What is IR lock means? and why it is happened two times on my PDP-25CMX.the remote control problems or the sensor in the display? help... thank you
    President:
  • 4,402 Answers
Infred lock in other words remote lock.unlock
Posted on Mar 17, 2008
Samsung ua46c8000 tv ir/sensor dose not work
Good day!
Please follow this procedure to find the exact problem.
  1. Check the battery of the remote.If your battery is 1.5vdc x2,the reading should be 1.5vdc x2 also! or 1.4vdc,tolerance to response the remote.Replace the battery if it is below on the tolerance voltage.
  2. Check the IR sensor using a digital camera or cell phone camera.
  3. Place the camera in the front of IR sensor then push any of the button to activate the remote.If your IR sensor flashes on the camera it means you IR sensor is good if not flashes on the camera replace it.
I hope this information will be helpful.Thank you very much.
Apr 18, 2011 | Samsung Bn59-01041a Remote Control
My verizon fios remote control stop to control the 65" cinema series toshiba tv.the remote seems to be ok.The oryginal tv remote doesnt control it also.I think that there is something wron with the tv...
Yes, most likely the sensor is at fault - more precisely it's connections to the motherboard are iffy. You must take the back cover off the tv and reseat them. While you are there check their soldering points - with age they tend to melt and get loose.
Jul 28, 2010 | Televison & Video
1.5 non database #120714 Every time we press a
The remote needs to be replaced. Call dish or go online to order a replacement. Thanks for using Fix Ya.
Mar 08, 2010 | DISH Network IR Remote Control
I got Two TV's My TV Connected to remote 1 in IR mode. After trying to record some thing using dvr the remote dies on satellite cannot change channel... Tech team tries every thing send new remote and...
topscrew2002
From what you have written, when you try to record on your DVR the remote stops working, is that correct? How long has this been happening? Have you received a new remote? If yes and it is still happening, you are probably getting IR interference from some source in that room. It could be from a florescent lamp, another player, or even the TV. Is the receiver in a open space or in an enclosed area? The IR sensor has to have a direct line of sight to work properly. You may also check on the receiver if anything is obstructing the sensors, maybe dust. I hope this helps.
Ray Calo
DISH Network
Dec 02, 2009 | DISH Network IR Remote Control
TV won't take remote control commands
I have the same issue. Obvious thing is to install new batteries. I assume you have done this already. Have you tried using the buttons on the bottom of the monitor to scroll through the main menu using the volume buttons to option 3, and scroll down to IR remote to see if it is selected ON. If it is OFF, select ON with the bottom LEFT or RIGHT buttons.If your remote still does not work, you can try to work it by connecting a 1/8" stereo mini-plug cable into the front end of the remote and the other end to the monitor remote control jack(second from bottom on back panel). Check the IR Remote settings this way. If it still does not work then you have the exact same problem I have... IR and Wired remote inoperative. I am still hoping for a solution but I am afraid there is either a stuck bit in the IR remote circuit or a bad board/chip. Anyone have a solution to this??
OPTION3
KEY LOCK OFF←→ON
IR REMOTE OFF←→ON
LOOP OUT OFF←→ON
ID NUMBER ALL←→1←…→256
Nov 08, 2009 | Pioneer PureVision PDP-424MV 42 in. Plasma...
My remote will not perform any functions with the Plasma TV. No Volume, Channel, Input, TV (off/on) etc.
If you have fresh batteries in your remote and its still not working, then try another remote and if you can't get another remote to work with the TV then you know its not a remote problem and its more then likely a problem with the IR sensor in the Plasma TV.
If thats your case after doing your troubleshooting then see if your Pioneer Plasma tv is under warranty, if it is contact Pioneer to get the TV covered under warranty. If its not then you would need to contact Pioneer to get the part # for the IR sensor on the plasma tv.
Then depending on price you can buy it from them or do a search on google to find the best price for the IR Sensor.
Aug 10, 2009 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Remote code for ps3
You should get a new remote control. TV manufacturers don't spend mich time or effort finding codes to all appliances. If you get a remote that can learn codes, it doesn't have to be in the ir codes list.
Mar 21, 2009 | Pioneer PDP-LX508A 50 in. Plasma TV
Panasonic PV-8400 Remote sensor not working?
This is indeed a faulty IR sensor. If it's just the sensor, swap with your good one to check. From memory they are plug in - a little device behing d the smoked translucent facia (display panel). I have come across this several times with Panasonic VCRs. Check whether the remote works at night time with all fluorescent lights in the room switched off. If so, the IR filter circuitry is faulty. Same solution - replace IR sensor on VCR.
Jul 21, 2008 | Panasonic PV-8400 VHS VCR
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Electro Med Services...
