Water doesnt stop over fills the tub - Washing Machines
  • Anonymous Jan 25, 2009
    part no. fwx225rhso
    Novelist:
  • 139 Answers
Most washers have a pressure switch in the control panel that controls the water level. A plastic or rubber tube connects from the bottom of the tub to the pressure switch. The washer will fail to stop filling if the tube comes loose or develops a leak. The other possible problem is that the pressure switch is defective.
Posted on Mar 17, 2008
    Sergeant:
    Champion:
  • 266 Answers
I had the same problem. How I fixed my problem.... 1st blow out the line, mine had water in it. 2 put line back on switch, use new hose clamp, I used a 3/8 gates hose clamp from the auto parts store. on the pressure switch there is a adjustment screw. back it all the way out. wipe clean and dry with q tip. put screw back in. tighten all the way down, be gentle it's plastic don't strip it! then back it out till it's level with the holder. turn on washer when the tub fills about 4 to 6 inches of water , 1-2 inches from the bottom of glass the water should shut off, if it shuts off early turn screw 1\2 a turn till water level is reached. the pressure in the line should be around .15 to .20 psi. remeber to check your water pressure too, it must be between 20 to 75 psi so the valve will close.
Posted on Jan 23, 2009
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: washer fills up only half way but water keeps trying to fill tub
That is because the water level switch get stuck when water level reaches that particular point.
The water level switch is activated either by a floater sensor or by a membrane sensor that detects water pressure/volume, depending on the model.
On washing machines it is usually a membrane switch, and that is faulty on your machine.
Posted on Feb 20, 2009
  • 16 Answers
SOURCE: My washing machine doesnt stop filling the tub when the right water level is reached
Not familiar with this model. When a washing machine fills with water up to a predetermined level, it usually operates a pressure switch which will turn off the water valve, and redirect the power to the programmer, or heater, or some other stage of the programme. If there is a blockage of powder or gunge in the tube leading to the pressure switch this would prevent air from rising up the tube to operate the switch. Tom.
Posted on Mar 09, 2007
mgprice
  • 744 Answers
SOURCE: water doesn't stop filling tub and tub overflows
Hello,Sounds like a problem with either the inlet valve or the pressure switch, way to determine which on is while it is filling pull the plug..if water keeps filling it's the inlet valve..if it stops filling it's the pressure switch..If you have any other questions or concerns please feel free to comment again..good luck!! Mike
Posted on Aug 31, 2009
Water doesnt stop fillinG in panasonic NA F60A6 WASHING MACHINE
Fyi. All new washing maching already tested on their functionality and features but not test run with water intake and drain function. I would like to share My experience last time with this model. The water outlet valve will release by motor when you set to drain mode.it suppose manage to retract back by spring when drain process finish or afte small you change to wash mode.
Take a look on the spring movement.normally it not properly hold valve switch hence the retracted spring not block the valve to stop water drain. Just rectify the alignment of the valve swich which directly connected to the retractable spring.
Dec 26, 2010 | Washing Machines
Sometimes washer keeps running water & doesnt fill up. i have to unplug it for a few hours so it can work again...has happened on all cycles...what causes tub not to fill with water
water is siphoning out the drain hose ,drain pipe not high enough "must be 36 inchs"from floor or hose is inserted in pipe to far creating a suction situation ~once over the edge it cant stop...., may need a anti siphon kit on drain hose .
Apr 27, 2010 | Roper RAX4233PQ Top Load Washer
Washing machinve overflows intermittently - sometimes the water stops and sometimes it doesnt.  Occurs on all the cycles not just the first fill
Thats caused by the pressure switch or the fill valve. Try checking the tub for a clear hose coming from the side and be sure its attached.
Mar 13, 2010 | Whirlpool LCR7244H Top Load Washer
Gcxrpo9odoww GE washer .. On fill up, it over flows onto floor?
Fill switch could be bad, or fill tube could be plugged making water not stop and it keeps filling. The fill tube goes from fill load selector switch to bottom of tub. Remove from top and blow it out. If this doesnt work replace water load size selector switch.
Jan 17, 2010 | GE WBSR3140DW Top Load Washer
My washing machine does not stop filling up it runs over.It still spins the water out, but was making an awful grinding noise.
FIRST, IF IT DOESNT STOP FILLING YOU EITHER HAVE A CLOGGED VACUUM LINE OR A BAD PRESSURE SWITCH. AS FOR THE NOISE WHEN IT SPINS, TAKE OFF THE BELT, CHECK PULLEY FOR THE MOTOR AND PUMP, IT SHOULD SPIN FREELY AND TIGHT. IF THEY BOTH GOOD, AND THE NOISE IS AROUND THE MIDDLE OF THE TUB ON TOP OF THE TRANSMISSION, MEANS YOU HAVE A BAD TUB BEARING
BOYNISMO@YAHOO.COM OR 714-334-1998. I CAN WALK YOU THROUGH THE PROCESS IF NEEDED.
Jan 14, 2010 | Admiral Washing Machines
Water keeps filling and doesnt go to next cycle
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tube. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Sep 03, 2009 | Washing Machines
Water doesn't stop filling tub and tub overflows
the water level sensor is not working and needs to be replaced
Aug 31, 2009 | Washing Machines
Maytag washer water doesnt stop
raise top or remove front panel(can't remember which) rear corner left small hose attached to connector on tub pull and clean probably plugged up with crud also ck connection on tub
Dec 12, 2008 | Maytag HAV3460AWW Top Load Washer
COLD WATER DOESNT SHUT OFF AND SPIN CYCLE STARTS AND STOPS
The pressure tube switch tubing gets clogged on these machines. The best way to repair is remove the 4 torx screws securing the control panel, On the water level switch remove clear tube from switch, with some water in tub, i suck water up and back down the tube, clearing the tube. After tube is clear spin machine for 3 mins. Test water fill again.
Dec 04, 2007 | Washing Machines
My washing machine doesnt stop filling the tub when the right water level is reached, it will just continue filling and never stops filling. Can anyone suggest what is wrong and how to fix this?
Feb 27, 2007 | Admiral AW22 Top Load Washer
Washing Machines Logo
175 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
