Question about NEC MultiSync 1760NX 17" LCD Monitor
Apologies if you got this?? i dont know how this works???
That monitor is probably close enough...
mine is the 1760v
Trying to figure out how to configure the resolutions and adjust the position.
thanks
trish
javgrirl@cox.net
  • 667 Answers
Here is the link for your manual that will help you with your resolutions and screen position. Really easy. Nice monitor : http://www.necdisplay.com/cms/documents/UserManuals/LCD1760V_manual3.pdf
Posted on Mar 17, 2008
  • Jeffrey Pemberton
    Jeffrey Pemberton Apr 22, 2008
    Hey Trish, just check in about the manual for monitor. Didn't hear from you further so I must believe that this was what you were looking for. I know you're busy but if you wouldn't mind please take a moment to rate this solution as fixed this. We're judged on our ratings and I would greatly apprectate it. Thanks much.
My monitor dont work anymore but when i charge it ..the charge light light up...and when it fully charge it turn green but still dont come on.. no water in or i didnt drop it help me
probably back light is out. Look closely at screen and see if you can see a faint image on screen (hard to see if no light behind to shine though, so look close).
May 21, 2014 | Uniden UDR444 - Monitor Lcd 4.3 Tchsc Bk
I have a NEC LCD 1760V and the resolution notifier keeps popping up. How do I eliminate this problem. It keeps telling me to exit.
insert the AGP card in the AGP slot in install the drivers the problem will be definatly solved the card should be of 8X grade
Mar 04, 2010 | NEC-Mitsubishi Nec Display Solutions...
Pedal does not bring up grill i have to take grill off and pull up manually any way to fix?
If you can still raise it manually, it probably needs new hydraulic struts. Mine actually never worked from new, and I am taking mine apart today to fix it. I will let you know what the part number is of the strut.
Aug 27, 2009 | Thermos Grill2Go Fire+Ice
No Manual--Don't know what top buttons do Minolta AF 10
Hi, Do you still need help? I can email the instructions. Tony
May 28, 2009 | Minolta Compact Binocular
My nec 1760v monitor goes into sleep mode while i am using it and the only way to get it out is to turn it off and then on.
In Windows, right click any empty space on the desktop> Properties >Screensaver>Power
Check settings \to TURN OFF your monitor in some time.. see if setting this OFF works.
Sep 01, 2008 | NEC Computers & Internet
Compaq presario 700F
definatley the display close power switch, located under switch/speaker panel.im not sure if the hinge activates it or not. looked into mine and found part# tag interfering w/ power switch board, cleaned it up, working good now. discovered this by gently pulling top left and pushing lower right of display, it would flicker.thaught it was closed probably a result of closing it with right side after every shut down.im trying to close only from middle..i also try never to pick it up from one corner, plastic is very bendy and screw comes loose.two hands always, specialy where rom is.i think your monitor thinks its closed. while black hold it under bright light and you can see enough to navigate.tried svid, used it for safemode driver check, took several hours before i got to hinge. i hope this is your troubles as they cost nothing to repair.my warrenty left 22 days ago.i was sweating.hope this helps.
joe
Aug 03, 2008 | Compaq Presario 700 470024-192 Notebook
DISPLAY STAYS FOR 2 SECOND ON NEC MULTISYNC LCD 1760V
the inverter board has a problem. this is the small pcb that sends high volts to the backlights you will need to change it
Jul 12, 2008 | NEC MultiSync 1525X 15" LCD Monitor
Getting stuck on trunked stations?
This is a digital trunk, you wont be able to pick these up on the bc780, it only does analog trunk systems. Some trunks use mixed analog/digital, if you can figure out which ID's are using digital you can lock them out. Even worse is the fact that the ID's you lock out are probably the ones that you are trying to monitor :(
May 10, 2008 | Uniden BC780XLT Base Scanner
Philips HDD082/17
Try a soft reset by holding the play/pause and the volume up button for a couple of seconds.
Oct 07, 2006 | Philips HDD082 MP3 Player
NEC MultiSync 1760NX 17" LCD Monitor Logo
146 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
