NEC Electra Elite DTU 32D-1 Corded Phone
Problem for NEC Electra Elite DTU 32D-1 Corded Phone (necdtu32d-1)
TELRAD AVANTI 3020 & 3015
By ERICC on Mar 17, 2008
HOW DO I SET THE TIME ON THESE UNITS? THERE IS NOTHING IN THE USER GUIDE.
THANK YOU
Same Problem
Mar 09, 2009
-   CAN'T CHANGE TIME, AND TRIED THE SOLUTION ON THE MESSAGE BOARD STILL NOT WORKING. -   Guest
Apr 15, 2008
-   It does not tell me how to set the time telrad avanti 3015-FD can you help-   opsman1
Best Solution
posted on Jul 15, 2008
Very Helpful)
seank123
Rank: Apprentice
Rating: 95%, 2 votes
Time is set on the MPD card in the system case. Use the eManager software and go to Tools->System Terminal. In there, select the System Utilities Menu (option 2) amd then Real Time Clock (option 4). You can set the time and date here.
Was this helpful?
Yes
No
Solution #2
posted on Nov 26, 2008
Very Helpful)
peggynez
Rank: Apprentice
Rating: 100%, 2 votes
Avanti Model 3020F or 3020H Display telephones
1) Leave the handset on-hook.
2) Press the FEATURE button.
3) Press the PROGRAM soft key.
4) Press TIME soft key.
5) Enter the time in the 24 hour clock format of HHMM. Use a leading 0 for single digit numbers.
6) Enter the date in the format DDMMYY using a leading 0 for single digit numbers.
7) Press SAVE soft key to save the settings.
Note: All 10 digits for the time and date must be entered. You can not skip any steps. To abort the time and date setting process press SPKR at any point before pressing SPD/PROG.
Avanti Model 3015DF or 3015DH Display telephones 1) Leave the handset on-hook.
3) Press the PROG soft key.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for NEC Electra Elite DTU 32D-1
Questions and Unsolved Problems for NEC Electra Elite DTU 32D-1
Do you recommend NEC Electra Elite DTU 32D-1 Corded Phone (necdtu32d-1)?
Answer
Answer
Someone transferred their calls to another extension and we can't get it released back to normal.
Answer
NEC-IP1NA-12TXH Phone. Light at the top, upper right of the unit blinks constantly. Driving me... (More)
Answer
I can't get the call forwarding cancelled. My instruction sheet says press FWD ALL then speaker, but... (More)
Answer
When calling from reception through handset to an office phone speaker there is loud buzzing heard.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For NEC Electra Elite DTU 32D-1...:
Top Phone Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Phone Experts
Top Telephone Repair
(800) 513-9962
Component level repair and complete refurbishing...
BARCLAYENTERPRISESINC
(316) 262-7171
Cctv,Cable Tv Wiring & Outlets,Computer Wiring...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
