Question about Panasonic KX TGA400B Cordless Expansion Handset
Panasonic KX-TGA400B De-register handset
One of our handsets does not work at all (will not charge, does not work with new battery). How do I de-register it so that I can assign another handset to that number? Note: We have 6 handsets all assigned.
  • 2 more comments
  • lstevens19 Apr 03, 2008
    Thanks for the help. Everything is corrected.
  • Anonymous Mar 14, 2014
    kx tg8220e my second handset is contually showing one bar on the battery indicator even when new batteries are inserted. I have scoured the internet for a replacement handset without success. Any suggestions?
  • Anonymous Mar 17, 2014
    The handset charges and the backlight works, the keypad does not function
  • 106 Answers
You do not need to power up the handset to delete the old intercom number, you do this on your base station. At your base push Function, then scroll up to Registration, push Enter, scroll to de-registration, push enter, scroll to the right and highlight that intercom number that you wish to delete, push Enter then Clear. If your not sure which intercom number it was, take a piece of paper and a pen and look at each functional handset you have, and notate the intercom number which is in the upper right hand corner. You can send your dead handset in for repair to have a backup, so don't toss it.
Posted on Mar 23, 2008
Can I get replacement phones (3) for Panasonic KX-TG6843B 6.0 3-Handset Cordless Telephone? This phone blocks up to 250 calls. If I keep the base, will I keep my blocked numbers.
The stored block numbers should be saved. The database is in the base's memory. Since the KX-TG6843 base can support a total of 6 KX-TGA680S handsets, you can purchase and register 3 new handsets. If needed, you can de-register the old ones from any working handset and then add even more. See page 35 of the manual, . Additional handsets are available from Panasonic, , Scroll down to the Accessories section and expand it. also has the handsets: .
I hope this helps.
May 30, 2017 | Panasonic Lands Phones
How can i register my hanset. it says error.
Please use the below link to assist you with handset registration.
May 06, 2014 | Panasonic KX-TGA560 Cordless Expansion...
Panasonic Phone Keeps De-Registering
This solution is for the KX-TG2356 cordless phone
The problem you are having is not that the handset is de-registering but your handset is losing the link to the main base.You said you went through 6 handsets then, the only remaining thing that could cause your problem is: A bad handset battery. This would give you all types of connection problems and the Main base.
I will begin with replacing the battery. If that does not solve your problem then the problem would be the main base
Mar 24, 2017 | Panasonic KX-TG2356 Cordless Phone
Panasonic kx-tg1611 wont register
how i registerd TG1611SP PANSONIC cordless with base and what is HS REGISTRATION and from where i got HS PIN NUMBER
Mar 17, 2013 | Panasonic KX TGA400B Cordless Expansion...
Manual for Panasonic Handset KX-TGA560B
For the KX-TG5672, you should press and hold the Intercom button until the charge indicator flashes. Then press the button to assign the handset # 1, 2 or 3 (keypad 1, 2 or 3). Then press OK on the handset and wait for the handset to beep. These steps must be done within a minute from when the charge indicator flashes. It's best to have the base and the handset close together when you register the handset.
Panasonic has the manual for the TX-TGA560 available here: . (This manual covers both the KX-TGA560B and KX-TGA560M.) The manual for the KX-TG5672 is available here: .
If you still have a problem, try removing the battery from the handset and disconnecting the power cord from the base (from the wall and the base itself). Wait a few minutes and then reconnect the power cord and the battery for the handset. (Make sure that the base has power and the adapter is warm.) Then try registering again.
I hope this helps.
Jan 03, 2012 | Computers & Internet
The number 1 button will not work unless extreme force is used
This is a very common problem with the KX-TGA400B and KX-TGA200B handsets. You need to replace the keypad or send it out for repair. Google "KX-TGA400B improved rubber keypad". Do not use the original factory keypad, the contacts are to small.
Dec 15, 2008 | Panasonic KX-TG4000B 4-LIne Multi-Handset...
A busy signal
Hi Kevin,
Sorry for being off line so long. If you have not fixed the problem already, I would try de-registering the handset 3 (from both the base and handset), then re-register it, it should re-register as HS 3, unless 1 and 2 are vacant. If that does not do it, de-register just the handset (not at the base), then re-register it to the base, it will grab the next sequencial intercom number. If it is still failing, then the handset is most likely defective. As a last resort, you can try initializing the handset and the base. Let me know how it goes. CG
Apr 03, 2008 | Panasonic KX TGA400B Cordless Expansion...
1 handset "no link to base', picked up a new one but the de-re register procedure did not work, still have the same msg with the new handset
You may have a bad base. Do you have other handsets that are running okay on your base? Are you confident your going through the registration procedures correctly with the replacement handset? Did you have a storm come through preceeding your problems?
Jan 27, 2008 | Panasonic KX-TGA600B Cordless Expansion...
DeRegistering a Damaged Cordless Phone????!!!!
If you are still looking for an answer on dereg of a handset, the manual says Menu - 0-0-2 then 3-3-5-OK then select the handset you want to cancel/deregister
Nov 05, 2007 | Panasonic KX-TG6074B Phone
DeRegistering a Damaged Cordless Phone???!!!!
I have a Panasonic KX-TG6700 base unit and KX-TGA670B handsets. We had a similar problem where we were no longer able to deregister the handset using the handset itself. We wanted to be able to use that slot that the broken phone was still occupyng. The solution that we found in the manual online was to hold down the intercom button for 3 seconds until the "in use" light turned on. Then press and hold the number of the extension you want to deregister until it beeps. At this point the base unit has freed that extension.
Nov 05, 2007 | Panasonic KX-TGA600B Cordless Expansion...
Panasonic KX TGA400B Cordless Expansion Handset Logo
414 people viewed this question
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
