Xerox 5830 A2-2 code
ADF will not feed moves in only about 1/8th"
    President:
  • 2,072 Answers
A2-2 is an indication the feed rollers adn belts are slick.
What you can try it to take a piece of paper, dampen is slightly in the middle with alcohol, put that into the feeder and hold it to jam.
What that will do it allow the rollers to spin on the paper with the alcohol and you will see the dirt on the paper. You may have to do that a few times to get those rolls clean.
Do not use a soapy cleaner like fantstic since it will shread the paper.
But you have slick feed components, cleaning will help, but the only cure is to replace them.
Posted on Mar 17, 2008
SOURCE:
I have Xerox M 20i .When ever I feed papers from ADf. Print is not coming normal.Some time it shrink the text,I checked the roller are fine.
The Xerox is a business machine and has a setting to reduce the size of scans by percentage.
Read the instruction manual to turn it off or play with the buttons.
WorkCentre M20/M20i Documentation - Xerox Support and Drivers
www.support.xerox.com/support/workcentre-m20-m20i/documentation/enus.html
  1. Cached
  2. Similar
Product documentation for WorkCentre M20/M20i. ... WorkCentre M20/M20i Firmware Installation Instructions. Setup and Installation Guides. Description.
[PDF]WorkCentre M20i System Administration Guide - Xerox Support and ...
www.support.xerox.com/support/workcentre-m20i/file-redirect/enus.html?...en... Xerox WorkCentre M20i System Administration Guide. Page i. Table of Contents. 1 Welcome ................................................................................. 1-1. Introduction .
Xerox 20i Google Search
Nov 19, 2016 | Xerox Office Equipment & Supplies
Documate error 8
Hello.
I am a Support Engineer with Xerox Scanners.
E8 is a Paper Jam error that could be caused by:
- paper crumpling during scan.
- paper is multi-feeding all at once instead of feeding separate.
- scanner continuously tries to feed after paper has fed through.
if the paper is crumpling during the scan, make sure the inside of the scanner is clear of any obstructions. use the paper guides in the ADF tray to keep the paper straight when feeding in.
if the paper is multifeeding while scanning, fan out the pages before inserting them into the scanner. if problem persists, try cleaning the rollers with rubbing alcohol and a lint free cloth.
if scanner tries to continually feed after the paper feeds through, the ADF tray will need to be reseated. open the scanner and remove the ADF tray at the top. line up the 4 keys at the bottom of the tray with the 4 corresponding key slots inside the scanner. push the tray back until it clicks into place.
We also have an extensive support site and knowledgebase at
http://www.xeroxscanners.com/en/en/support/
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
Jan 28, 2013 | Xerox DocuMate 162 Pass-Through Scanner
I need part numbers for the ADF feed roller/shaft/clutch and the ADF Separation Pad/Roller.
Should be 002N02001 for the Feed Roller Assembly and 22N1487 for the Separation Pad
About $50 total for both parts
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 16, 2010 | Xerox WorkCentre M15i Laser Printer
I picked up a 5830 copier and a paper jam is in the LCD I followed the instruction, and there is no paper caught into the area per the displayed area or in the paper path period. Code is D3-1 Do you have a...
The machine has been sitting around for a while, or was just been stopped being used.
Try cleaning the brown roller in Tray 2.
Try the other paper trays see if they work. Tray 1 and tray 3.
We would need more information about the results of these areas and how it worked.
If there is alcohole, try cleaning the brown roller. The other rollers are harder to see. This machine could even have bad paper feed clutches.
A xerox serivce call would have to be placed to do the major repairs.
Oct 03, 2009 | Xerox 5830 Copier
I have forget my user code
if it is a 5830 model, go to the menu and look for tools.
type "1111" and hit enter
sometimes it can be "11111" and see if it works.
I hope this is the area you wish to enter.
If it is the auditron mode, place a Xerox service call for the service rep.
Jun 05, 2009 | Xerox 5830 Copier
XEROX 6110 coloer printers
Xerox 6110 Code Description A1-1 to A1-32 All indicate a paper path problem, etc. in the ADF A2 ADF exit problems A3 Irregular size documents A5 ADF interlock A6 ADF single sheet document reset A7 Platen interlock A8 ADF exit interlock C1 Tray 1 jam C2 Tray 2 jam C3 Tray 3 jam C6-1, C6-2 Jams related to duplex C6-3 Registration sensor, re tray 1 C7-1, C7-2 HCF feed problems C7-3 Tray 1 feed problem C8 Paper stays in tray or duplex or HCF C9 Bypass feed problem E1-10 to E1-25 Internal jam E1-6 Paper on registration sensor E2 Reset signal happened. Might read E-2 something else E3-30 to E4-14 Exit jam E3-6 Exit jam E4-10 to E4-14 Inverter sensor not actuated E4-15 Inverter sensor E4-40 to E4-45 Duplex entry sensor E4-6 Inverter sensor E5 Front door interlock E6-1 Tray 1 interlock E6-2 2 tray or duplex interlock E6-3 HCF interlock E7-2, E7-3 Duplex interlock E8-6 to E8-15 Duplex entry sensor F1-1 Sorter entry sensor F1-6 Sorter exit sensor F3 Paper size not available for sort/stack F5 Sorter interlock J1 Add toner J3 Replace copy cartridge J7 Replace copy cartridge J8-1 Wrong copy cartridge installed J8-2 Copy cartridge EEPROM L6 Auditron or other counter problem L8 Platen glass temperature is too high L9 Communication problem between interimage erase/edge lamps and main board U1-1 Main motor drive problem U2-1 to U2-4 Scan home sensor U3-1 Lens sensor U4-1 Open fuser thermistor U4-2 Fuser did not warm up properly U4-3 Fuser temperature too high U4-4 Fuser problem. Staying on too long U4-6 High fuser temperature U5-1 Sorter bin home switch not activated U5-2 Sorter bin home switch stayed actuated U5-3, U5-4 Sorter bin home switch U6-1 ROM problem U6-2 RAM problem U6-3 Low battery U6-4 Incorrect value in NVM. Reinitialize main board with code 20-96 U8-1 to U8-6 Problem with exposure lamp, lamp sensor, lamp board
Jan 03, 2009 | Office Equipment & Supplies
ADF won't feed the paper. The feeder wheels are heard turning but the paper won't feed.Replaced the "pad" and cleaned the rollers & glass and checked the feed guide and feed sensor.
If those rollers are turning, and not feeding even after cleaning they simply need replaced. they can get so slick that no ammount of cleaning will help.
Thats what is sounds like.
Like trying to drive a car on ice. No traction.
Jan 25, 2008 | Xerox DocuMate 272 Path-Through Scanner
Image wrap with adf
You have to reinitialize the software. I will be back in a few minutes with the procedure. I have to hunt it up.
Jan 23, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Document not moving all the way thru ADF.
The roller and retard pad need replaced. They are simply worn.
Oct 19, 2007 | Xerox DOCUMATE 510 Flatbed Scanner
83 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
