Question about Sony Ericsson Walkman W810i Cellular Phone
Ear phone my left ear phone dose not work
    Novelist:
  • 188 Answers
It might be due to loose connection of the wires are they are broken.
I suggest you to get a new one.
It cannot be repaired.
Hope you can understand.
Posted on Mar 20, 2008
Just moved to new location and hooked up i com. Am only getting sound in left ear. Have rechecked everything and all connections seem sound???
this is an oxmoron you cant have checked every thing
left and right ear audio on CBs come from a common mono signal
so the right ear signal is missing or the headphone on the right ear piece is busted
sherlock....
Nov 27, 2014 | Icom Ptt Over Ear Mic / Ear-phone For...
Jvc gumy ear bud headphones purple
When you pull the wire up does it increase the right ear bud volume/ sound? If it does, then it means the right side ear bud has a short within the head phones circuit which is aka the wire that leads to the musical device in which the ear buds branch off from.
If the right side ear bud does not produce an increased volume for sound by picking the wire up or pulling it in towards you or to the left side of your body or musical device then it means that the right speaker is blown.
I know that all head phones come spiced together aka they are stuck together and have to be pulled apart in order to get both head phones seperated from each other so that they can be worn in the ears. If you pulled the wire apart to much or too quickly then that is what ruined the right head phone.
I suggest that regardless if the ear phones begin to work by pulling the wire up,side ways, or into towards your body that you return them back to the store since after awhile the problem will eventually continue to happen causing the right ear bud to completely blow. Once you return the ear phones be cautious with the new set when you seperate the ear buds from each other since they are very touchy and have to be handled with delicateness when seperation is taking place.
Please let me know how it works out for you. I have had many ear buds and I tell ya something; they are very easy to blow one side when seperating. I had to learn after a few pairs that I was ruining the speakers by the way I was seperating my wires. I kept thinking for the first 3 pairs that the store was selling blown ear buds until I began having same problems with another few stores so I said to myself "well the solution is to figure out what I am doing wrong in order to blow one side of my ear buds every time". After few seconds it was not that obvious that all I had to do for assembly was to pull the wires apart in order to get both ear buds to go into my ears.
Jan 22, 2014 | JVC Gumy Ear Bud Headphone - Peppermint...
Ear tip can NOT fit my ear ! it keeps slide out from my ear~ Dose anyone here have the solution for it?? is there any ear tip i can use to solve the problem ?? Thanks
Have you tried a different size ear tip, you should have gotten a small ab a large size, here is the link below for the Backbeat 903 ear tips (model 80846-01).
Plantronics BackBeat 903 Ear Tips
Good luck from Headsets Direct!
Nov 03, 2011 | Plantronics Backbeat 903 Bluetooth...
Left ear doesnt give out sound
there are two reasons for which your left ear head phone is not working:
1.If the insulation between the wires(copper leads inside the cord) fails....the two leads gets short circuited and it will stop working...OR some times the cord ll be looking good but inside one of the leads got cut then one of the headphones fails...
the solution for the above problem is dont wrap the cord...this ll lead to cut or insulation failure....
2.the speaker in the left head phone got failed...
dont forget to rate me...
good luck...
Apr 15, 2010 | Bose Around-Ear Headphones - Silver
Only one ear phone work
Check Following Instructions:
- Connect your ear phone pin properly to your MP3 Player.
- If one ear phone not working - check ear phone wire is break - connect wire metal correcly.
your ear phone will working.
Apr 13, 2010 | Archos Internet Media Tablet MP3 Player
Only the left ear phone works
Try updating the firmware.
http://kb.sandisk.com/app/answers/detail/a_id/156/kw/firmware/r_id/101834
Mar 31, 2010 | SanDisk Sansa e250 MP3 Player
Ear phone jack needs to be replaced
If you know anyone with soldering capability the pads on the headphone jack just need to be re-soldered. Mine did the same thing so I re-flowed the solder joint and now it works perfect.
-Brad
Dec 08, 2008 | Dell Pocket DJ MP3 Player
No HD
Your TV has a built in tuner but NOT a built in antenna. Depending on where you live (distance from broadcasters) you will need to add anywhere from rabbit ears (with the UHF loop) to an antenna on the roof or mast.
If your home already has an antenna installed, connect the coaxial cable to the back of your TV. Then go to "Set-up" and scan for DIGITAL channels. If you are trying rabbit ears, do the same.
Mar 15, 2008 | Protron PLTV-4250 42 in. LCD Television
Nokia 3120
your nokia phone dose not recocnize this headphone......it has software compatiblity issues...goto the dealer from where you have purchased it ...if he is not able to solve it thn go to nokia center
Dec 26, 2007 | Nokia Handsfree Car Kit For 3100, 3120...
Sony Ericsson Walkman W810i Cellular Phone Logo
26 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
