Question about Homedics Sound Spa Premier SS-5000 Clock Radio
Savings time We recently switched to daylight savings time. Despite changing my clock several times, it keeps reverting back. How can I keep it at the right time?
  • 1 more comment
  • EmilyS Mar 19, 2008
    The same thing is happening to our clock. I turned off the Atomic function, but still at the same time every day (6am for some reason), it goes back an hour to the time before daylight savings time started. I reset it manually, but the next morning it has reverted back.
  • Anonymous Mar 22, 2008
    Same issue with mine. I love the clock, but I am going to return it this weekend if I can't get a fix from there support line.
  • glucko_37744 May 11, 2010
    Clock keeps switching the time by itself sometimes to an hour earlier; sometimes many hours.
    Where is the solution in the directions?
    Is this a setting/option problem with an easy solution like slide over a switch or press a button?
    --Rich G
This is more of a Clarification than a solution.
I've determined that the SS-5000 is not recognizing the changes to DST that happened in 2007.
From 1986 to 2006 this was the first Sunday in April to the last Sunday in October, but starting in 2007, it is observed from the second Sunday in March to the first Sunday in November, adding about a month to daylight saving time.
So in March the clock is still trying to keep the "earler" time and in November it's trying to keep the 'later' time.
I'm contacting HomeMedics Support to see if there's a resolution.
Posted on Mar 11, 2009
  • jdlogan Mar 22, 2009
    Steps for DST resetting on the
    SS-5000.
    1.Remove batteries from the product.
    2.Unplug the
    adapter.
    3.Wait 1 min.
    4.Install
    batteries.
    5.Plug it into the wall.
    6.Set the unit to
    the correct time zone.
    7.Turn on the
    Atomic Clock.
    8.Clock should
    automatically adjust to the correct time in 2 to 4 hours.
    In order for DST to function, the unit must pick up the
    atomic clock.
    My Unit is now displaying the correct time.
    NOTE: I needed to turn to Atomic clock radio on several time before it caught the signal,
From website/webpage
http://media.homedics.com/IBs/SS-5000_IB.pdf
info from
Selecting a Time Zone
1. Press the ATOMIC ON/OFF button (Fig. 3) to turn off the atomic time function.
To indicate you are at the off position, the atomic time icon (Fig. 2) will be
removed from the display.
2. Toggle through the DST/TIME ZONE button (Fig. 3) until you reach your desired
time zone. (P - Pacific Standard Time, M - Mountain Standard Time, C - Central
Standard Time, E - Eastern Standard Time)
3. Once you have selected your time zone, press the ATOMIC ON/OFF button
again to turn on the atomic time function. To indicate you are at the on position,
the atomic time time icon will reappear with flashing antenna bands. (When the
antenna bands appear flashing the unit is searching for the atomic time signal.)
4. If the atomic time icon disappears afterwards, the atomic time signal is not available
at that moment. Try setting the unit in other locations. Remember to place the unit
away from sources of interference such as mobile phones, appliances, TV etc.
5. The atomic time icon will appear on screen if the atomic time reception is successful.
(The antenna bands will stop flashing when atomic time reception is successful.)
The radio-controlled clock will have a daily synchronization at 1:00 am everyday.
If previous attempts of reception were unsuccessful, the home receiver will
attempt synchronization each hour until successful. Each reception cycle ranges
from 2 - 10 minutes.
Manual Setting of Clock
1. Press the HOUR button (Fig 1) until you reach the correct hour.
2. Press the MIN button (Fig 1) until you reach the correct minute.
3. Press the BACKLIGHT HI/LOW/OFF button (Fig 3) to adjust the backlight intensity.
Note: A PM indicator will appear in the upper left hand corner of the LCD
display during the PM hours. Be sure to set the time for the correct 12-hour
period - AM (morning) or PM (evening).
Hope all this works.--RG
Posted on Sep 28, 2008
How do I get the clock to keep the daylight savings time and not revert when I restart the car?
set the time 1 hour fast as if you are setting the clock . So instead of setting it on 12 midday set it at 1 pm even though it is midday.. clocks do not know any different.
Jan 15, 2015 | Cars & Trucks
I recently moved my melodies in motion clock back one hour for daylight savings time and now the clock is not keeping time. I suppose I should not have moved it backwards but now what do I do to get the...
By moving the clock back one hour you changed from DST to standard time, not as you stated. Some clocks require you to rotate the hands clockwise to set the time back. Your clock may have been damaged beyond repair.
Nov 05, 2013 | Seiko Melodies in Motion Clock
My clock went back one hour on Sunday 10/25, need to get it to move ahead one hour.
The clock program for Daylight savings Time is programmed for the old "third Sunday in October" changeover. The new changeover is the first Sunday in November. The program probably cannot be updated. If there is no button or setting to disable automatic change to Daylight Savings Time you can set the time manually and then change it manually to Daylight Savings on November 1 for the time to be correct.
Oct 26, 2009 | Emerson Smartset Clock Radio
Can't change clock to eastern standard time
Can't solve it but the clock doesn't know the government changed when daylight ends.
Nov 04, 2008 | RCA RP5430 Clock Radio
Wrong Time
This appears to be a issue with the Magellan code. The Magellan code is setting Daylight Savings Time according to 2007 rules and not the 2008 rules. Magellan support indicates to change the time zone from Eastern to Central, save it and then put the time zone back to Eastern Time. I do not understand this solution. You can simply uncheck the Daylight Savings Time option and this will put the clock to the correct time. You will need to check the Daylight Savings Time option to put the clock ahead one hour when the clock is off by one hour. Magellan support informs me this is a manual process. Magellan needs to create a fix in their firmware to change the clock according to 2008 Daylight Savings Time when the box is checked.
Oct 23, 2008 | GPS
Setting to/from daylight savings time?
Press the white button on the base of the clock,
Harry
Jun 19, 2008 | RCA RP-3765 Clock Radio
Emerson Research SmartSet Clock Radio
There is a solution for this already. You can reprogram the clock to use the new DST settings.
See http://www.fixya.com/support/t137304-daylight_saving_time_issues
Mar 10, 2008 | Emerson SmartSet CKS1850 Clock Radio
Turning daylight saving time OFF
If DST is *already* set to "on" when you reset the time zone to Z-07 (Hawaii), my very recent experience is that the time *still gets adjusted back* by one hour.  Now that daylight savings time is over (at least according to the clock's pre-programmed and outdated schedule) I'm hoping that setting the time zone to Z-07 (Hawaii) will completely cancel the automatic time changes from now on.  Otherwise, I need to purchase another clock, and it won't be a Timex.
Apr 02, 2007 | Timex T311T Clock Radio
Homedics Sound Spa  Premier SS-5000 Clock Radio Logo
880 people viewed this question
Top Homedics Audio Players & Recorders Experts
Gyula Lacz
ray gallant
Are you a Homedics Audio Player and Recorder Expert? Answer questions, earn points and help others
