NEC px42vp4a repair advice
My NEC px42vp4a turns on, the menues look fine, as soon as I send a "live" video signal, it shuts down,
witha a small click sound in the left corner area..
you can see the pic for a minute or so, then off
a "menue " screen from DVD stays on, caler as a bell. yet as soon as you actually have moving video, it turns off.
any advice on the repair needed?
thanks
  • solex98 Apr 06, 2009
    I have the same identical problem. Did you find any solution to remedy?
    Top Expert:
  • Televison & ... Master
  • 76,140 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ..
Posted on Jun 29, 2017
6ya staff
SOURCE:
techman
Larry Dillon
  • 3130 Answers
SOURCE: Screen Burn In ?
Nope Not unless you replace the tubes with the burn in them You have to take off ther front screen and look into the lens while tvs on and you will see what tube is burned worse. Sorry!!! but I have heard of folks equilizing the burned tubes by taking a solid color one at a time (red,green and blue) and keeping on only one color on for 4 to 6 hours one at a time and them all on at a time for a solid white and have seen some pretty good results.. Good Luck
Posted on Apr 19, 2006
Anonymous
  • 7 Answers
SOURCE: hdtv-dlp has no sound or picture
This sounds like an o-so familar problem. It sounds like the Switching IC or the MICOM has failed
Posted on Nov 10, 2006
techman
Larry Dillon
  • 3130 Answers
SOURCE: Convergence Problem?
The convergence IC most likly shorted, and burnt out the b+ feed resistor. There are two IC's inside this set to control the green red and blue convergence. They are most likly STK 392-###. The ### is another set of numbers that change depending on the model of the set. They each have three amps inside each one. You really should have both of the IC's replace with only original parts, as sub parts do not hold up and will not last as long as they should. Both IC's are soldered into place and if you decide to do this yourself, please be aware of the extemly high voltage inside of these puppys. there really are no user replaceable parts inside these sets unless you have solid state repair experience. Not only will yopu need the proper IC's, but you will have to find out what was burning. my best advice, Play it safe and call in a trained tech to assist you with this repair. The price should run someware between 300 to 450.00 to repair. Good Luck Please do not forget to rate this thread.
Posted on Dec 08, 2006
Anonymous
  • 317 Answers
SOURCE: Panasonic PT 47WX53 CinemaVision TV
call tech ..suggest c-chips..
Posted on Nov 26, 2007
Anonymous
SOURCE: Black screen- cannot view pictures, can hear sound
key is to open the cd tray and hold down the 1. Worked beatifully.
Posted on Jan 07, 2008
My N64 has always worked. But recently it has not been sending a signal to my TV. The red light turns on to show that it is on, But my screen remains black with no picture nor sound. I have tried resetting...
IT IS GONE. MY ADVICE IS TO BUY NEW ONE. THE GRAPHIC CARD HAS GONE BAD.
YOU CAN BUY NEW MOTHERBOARD AND REPLACE IT WITH THE OLD ONE THEN IT WILL WORK FINE AGAIN.
step by step
http://www.ifixit.com/Guide/Repair/Repairing-Nintendo-64-Motherboard/1608/1
http://ifixit.com/pdf/ifixit/guide_1608_en.pdf
PLEASE RATE IF THIS HELPED YOU
Apr 10, 2011 | Video Game Consoles & Games
I have a NEC PlasmaSync 42MP02. When I turn it on, there's a click the standby LED changes from red to green, but then goes back to red again. Nothing appears on the screen, it remains dark.
Monitor is not receiving the video signal. Check the video connection cable at the back, also test the monitor on a different computer.
Jul 05, 2008 | NEC Televison & Video
NEC Multisync LCD1765: Screen flashes and then mintor turns off with message "No Signal"
Restart your computer.
As soon as it starts the start-up process, keep tapping the F8 key, repeatedly.
When you see the Windows "start-up" menu, select "start in safe mode".
Does your monitor work in this low-resolution (640-by-480 or 800-by-600) mode?
If so, then you had configured Windows to a too-high resolution that the NEC did not support.
Choose 1024-by-768, and click "Apply", to test that the NEC supports this mode.
Try connecting the NEC to some other computer, to see if the NEC itself is the problem.
Mar 28, 2011 | NEC MultiSync LCD1765 17" Flat Panel LCD...
HI, My Hp DV9000 will turn on but shuts off the
There could be a few possibilities here, first the ac adapter needs to be checked for voltage at the tip, it has to be between 18.5 and 19.5 volts. The battery is most likely dead or has dead cells which will not carry a charge. The third problem could be the motherboard. Try leaving the battery out and just run the laptop off the AC adapter....if the laptop runs fine , then the battery is bad and sending signals to the motherboard causing a shutdown. If the laptop is still shutting down or refusing to start, then there maybe a problem with the voltage resulator in the charger brick. If the battery and charging brick are in good condition, then the laptop may be getting a thermal shut down signal from the processor because of an overheating condition. The processor heats up immediately, if the laptop has been run overheating for some time, the thermal grease on the processor can be cooked off reducing the efficiency of heat bleed off, thus causing a shut down to protect the laptop from a terminal meltdown. Try using compressed air and blow out all the ventilation grills and compartment openings to clear out debris, hair and dust.
Jan 07, 2010 | HP Pavilion dv9000z Notebook
Digital projector is shutting down as soon as dvd
Hi make sure that in the projector menu it doesn't have an option to cancel "control" as many tv's with hdmi have the capability to receive command signals through the hdmi cable.
Also make sure that your receiver is set for hdmi signal you must designate which input you are using on the receiver and then tell it what type of signal you want it to use.
you may have just pushed a button that changed these settings somewhere along the way.
hope that helps
Dec 30, 2009 | Denon AVR 3808Ci Receiver
Hi, I have an NEC hi-def-receiver, model NHD-1000, just recently it has been turning itself off, power is still there, has 4 lines instead of time but it loses the signal. 4 symbols appear when it shuts...
I had the same problem and found it was caused by dry solder joints in the output pins of the power supply board. Solved it by resoldering the joints.
Nov 24, 2009 | Kitchen Appliances - Others
Nec Multisync LCD 195VXM+ black screen after turning on computer
I'm thinking your video card is sending a signal the monitor doesn't recognize.
You'll need to start the computer and hit F8 until you get the black and white menu. Choose the VGA mode and it should work well enough for you to adjust the refresh rate or the resolution to get the monitor to work
Aug 28, 2009 | Computers & Internet
Labtec Webcam closes within Live Messenger
Normal 0 See section C. Windows Live Messenger in the info below to setup the Audio & Video.
Also send this to your family and friends so they have there computer setup properly.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/Bud ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
C. Windows Live Messenger:
Go to this site http://download.live.com/?sku=messengerBud and download Windows Live Messenger.
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Feb 14, 2009 | Labtec 961307-0914 Webcam
Mits. 1998 vs50603 48in.
Good Day, WADE N;
Some Models will shut down when no signal is detected.
Try unplugging the TV from wall/power source for 3 to 5 minutes.... plug back. Same thing? Go into OPTION MENU, press 'MENU' button on the remote > enter 1270. Choose reset system. If not there go to the SERVICE MENU, press "MENU > 1257 (same thing).
CAUTION: before you change any settings, document them (write down).
Good Luck, big IRISH.
Aug 13, 2008 | Mitsubishi VS-45607 45" Rear Projection...
NEC PX-42VP4G Power supply
Check to be sure that there is no voltage on the input line. You don't indicate what input you are using. Since the set appears to work without an input connected, try looking at the input cable. Also, if the problem is internal to the set, shorting the input jack would cause the same behavior. Please update this with what you find.
Dan
May 13, 2008 | NEC PlasmaSync 42VP4D 42 in. HD-Ready...
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
