Question about Xerox WorkCentre XD100 All-In-One Laser Printer
XD100 Workcenter Copy quality
Just replaced toner cartage, woks fine except black line down side of copy,
what is the problem with that??
  • redlaw Mar 18, 2008
    Thanks for your help, it is more of a thick black line down the edge of the copy, I cleaned the drum, and the transfer wire i think..How would you clean the mirror and lamp cartridge? is there a special soultion to clean it with?
Its so simple the main charger is dirty ,main charger is located on top of the drum unit and can be removed with two skrews, there are four screws in a row along the top of the drum unit remove the two outermost skrews and lift that whole piece over and up you will find excessive toner build up on the drum facing side of that main charger on the same end as your line, clean with soft brush and compressed air or you can wash with 409 and water if you wash with water make sure it is really DRY before you install back into machine or replace drum unit it is almost ready anyway
Posted on May 07, 2008
    President:
  • 2,072 Answers
If its is a fine line. Looking like a pencil line. See if it is there when you run it off the glass or through the document feeder. If it is only there when it is run throught the document feeder, the small strip of glass under teh document feeder had some contamination on it.
You may have something on the optics. Mirror or lamp carriages. You would want to clean those. The Drum cartridge could be bad. Take the drum out and see if it's on the drum.
The transfer wire on the lower part of the right hand door, just above the white rollers and may need cleaned.
Last and the least likely would be the fuser roller. That is the heated area just before exit area of the machine, You can look in there with a flash light and see if any of that roller is worn.
In order, I would think . 1, Drum, 2 Optiscs, 3. Fuser,4 Transfer corotron wire on the right door.
Posted on Mar 17, 2008
  • Rick Kasper Mar 18, 2008
    Well with it being a thick line, I somewhat suspect the cartride had be sitting on end and all the ink and developer have congregated on one side. When you remove the cartridge is there any leaking from the end the marks are on? It may simply need shook side to side. May also be defective, I am assuming that the problem started with the new cartridge?
    Now if it is leaking you should try and vacuum it out if you have a crevice tool on a vacuum.
    If the issue was already there and the line is thick and kind of crusty and flakes off, you have a bad fuser roll. Sometimes the teflon coating will peel off the roller and the ink will build up on it, and cause a pretty bad looking streak, it will be thick and uneven looking, not a straight streaky line.
    as far as cleaning the mirrors and lamp. Use as soft a cloth as you have. The mirrors are front surface mirrors. So just dont use paper towels. The texture of a Tee Shirt type materal. Any glass cleaner will be fine, I like to use a 50/50 mix of rubbing alcohol and filtered water. Cleans well and doesnt streak.
    You want to just gently wipe the lamp, they are quartz and don't withstand a lot of pressure.
I have a xerox workcenter XD102 with a J1 error. What do I need to do?
J1 code on the XD100 series means that your toner cartridge is empty. You will need to order in a new one or have your existing cartridge refilled. Refills run about $60.00 and new ones are in the $100 to $125 range.
Precisionroller.com has a very good remanufactured unit for $46.00
http://www.precisionroller.com/search.php?q=xd100+toner
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 22, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
Replaced toner cartridge and copy had line of toner on edge -
Check the ink modual again.
if the ink is all on the upper and lower lip it needs to be wiped off.
Sometimes when shaking this modual, exessive ink can go on the surface and scrub on the drum itself.
How did you clean the drum?
Nothing should be used except a very soft dry cloth. The toner acts as a lubricant to the cleaning moducal.
Take out the toner modual and see if you can tilt the modual back away so it falls to the back of the modual, this way there will not be so much at the front developer mag roller.
Apr 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Black line down middle of confirmation copy
You need to remove the toner cartridge if fitted pull out the toner holder, making sure the opening is on the top, if not the toner will spill out, set this to one side and clean the toner holder thoroughly.
Mar 18, 2009 | Office Equipment & Supplies
Xerox XD100 does not work
When you saying No working , What Happens when you press the print Button can you manually get this copier to print out ?
Has it stop printing only ?
Feb 19, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
PC 920 Faded sides
hi
try this open the copier and remove Toner Cartridges and shake side ways for 5 times and try to make copy,if faded gone its better to replace Toner Cartridges for better copy quality
Dec 12, 2008 | Canon PC-940 Black and White Copier
Paper folds and jams before
your description points to a fuser assembly problem which is right where you looked. I'm not sure what that plastic piece is from. if it is black, it probably came from the fuser. That is a replaceable part, but I'm not sure you can still purchase them from Xerox.
Jun 24, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Bad copy quality on my brother MFC-9600. I have replaced the drum unit and still have vertical lines on the copy
Its not the drum,,, the toner cartridge has the black line pathc on the photosynthetic drum and that is causing the problem. check it by taking it out and roll the drum using your finger you will notice the vertical black patch. Get the toner replaced
May 30, 2008 | Brother Office Equipment & Supplies
Copy Quality Problem for Thiashen
bit vague...Cq not good? What does that mean?
Light copies> could be related to toner or ROS unit (laser unit)
if prints OK but copies U/S clean mirrors and ccd lens
Dark copies , streaking? Cleaning blade /drum unit U/S
or could be streaking from fuser roll
Patchy copies , dark edges, light edges ???????
more detail please
Feb 02, 2008 | Office Equipment & Supplies
Poor quality copies on Canon imageRUNNER 330
the image drum needs to be replaced
thanks for rating
Jan 10, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Xerox workcenter XD120f
The small scanner glass (not the full size glass) has some dirt on it. Use a lint-free cloth (not paper) with alcohol or Windex and clean the glass. This should help.
Nov 14, 2006 | Xerox WorkCentre XD120f Copier
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
100 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
