screws.....you normally have to mount them on manually. I hope that helps.
Mar 17, 2008 | Volfenhag ZX-8300 Car Audio Amplifier
Volfenhag ZX-8300 Car Audio Amplifier Logo
69 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
hoyzee1
Morne Olivier
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
